嗨,我们正在尝试获取屏幕上显示的标准偏差和平均值。
过程:重置示波器设置显示设置测量设置统计(“MEAS:STAT:MCO 10”)设置返回数据(“MEAS:STAT ON”)返回测量类型,curr,mean,min,max,stdev和计数值查询 仪器(“MEAS:RES?”)无论我们如何设置测量统计数,查询中获取的数据都是从一个继续无限增加的计数值计算出来的。 以上来自于谷歌翻译 以下为原文 Hi, We are trying to acquire the standard deviation and mean values displayed on the screen. process: reset scope setup display setup measurements setup statistics ("MEAS:STAT:MCO 10") setup returned data( "MEAS:STAT ON") to return meas type, curr, mean, min, max, stdev, and count values query instrument ("MEAS:RES?") no matter what we set the measurement stat count to it, the data acquired in the query is computed off a count value that continues to increment infinitely. |
3个回答
我相信“MEAS:STAT:MCO 10”意味着统计最近10次收购,而不是前10次。有点像平均运行。
以上来自于谷歌翻译 以下为原文 I believe "MEAS:STAT:MCO 10" means take the statistics of the last 10 acquisitions, rather than the first 10. Kind of like a running average. |
这就是我需要的(过去10的平均运行)。 通过远程接口拉出的测量值具有不断增加的计数值(MCO编号不会将计数限制在设定值)。 似乎MCO值仅设置屏幕上显示的统计测量值。 这使得拉动统计数据远程无用。 以上来自于谷歌翻译 以下为原文 that is what i need (a running average of the last 10). the measurements pulled through the remote interface have an ever increasing count value (the MCO number doesn't cap the count at the set value). it seems the MCO value only sets what's displayed on the screen for stat measurements. this makes pulling stats remotely useless. |
jingfu888 发表于 2018-10-24 09:42 你是对的,:MEAS:结果? 命令不服从最大计数(min,max,mean,std-dev与屏幕版本不匹配)。 对不起,我应该在回复之前先检查一下。 好像是个bug。 以上来自于谷歌翻译 以下为原文 You are right, the :MEAS:RESULTS? command doesn't obey the maximum count (the min, max, mean, std-dev doesn't match the screen's version). Sorry, I should have checked first before replying. Seems like a bug. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 08:14 , Processed in 1.190246 second(s), Total 75, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
