在UM1052中(STM32F0x / F100xx / F103xx / F2xx / F30x / F4xx
PMSM单/双FOC SDK v3.4)它写成: ''电机控制软件开发套件(STSW-STM32100) 设计用于STM32F0x / F100xx / F103xx,STM32F2xx, STM32F302xB / C,STM32F303xB / C和F4xx微控制器。软件库 实现三相永磁体的磁场定向控制(FOC)驱动 同步电动机(PMSM),表面安装(SM-PMSM)和内部(I-PMSM)。 描述了配备有编码器或转速计发生器的AC感应电动机的控制 在UM0483用户手册中。 但是看看UM0483(STM32F103xx 交流感应电机IFOC软件库V1.0)我发现这个pdf使用的是与UM1052中使用的库不同的库。 我只从ST.com STM32 PMSM FOC LIB v3.4 WEB下载;它具有与UM0483中描述的文件夹结构不同的文件夹结构。 我搜索了STM32 FOC Firmware Libraries v1.0,它有ACIM控制方法但是徒劳无功。 有人能告诉我固件标题''STM32 PMSM FOC LIB v3.4 WEB'是否可以控制ACIM电机? 其他库''STM32F103xx交流感应电机IFOC软件库V2.0'在哪里? 同样的UM1052说我可以在st.com上找到它,但我找不到它。 以上来自于谷歌翻译 以下为原文 In UM1052(STM32F0x/F100xx/F103xx/F2xx/F30x/F4xx PMSM single/dual FOC SDK v3.4) it is written: ''Motor Control Software Development Kit (STSW-STM32100) designed for and to be used with STM32F0x/F100xx/F103xx, STM32F2xx, STM32F302xB/C, STM32F303xB/C and F4xx microcontrollers.The software library implements the Field Oriented Control (FOC) drive of 3-phase Permanent Magnet Synchronous Motors (PMSM), both Surface Mounted (SM-PMSM) and Internal (I-PMSM). The control of an AC induction motor equipped with encoder or tacho generator is described in the UM0483 user manual. But looking in UM0483 (STM32F103xx AC induction motor IFOCsoftware library V1.0) I have discovered that this pdf uses a different library from the one used in UM1052. I have only downloaded from ST.com STM32 PMSM FOC LIB v3.4 WEB ; which has a folder structure different form the one described in UM0483 . I searched for STM32 FOC Firmware Libraries v1.0 which has ACIM control methods but in vain . Can someone tell me if the firmware intitled ''STM32 PMSM FOC LIB v3.4 WEB '' can controll ACIM motors? And where is the other library ''STM32F103xx AC induction motor IFOC software library V2.0 '' ??? The same UM1052 says I can find it on st.com, but I can't find it. |
3个回答
Ciao ionut.fasoola
名称中所述的STM32 PMSM FOC Lib仅为永磁电机(PMSM =永久磁铁同步电机)。 不幸的是,STM32F103xx交流感应电机IFOC软件库V2.0已经不在网络中,因此如果您需要,您必须直接向最近的ST本地支持人员询问。 感谢您的报告,现在文档已更新。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao ionut.fasoola The STM32 PMSM FOC Lib as stated in the name is only of permanet magnet motor (PMSM = pemanent magnet syncronous motors). Unfortunately the STM32F103xx AC induction motor IFOC software library V2.0 is no more in the web so if you require it you have to ask directly to your nearest ST local support. Thank you for your report, now the documentation has been updated. Ciao Gigi |
谢谢你的回复,吉吉
另一个问题:是否有使用STM32的交流感应电机控制库? 最好的祝福 以上来自于谷歌翻译 以下为原文 Thanks for your reply,Gigi Another question : is there a library for AC induction motors control using STM32? Best regards |
Ciao ionut.fasoola
目前唯一的FW是STM32F103xx交流感应电机IFOC软件库V2.0,如上所述,您必须直接向最近的ST本地支持人员询问。 再见 以上来自于谷歌翻译 以下为原文 Ciao ionut.fasoola At the moment the only FW is the STM32F103xx AC induction motor IFOC software library V2.0 and as discussed you have to ask directly to your nearest ST local support. Ciao |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1445 浏览 1 评论
2113 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1510 浏览 1 评论
2822 浏览 6 评论
5238 浏览 21 评论
361浏览 4评论
536浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
278浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
604浏览 3评论
509浏览 3评论
GMT+8, 2024-4-24 03:50 , Processed in 0.686185 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
