大家好,
我把Ubuntu放在第7代Intel NUC(NUC7i7BNH)上。 从16.04开始,一切都很好,直到上周左右。 然后有线以太网停止工作(无线很好)。 dmesg显示以下内容: [5.713374] e1000e 0000:00:1f.6:启用设备(0000 - > 0002) [5.713559] e1000e 0000:00:1f.6:中断节流率(ints / sec)设置为动态保守模式 [6.732187] e1000e:0000:00:1f.6的探测失败,错误-2 经过大量的谷歌搜索和故障排除后,我尝试了以下内容: 1)升级到18.04 2)禁用局域网唤醒 3)禁用安全启动 4)将BIOS降级到其工作的版本 5)使用intels更新了e1000驱动程序 这些都不起作用。 其他人有任何想法/遇到过这种情况吗? 我正试图解决这个问题。 哦,lshw -c网络: *-网络 描述:无线接口 产品:无线8265/8275 供应商:英特尔公司 物理id:0 公交信息:pci @ 0000:3a:00.0 逻辑名称:wlp58s0 版本:78 serial:a0:c5:89:fc:71:64 宽度:64位 时钟:33MHz 功能:pm msi pciexpress bus_master cap_list ethernet物理无线 配置:broadcast = yes driver = iwlwifi driverversion = 4.15.0-34-generic firmware = 34.0.1 ip = 10.0.0.103 latency = 0 link = yes multicast = yes wireless = IEEE 802.11 资源:irq:131内存:dc200000-dc201fff * - 网络未经授权 描述:以太网控制器 产品:以太网连接(4)I219-V 供应商:英特尔公司 身份证:1f.6 公交信息:pci @ 0000:00:1f.6 版本:21 宽度:32位 时钟:33MHz 功能:pm msi cap_list 配置:延迟= 0 资源:内存:dc300000-dc31ffff 以上来自于谷歌翻译 以下为原文 Hi all, I put Ubuntu on a 7th generation Intel NUC (NUC7i7BNH). Started with 16.04 and everything was fine until last week or so. Then the wired ethernet stopped working (wireless is fine). dmesg shows the following: [ 5.713374] e1000e 0000:00:1f.6: enabling device (0000 -> 0002) [ 5.713559] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode [ 6.732187] e1000e: probe of 0000:00:1f.6 failed with error -2 After lots of Googling and troubleshooting I've tried the following: 1) upgrading to 18.04 2) disabling wake on lan 3) disabling secure boot 4) downgrading bios to version where it was working 5) using intels updated e1000 drivers None of these are working. Anyone else have any ideas/have run into this? I'm at my wit's end trying to fix this. Oh, lshw -c network: *-network description: Wireless interface product: Wireless 8265 / 8275 vendor: Intel Corporation physical id: 0 bus info: pci@0000:3a:00.0 logical name: wlp58s0 version: 78 serial: a0:c5:89:fc:71:64 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless configuration: broadcast=yes driver=iwlwifi driverversion=4.15.0-34-generic firmware=34.0.1 ip=10.0.0.103 latency=0 link=yes multicast=yes wireless=IEEE 802.11 resources: irq:131 memory:dc200000-dc201fff *-network UNCLAIMED description: Ethernet controller product: Ethernet Connection (4) I219-V vendor: Intel Corporation physical id: 1f.6 bus info: pci@0000:00:1f.6 version: 21 width: 32 bits clock: 33MHz capabilities: pm msi cap_list configuration: latency=0 resources: memory:dc300000-dc31ffff |
2个回答
您好rlippmann,感谢您加入我们的英特尔®社区。我们了解您遇到的英特尔®NUC套件NUC7i7BNH的以太网连接(I219-V)存在问题。在这种情况下,请考虑英特尔®不测试和验证
英特尔®NUCon Linux *,但是我们知道许多NUC用户正在使用许多不同的Linux发行版.Intel®建议你查看Linux的Ubuntu *网站和论坛,以获得有关此安装问题的同行帮助。你的问题是 体验似乎是由于驱动程序兼容性问题,因为您的设备唯一支持的操作系统是Windows®10,64位*(Home和Pro版本),您可以在这里查看。但是,您可以尝试我们的英特尔®以太网适配器完整驱动程序 包。 并非所有版本的Windows *,Linux *或FreeBSD *都支持所有英特尔®以太网适配器和英特尔®以太网控制器,因此我们不保证这些驱动程序会对您的问题产生影响。我希望这有助于.Regards, 迭戈S. 以上来自于谷歌翻译 以下为原文 Hello rlippmann, Thank you for joining our Intel ® Community. I understand that you are experiencing issues with the Ethernet Connection (I219-V) of your Intel® NUC Kit NUC7i7BNH. In this case, please consider that Intel® does not test and validate Intel® NUC on Linux*, however we know that a lot of NUC owners are using is successfully on many different Linux distros. Intel ® suggests you check Linux’s Ubuntu* website and forums for peer assistance with this installation issue. The issue that you are experiencing seems to by a driver compatibility issue, since the only supported OS for your unit is Windows® 10, 64-bit*(Home and Pro editions) as you can check here. However, you can try our Intel® Ethernet Adapter Complete Driver Pack. Not all Intel® Ethernet Adapters and Intel® Ethernet Controllers are supported under every version of Windows*, Linux*, or FreeBSD*, so we do not guarantee that these drivers will have an impact on your issue. I hope this helps. Regards, Diego S. |
jerry1978 发表于 2018-10-26 17:40 我已经发布到ubuntu论坛没有回复。 正如我在原帖中所述,我已经下载并安装了最新的intel linux驱动程序,并从源代码编译它们,并在日志文件中出现相同的错误。 我相信这是一个BIOS问题,因为一切正常,直到我更新到8月24日版本。 现在,即使降级BIOS也无法解决问题。 以上来自于谷歌翻译 以下为原文 I've already posted to ubuntu forums with no response. As I've stated in my original post, I have downloaded and installed the latest intel linux drivers and compiled them from source with the same resulting error in the log files. I believe this is a BIOS issue as everything worked fine until I updated to the August 24th version. Now, even downgrading the BIOS doesn't fix it. |
只有小组成员才能发言,加入小组>>
238浏览 0评论
GMT+8, 2024-3-29 23:50 , Processed in 0.501623 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
