你好!
我在这里遵循为imx233 Olimex板编译内核的指南:https://eewiki.net/display/linuxonARM/iMX233-OLinuXino 我制作了所有内容,将其加载到SD卡上并启动了我的主板。 在启动期间,我得到一个超时:“超时等待设备dev-mmcblk0p2 xc2 xa0.device。” 我检查了fstab并确认它有“/ dev / mmcblk0p2 / auto errors = remount-ro 0 1” 任何想法可能有什么不对? 谢谢 完整日志在这里作为bootup.txt(新用户无法发布文件):https://www.dropbox.com/s/xoq33vl8x91578l/bootup.txt?dl=0 以上来自于谷歌翻译 以下为原文 Hello! I was following the guide for compiling the kernel for the imx233 Olimex boards here: https://eewiki.net/display/linuxonarm/iMX233-OLinuXino I built everything, loaded it onto the SD card and booted up my board. During startup I get a timeout: “Timed out waiting for device dev-mmcblk0p2xc2xa0.device.” I checked fstab and confirmed that it has “/dev/mmcblk0p2 / auto errors=remount-ro 0 1” Any ideas what may be wrong? Thanks full logs here as bootup.txt (new users can’t post files): https://www.dropbox.com/s/xoq33vl8x91578l/bootup.txt?dl=0 |
10个回答
嗨凯文,
我真的很惊讶imx23甚至支持SDXC: [2.330000] mmc0:主机不支持读取只读开关,假设写入启用 [2.350000] mmc0:地址aaaa的新高速SDXC卡 [2.420000] mmcblk0:mmc0:aaaa SL64G 59.5 GiB [2.480000] mmcblk0:p1 p2 这很酷。 可悲的是我的所有imx23都在工作,所以直到明天我都无法查看。 但是你可以仔细检查你的/ etc / fstab设置吗? 因为它接近登录提示。 编辑:好的,我看到你仔细检查了你的fstab设置。 您使用sfdisk和mkfs.ext4版本构建microSD卡的主机是什么操作系统? 问候, 以上来自于谷歌翻译 以下为原文 Hi Kevin, I’m really surprised the imx23 even supports SDXC: [ 2.330000] mmc0: host does not support reading read-only switch, assuming write-enable[ 2.350000] mmc0: new high speed SDXC card at address aaaa[ 2.420000] mmcblk0: mmc0:aaaa SL64G 59.5 GiB [ 2.480000] mmcblk0: p1 p2That’s pretty cool. Sadly all my imx23’s are at work, so i can’t check this out till tomorrow. But can you double check your /etc/fstab setting? as it did get close to the login prompt. edit: okay i see you double checked your fstab settings. What OS was your host that you built the microSD card with, sfdisk and mkfs.ext4 versions? Regards, |
嗨罗伯特,
是的,我在询问之前搜索了我的问题并看到了你以前的答案(虽然对于比格犬骨头)! 使用Ubuntu 16.04主机,来自util-linux 2.27.1的sfdisk,mkfs.ext4 1.42.13 谢谢 以上来自于谷歌翻译 以下为原文 Hi Robert, Yep, I googled my question before asking and saw your previous answers (for beagle bones though)! Using Ubuntu 16.04 host, sfdisk from util-linux 2.27.1, mkfs.ext4 1.42.13 Thanks |
嗨凯文,
这种组合应该有效。 您有机会获得SDHC卡吗? 我挖了我的硬件堆,发现了一个imx23。 但我唯一的SDXC卡是'ro',不再采用格式... 这是我的启动日志,带有16GB microSD: imx23-v4.9.x-boot.log(16.9 KB) debian @ arm:〜$ dmesg | grep mmc [0.000000]内核命令行:console = ttyAMA0,115200 root = / dev / mmcblk0p2 ro rootfstype = ext4 rootwait fixrtc [2.080000] 80010000.ssp未找到供应vmmc,使用虚拟调节器 [2.150000] mxs-mmc 80010000.ssp:已初始化 [2.300000] mmc0:主机不支持读取只读开关,假设写入启用 [2.320000] mmc0:地址e624的新高速SDHC卡 [2.360000] mmcblk0:mmc0:e624 SU16G 14.8 GiB [2.400000] mmcblk0:p1 p2 [2.540000] EXT4-fs(mmcblk0p2):已安装的文件系统,具有有序数据模式。 选择:( null) [10.410000] EXT4-fs(mmcblk0p2):重新安装。 选择:errors = remount-ro debian @ arm:〜$ uname -r 4.9.14-imxv5-R1 问候, 以上来自于谷歌翻译 以下为原文 Hi Kevin, That combination should have worked. Any chance do you have an SDHC card? I dug thru my hardware pile and found an imx23. But my only SDXC card is ‘ro’ and no longer taking a format… Here’s my boot log, with a 16GB microSD: imx23-v4.9.x-boot.log (16.9 KB) debian@arm:~$ dmesg | grep mmc[ 0.000000] Kernel command line: console=ttyAMA0,115200 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc[ 2.080000] 80010000.ssp supply vmmc not found, using dummy regulator[ 2.150000] mxs-mmc 80010000.ssp: initialized[ 2.300000] mmc0: host does not support reading read-only switch, assuming write-enable[ 2.320000] mmc0: new high speed SDHC card at address e624[ 2.360000] mmcblk0: mmc0:e624 SU16G 14.8 GiB [ 2.400000] mmcblk0: p1 p2[ 2.540000] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)[ 10.410000] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-rodebian@arm:~$ uname -r4.9.14-imxv5-r1Regards, |
