嗨,
我目前正在尝试打包IP。 为此,我需要在“端口和接口”视图中编辑端口。 不幸的是,当我尝试将“左侧大小”从“(toCeilLog2(DnCount_g) - 1)”设置为(ceiling(log(2,DnCount_g)) - 1)“并按”OK“然后窗口将不会关闭,我 我不能做更多的事情。窗口只停留,但我不能按另一个按钮(如十字架或取消按钮)。我仍然可以移动窗口,但就是这样。任何想法有什么不对? 以上来自于谷歌翻译 以下为原文 Hi, I currently try to package an IP. For that I need to edit ports in the "Ports and Interfaces" view. Unfortunatly when I try to set the "Left size" from "(toCeilLog2(DnCount_g) - 1)" to (ceiling(log(2,DnCount_g)) - 1)" and press "OK" then the window will not close and I am not able to do something more. The window just stays, but I cannot press another button (like the cross or the cancel button). I still can move the window, but that's it. Any ideas what's wrong? |
5个回答
不幸的是我做不到。
在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Unfortunatly I cannot do that. View solution in original post |
@lukileu,
您可以尝试重新包装或重新创建项目吗? 我认为问题不会一致。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @lukileu, Can you try to repackage or recreate the project? I dont think the issue will be consistent. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
嗨,
我已经试过了。 我第二次设置整个项目,结果相同。 另外,我试图直接编辑包的生成的xml文件。 然后项目仍将打开,但当Vivado尝试打开文件时,他将永远加载。 以上来自于谷歌翻译 以下为原文 Hi, I already tried that. I set up the whole project a second time, with the same result. Alternativly I tried to edit the generated xml file of the package directly. Then the project would still open, but when Vivado tries to open the file, he is loading forever. |
@lukileu,
您可以共享vivado存档项目来调试问题吗? --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @lukileu, Can you share the vivado archive project to debug the issue? --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-19 16:06 , Processed in 0.986678 second(s), Total 75, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
