你好…
我正在尝试追踪电容器数据表。 电容器有字母数字标记,如下所示: 100 10V UT ... 它是黑色和灰色的。 请保留照片: 这是我收到的带有盖子的电机驱动器的原理图。 ... 这是我用相机拍的最好的照片: 如果你能找到这个项目,我正在寻找这个特殊型号的帽子的数据表。 赛斯 以上来自于谷歌翻译 以下为原文 Hello… I am trying to track down a capacitor datasheet. The capacitor has alpha-numeric markings like so: 100 10v UT … It is black and gray. Please hold for the photo: That is the schematic I received w/ the motor driver that has the cap on it. … and here is the best photo I can get w/ my camera: If you can find this item, I am searching for a datasheet of this particular model of cap. Seth |
5个回答
你好再一次,
我发现,通过制造商。 这个特定的电路板,类似的数据表,但他们无法得到我正确的数据表b / c他们的记录不是那么高的标准。 看这里: 如果这有帮助,请告诉我。 我会继续搜索。 赛斯 附: 我基本上试图弄清楚电容和L298芯片是否可以处理我的12v 3.3Ah电池供电。 以上来自于谷歌翻译 以下为原文 Hello Once More, I found, via the mfg. of this specific board, a similar datasheet but they cannot get me the correct datasheet b/c their records are not all that up-to-par. See here: If this helps, please let me know. I will continue to search. Seth P.S. I am basically trying to figure out if the capacitor and L298 chip can handle my 12v 3.3Ah battery supply. |
制造商是否为您提供了部件号?
盖帽上的标记似乎与我所展示的Nichicon数据表上的标记不符。 - 罗伯特· 以上来自于谷歌翻译 以下为原文 Did the manufacturer give you a part number? The markings on the cap do not seem to match the markings on the Nichicon data sheets I am showing. -Robert |
你好,
不,先生......制造商。 没给我一个零件号。 我列出的Nichicon数据表是他们给我的补充。 他们没有保留他们所生产的产品的良好记录,这个电容器是一个缺失的项目,只是偶然地,最终我的驱动程序。 赛斯 以上来自于谷歌翻译 以下为原文 Hello, No sir…the mfg. did not give me a part number. The Nichicon datasheet I have listed is what they gave me as a supplement. They did not keep good records of what they produced and this capacitor is a missing item that just, by chance, ended up on my driver. Seth |
赛斯,
不幸的是,我没有在我们的系统中显示匹配任何标记。 如果制造商不知道谁制造了盖帽,最好用已知的盖子更换,以确保符合规格。 - 罗伯特· 以上来自于谷歌翻译 以下为原文 Seth, Unfortunately I am not showing the marking matching anything in our system. If the manufacturer does not know who made the cap it may be best to replace with a known cap to ensure the specifications are met. -Robert |
再次问好,
好的,先生......谢谢你的尝试。 赛斯 以上来自于谷歌翻译 以下为原文 Hello Again, Okay sir…thank you for trying. Seth |
只有小组成员才能发言,加入小组>>
3289 浏览 3 评论
207浏览 1评论
GMT+8, 2024-4-25 01:23 , Processed in 0.554264 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
