您好,我需要定期使用我的天线在N1996A频谱分析仪上进行天空测量,即每隔15分钟左右,在24小时内进行天空测量。
理想情况下数据应该是数字,所以最终我需要它是xls格式(或任何可以很容易地转换为matlab或Origin进行分析的东西)到目前为止,我已经尝试过使用VEE Pro 8.5和一些SCPI命令。 MMEM:STOR:TRAC命令需要每次都定义一个路径。 但是,我希望它自动运行总共100次,并保存跟踪或测量数据。 一遍又一遍地运行相同的命令只是替换旧文件。 有人可以帮忙吗? 提前致谢。 以上来自于谷歌翻译 以下为原文 Hello, I need to take sky measurements using my antenna on an N1996A spectrum analyzer periodically, i.e. every 15 minutes or so, over a period of 24 hours. The data should be ideally in numbers, so ultimately I would need it to be in xls format (or anything that can easily be transposed to MATLAB or Origin for analysis) So far I have tried using VEE Pro 8.5 along with some SCPI commands. The MMEM:STOR:TRAC command requires a path to be defined every time. However, I want it to run automatically for a total of, say 100 times, and save the trace or measurement data. Running the same command over and over again simply replaces the old file. Can anyone help? Thanks in advance. |
1个回答
我会在您的VEE程序中控制测量的时间,然后只要您想使用以下内容从仪器中提取跟踪数据:TRAC:DATA?
远程查询。 然后,您可以将跟踪数据保存到PC上的文件中,并根据您获取数据的时间选择文件命名,或者根据您可能想要的其他任何内容进行命名。 这也比将数据保存到仪器存储器快得多。 最好的问候,Mike编辑:Mike M于2015年2月11日上午10:00 以上来自于谷歌翻译 以下为原文 I would control the timing of the measurements in your VEE program and then just pull trace data from the instrument whenever you wanted to using the :TRAC:DATA? remote query. You could then save the trace data to a file on your PC with your selection of the file naming based on the time you took the data, or whatever else you might want to base it on. This would also be much faster than saving the data to the instrument memory. Best regards, Mike Edited by: Mike M on Feb 11, 2015 10:00 AM |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 08:51 , Processed in 0.932552 second(s), Total 45, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
