硬件:PIC24FJ256GB106MRF24WG0MAI有一个较老的项目,我正在尝试改变自定义网页。看起来网页目录需要转换成一个MPFS2图像,查看当前的MPFS2IMP.O,它的著作权为2012,所以我想我需要软件在今年的范围内,因为我所尝试的到目前为止…将生成MPFS2映像,但该文件的大小将是双倍的,在MPLAXXError编译我的项目时,我将得到错误:“在通用的包含文件中没有指定的处理器ID。需要下载新的ASM30汇编程序吗?我不知道我需要什么软件来创建正确的MPFS2图像,如果任何人有任何想法,或者你需要更多的信息,请让我知道。谢谢!
以上来自于百度翻译 以下为原文 Hardware: PIC24FJ256GB106 MRF24WG0MA I have an older project and I'm trying to change custom webpages. It looks like the webpage directory needs to be converted to a MPFS2 Image looking at the current MPFS2Image.o that works its got a copyright of 2012 so I would assume I need software in the range of this year because what I have tried so far... will generate a MPFS2 Image but the file will be double in size and I will get error upon compiling my project in MPLAB X Error: "Processor ID not specified in generic include files. New ASM30 assembler needs to be downloaded?" I don't know what software I need to create a correct MPFS2 Image if anyone has any ideas or you need more info please let me know. Thanks! |
2个回答
我使用了来自和谐V2.05.01的MPFS2.JAR以及我在Github上可以找到的随机变量。我也找不到任何方法来下载一个Microchip来尝试旧版本。(我真的必须安装每个和声版本才能获得.jar文件吗???)
以上来自于百度翻译 以下为原文 I've used the mpfs2.jar from Harmony v2.05.01 and also random ones I could find on github. I also can't find any way to get to a microchip downloads archive to try older versions. (Do I really have to install each Harmony version just to get a .jar file???) |
你应该在MLA副本中寻找转换器不和谐。尝试MLA的最后版本,并从那里向后工作。
以上来自于百度翻译 以下为原文 You should be looking for the converter in a copy of MLA not in Harmony. Try the last version of MLA , and work backwards from there. |
只有小组成员才能发言,加入小组>>
4824 浏览 9 评论
1829 浏览 8 评论
1747 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2954 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2059 浏览 5 评论
460浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
362浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1797浏览 0评论
GMT+8, 2024-4-24 09:20 , Processed in 1.154770 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
