嗨,是否可以将8590处理器板更换/换成8592A?
当然要交换四个固件存储器等等。 还要改变内存跳线? 73阿里 以上来自于谷歌翻译 以下为原文 Hi , Is it possible to change/swap a 8590 processorboard into a 8592A ? of course with swap the four firmware memories and so on. Also change the memory jumpers ?? 73 Ary |
6个回答
我刚看到你发布的消息,但我没有看到任何重播,我有一个类似的分析器8592a,就在最近我得到“也许”同样的问题,屏幕有垂直线条,这阻止我读取错误的代码,但申请时
校准信号300Mhz信号显示在垂直线的背景中,我也看到一些字符,你能找到解决问题的方法吗? 谢谢 以上来自于谷歌翻译 以下为原文 I just saw your posted message , but I haven't seen any replay, I have a similar analyzer 8592a and just recently I got " maybe" the same problem , the screen has vertical lines which prevent me to read the faulty code but when apply the calibration signal 300Mhz the signal is displayed in the back ground of the vertical lines and also I see some characters , have you been able to find the solution to the problem ? Thanks |
感谢您的回复,我将尝试关闭校正因子,看看是否得到相同的结果。 我更专注于视频板,然后是A16处理器板,8592a,我有一个独立的处理器板视频板,不幸的是我无法找到任何绘图板,所有我 发现与处理器和视频在同一块板上的8590有关。 该板有一个由Hitachi制造的视频控制器IC和4个视频存储器u9,u12,u12,u18以及其他IC。 我不急着让单位继续前进,因为我已经退休了,我只是喜欢用这个单位来玩,但是我想看看单位的运行,它不一定是完美的很久我 将能够看到显示的信号..绝对有一个类似的工作单位交换电路板并能够确定故障板然后只在故障板上工作会很好,但找到一个工作单元将非常 难。 我会继续寻找解决方案,并会让你发布。 再次感谢 以上来自于谷歌翻译 以下为原文 Thanks for your response , I will try to turn the correction factor off and see if I get the same result. I was more concentrating on the video board then to the A16 processor board, the 8592a which I have has a stand alone video board from the processor board, unfortunately I haven't been able to find any drawing for the board ,all the one I found are relate to the 8590 which the processor and the video are in the same board. This board has a video controller IC made by Hitachi and 4 video memory u9 ,u12,u12,u18 plus the rest of IC's . I'm not in a big hurry to get the unit going, since I'm retired and I only like to use the unit to play around but I would like to see the unit going, it does not have to be perfect has long I will be able to see the signal displayed.. Definitely it would be nice to have a similar working unit to swap the board and be able to determine the faulty board and then work only on the faulty board ,but finding a working unit will be very difficult. I will keep looking for a solution and will keep you posted. Thanks again |
tong5682 发表于 2018-10-26 08:53 当在校准运行期间检测到的信号中存在幅度误差时,我已经看到类似的问题。 我的具体问题被追溯到间歇性衰减器。 两个主要线索是:1)不连续性总是发生在同一点或幅度相同的边界内,2)当关闭校正时,问题就消失了。 编辑:当我说“幅度误差”时,我并不是指预期的频率响应变化。 我的意思是极端和意外的幅度变化,如衰减器中的一个坏步骤,会混淆校准程序并使其产生不良的校准数据。编辑:MarkL于2015年3月18日上午5:23 以上来自于谷歌翻译 以下为原文 I have seen problems similar to this when there are amplitude errors in the detected signal during a calibration run. My specific problem was tracked down to an intermittent attenuator. The two major clues are: 1) The discontinuity always happens at the same point or within the same boundaries in amplitude, and 2) The problem goes away when correction is turned off. EDIT: And when I say "amplitude errors," I don't mean expected frequency response variations. I mean extreme and unexpected amplitude changes, like a bad step in the attenuator, that confuses the calibration routine and casues it to generate bad cal data. Edited by: MarkL on Mar 18, 2015 5:23 AM |
uvysdfydad 发表于 2018-10-26 09:00 谢谢MarkL,是的,这个问题随着“Cor Off”消失了。 关于EDIT的评论。 步骤attanuator检查是否正常频率校准看起来不错,但“商店校准”不会工作。 无法进行幅度校准。 看到线程上的图片。 阿雷 以上来自于谷歌翻译 以下为原文 Thanks MarkL, Yes this problem goes away with "Cor Off". Remarks on EDIT. step attanuator is checked is ok Frequency calibration looks ok but "store cal" wont work. Amplitude calibration is not possible. see pictures on thread. Ary |
W_B_L 发表于 2018-10-26 09:10 如果您可以看到正常校准信号并且关闭校正,则可能需要覆盖初始校准。 我找不到专门针对8592A的服务手册,但859xE系列有这样的东西。 它的工作原理如下(服务手册第209页):...仪器固件要求校准输出信号为300 MHz±2 MHz。 有时仪器默认数据无法调整此范围内的校准信号,并且屏幕上可能会出现“未找到校准信号”消息。 按Frequency,-37,Hz,Cal,Cal Freq执行校准输出旁路检查。 这将绕过校准检查,并通过校准扫描斜坡开始。 ... 8592A可能有类似的东西可以帮助你。 以上来自于谷歌翻译 以下为原文 If you can see a normal cal signal with correction off, you might need to override the initial cal sanity check. I can't find a service manual specific for a 8592A, but there is such a thing for the 859xE series. It works like this (page 209 of the service manual): ... Instrument firmware expects the cal output signal to be 300 MHz ± 2 MHz. Sometimes the instrument default data is not able to tune the cal signal within this range and a “cal signal not found” message may appear on screen. Perform a cal output bypass check by pressing Frequency, -37, Hz, Cal, Cal Freq. This will bypass the cal check and start by calibrating the sweep ramp. ... There may be something similar for the 8592A that could help you. |
uvysdfydad 发表于 2018-10-26 09:25 嗨马克尔,谢谢你的信息,我已经尝试了-37赫兹。 但它没有给出任何结果。 再次迎接挑战。编辑:PA0ALV于2015年3月26日上午5:25 以上来自于谷歌翻译 以下为原文 Hi Markl, Thanks for info, ive tried the -37 Hz. But it did not give any results. Going on its a challenge again. Edited by: PA0ALV on Mar 26, 2015 5:25 AM |
只有小组成员才能发言,加入小组>>
2096 浏览 1 评论
1854 浏览 1 评论
1712 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 15:32 , Processed in 1.289644 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
