大家好。
我是一名大学生,目前正在使用ADS作为我的学期项目。 目标是设计具有特定规格的微波LNA。 我目前正在尝试匹配输入以获得最大可用增益。 我用增益和噪音圈来表达我的观点。 该点对应于18.5 + j 22.75(非标准化)。 我的终点都是50欧姆。 由于我是ADS的新手,我开始以我所知道的唯一方式开始这样做:我建立了一个带有两个50欧姆终端的新原理图。 在两者之间,我已经放置了一个微带线的L网络,Z0 = 50.他们的线路要调整,使得Zin变为18.5 + j 22.75。 我使用史密斯图表实用程序从50映射到阻抗,并使用linecalc(使用我的基板模型)来计算我的线长和开放存根的长度。 但是当我将这些值放在网络中并模拟找到Zin时,我得不到18.5 + j 22.75。 我希望这很清楚。 我附上了我的文件供您查看。 以上来自于谷歌翻译 以下为原文 Hello everyone. I am a college student currently using ADS for my term project. The objective is to design a microwave LNA with certain specs. I am currently trying to match the input for max available gain. I used the gain and noise circles to pick my point. The point corresponds to 18.5 + j 22.75 (non-normalized). My terminations are all 50 Ohm. Since I am new to ADS, I started doing this the only way I know: I build a new schematic with two 50 Ohms terminations. In between, I have placed an L network of microstrip lines with Z0 = 50. Their lines are to be adjusted such that Zin becomes 18.5 + j 22.75. I used the smith chart utility to map from 50 to that impedance and used linecalc (with my substrate model) to calculate the lengths of my line length and open stub. But when I place these values in the network and simulate to find Zin, I do not get 18.5 + j 22.75. I hope this is clear enough. I attached my files for your viewing. 附件
4个回答
更新:我的规格是:增益> 15 dB,NF我已经执行了输入匹配,然后共轭匹配输出。 但是最终匹配电路的NF总是比我选择的点(在增益/噪声圆上)高得多。 例如,在更新的附件中,我选择的点数为0.3 NF,但在匹配后,我得到的NF约为1.你能帮我吗? 以上来自于谷歌翻译 以下为原文 Update: My specs are: Gain > 15 dB, NF < 1.2 dB at 2.45 GHz I have performed the input matching, then conjugate matched the output. But the final matched circuit always has a NF that is much higher than what the point I selected (on the gain/noise circles) corresponded to. For example, in the updated attached file, my selected point had a 0.3 NF, yet in after matching, I get a NF of about 1. Can you please help me here? 附件
取名字太难 发表于 2018-10-25 16:42 唯一合乎逻辑的结论是我没有正确匹配我的源阻抗与gamma_s,这就是为什么我没有得到我想要的NF。 为了匹配Z0和Zs(Zs从Gain / Noise圈子中选择),我基本上创建了一个新的原理图,带有两个50欧姆终端和一个MLIN L匹配网络。 我使用s参数调色板中的Zin工具并将其设置为Zin1 = Zin(S11,portZ1)。 然后我调整Zin读Zs。 最后,我将获得的线长放入我的最终原理图中作为输入匹配网络。 我这样做了吗? 以上来自于谷歌翻译 以下为原文 The only logical conclusion is that I am not properly matching my source impedance to gamma_s, which is why I am not getting the NF I wanted. To match Z0 to Zs (Zs optained from Gain/Noise circles) I basically create a new schematic, with two 50 Ohms terminations, and a MLIN L matching network. I use Zin tool from s parameter palette and set it to Zin1 = Zin(S11,portZ1). Then I tune such that Zin reads Zs. Finally I place the obtained line lengths into my final schematic as the input matching network. Am I doing this correctly? |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2574 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1557 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-18 08:23 , Processed in 1.026103 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
