IntelCorporationIntegratedGraphicsFail
嗨,我目前正在设置我的PC(Win7 sp1)与英特尔(R)高清显卡与1x DELL显示器和1x三星LED电视(UA55NU7100)。 1. DELL监视器通过DVI-I连接到VGA(能够输出1920x1080分辨率) 2.电视通过DVI-I连接到HDMI(PC无法检测到电视,反之亦然) 我尝试卸载Intel(R)HD Graphics,现在PC能够检测电视并输出低分辨率到电视。 所以我得出结论显示驱动程序无法支持? 寻找英特尔提供的解决方案...... 使用英特尔系统支持实用程序生成附加的Win7sp1.txt文件。 谢谢& 问候, tkew Win7sp1.txt.zip 5.7 K. 以上来自于谷歌翻译 以下为原文 IntelCorporationIntegratedGraphicsFail Hi, I currently setting up my PC (Win7 sp1) with Intel(R) HD Graphic with 1x DELL monitor and 1x Samsung LED TV (UA55NU7100). 1. DELL monitor connected via DVI-I to VGA (able to output 1920x1080 resolution) 2. TV connected via DVI-I to HDMI (PC failed to detect TV, vice versa) I tried uninstall the Intel(R) HD Graphics, now PC able to detect TV and output low resolution to TV. So i make a conclusion the displays driver is unable to support? looking for a solution provide by Intel... Attached Win7sp1.txt file generate using Intel System Support Utility. Thanks & Regards, tkew
3个回答
您好tkew感谢您加入英特尔®社区。
请允许我与您分享,虽然作为单根电缆,但无法连接DVI-I到HDMI®。 这是由于此连接存在DVI-I或HDMI®无法处理的信号。 请记住,英特尔不建议使用任何类型的适配器。 这是因为我们无法测试所有这些,所以我们不能保证它们能够正常工作。 此致Leonardo C.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello tkew Thank you for joining the Intel® community. Allow me to share with you that the in connection DVI-I to HDMI® is not possible though as a single cable. This is due to this connection there are signals that either the DVI-I or the HDMI® do not handle. Please bear in mind that Intel® does not recommend the use of any kind of adapters. This is because we cannot test all of them, so we cannot guarantee that these are going to work. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation |
您好tkewI正在检查您的案例,并想知道您是否需要进一步的帮助。
如果是这样,请不要犹豫回复.Regards,Leonardo C.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello tkew I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-25 19:35 亲爱的莱昂纳多, 指出。 我正在考虑添加显卡作为解决方案。 问候,tkew 以上来自于谷歌翻译 以下为原文 Dear Leonardo, Noted. I am considering adding graphic card as solution. Regards, tkew |
只有小组成员才能发言,加入小组>>
237浏览 0评论
GMT+8, 2024-3-29 13:09 , Processed in 0.771577 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