嗨罗伯特,
SDHC卡仍然存在同样的问题。 我注意到日志顶部报告了CRC错误: CPU:飞思卡尔i.MX23 rev1.4,454 MHz BOOT:SSP SD / MMC#0 DRAM:64 MiB 没有arch特定的invalidate_icache_all可用! __led_init:请求GPIO59失败! MMC:MXS MMC:0 ***警告 - 错误的CRC,使用默认环境 什么CRC检查失败? 我的rootfs校验和与您站点上的校验和匹配。 内核已损坏? 应该注意的是,我尝试使用4.10和4.9内核并且遇到了同样的问题。 以上来自于谷歌翻译 以下为原文 Hi Robert, Still have the same problem with a SDHC card. I noticed a reported CRC error at the top of the logs: CPU: Freescale i.MX23 rev1.4 at 454 MHzBOOT: SSP SD/MMC #0DRAM: 64 MiBNo arch specific invalidate_icache_all available!__led_init: failed requesting GPIO59!MMC: MXS MMC: 0*** Warning - bad CRC, using default environmentWhat CRC check failed? My rootfs checksum matched the one on your site. Kernel is corrupted? It should be noted that I tried this with both 4.10 and 4.9 kernels and had the same issues. |
等等,我刚检查了你的日志,你有相同的CRC问题,所以我猜这应该不是问题。
以上来自于谷歌翻译 以下为原文 Ah wait, I just checked your logs and you have the same CRC thing, so it shouldn’t be an issue I guess. |
U-Boot将允许您为将来的靴子保存环境(也就是更改/添加)。
在我们的例子中,我们只是使用默认设置。 CRC失败,因为该位置是“空白”...... 问候, 以上来自于谷歌翻译 以下为原文 U-Boot will allow you to save the environment (aka changes/additions) for future boots. In our case, we are just using the default settings. The CRC fails, since that location is “blank”… Regards, |
嗯好的。
我唯一改变的是我还包括一些非默认的内核模块。 在PPS下的设备驱动程序的menuconfig中,我选择了该子菜单中的所有模块。 我试图再次编译所有内容而不选择那些,看看是否有所作为 以上来自于谷歌翻译 以下为原文 Hm ok. The only thing I changed is I also include some non-default kernel modules. In menuconfig in Device Drivers under PPS, I selected all the modules in that submenu. I’m trying to compile everything again without selecting those, going to see if that makes a difference |
仍然打破了一切到t。
没有额外的模块加载或任何东西 以上来自于谷歌翻译 以下为原文 Still broken following everything to a t. No extra modules loaded or anything |
你有什么想法吗?
我真的坚持这个。 以上来自于谷歌翻译 以下为原文 Do you have any ideas what’s wrong here? I’m really stuck on this. |
嗨凯文,
没有任何东西。 几天前,当我测试内核映像时,我已经重建了从wiki编写的所有内容。 (我正在使用Debian Buster amd64) sudo sfdisk -v 来自util-linux的sfdisk 2.29.2 sudo mkfs.ext4 -V mke2fs 1。43。4(2017年1月31日) 使用EXT2FS库版本1.43.4 它唯一可能是: https://eewiki.net/display/linuxonarm/iMX233-OLinuXino#iMX233-OLinuXino-CopyRootFileSystem sudo tar xfvp ./debian-*-*-armel-*/armel-rootfs-*.tar -C / media / rootfs / 同步 sudo chown root:root / media / rootfs / sudo chmod 755 / media / rootfs / 在Debian Stretch开发期间,chown和chmod调用成为必需。 但没有它们,它只会破坏默认的用户权限。 问候, 编辑:舌头绑... 以上来自于谷歌翻译 以下为原文 Hi Kevin, No nothing off hand. When i tested the kernel image a few days ago i had rebuilt everything as written from the wiki. (I’m using Debian Buster amd64) sudo sfdisk -vsfdisk from util-linux 2.29.2sudo mkfs.ext4 -Vmke2fs 1.43.4 (31-Jan-2017)Using EXT2FS Library version 1.43.4The only thing it might be: https://eewiki.net/display/linuxonarm/iMX233-OLinuXino#iMX233-OLinuXino-CopyRootFileSystem sudo tar xfvp ./debian-*-*-armel-*/armel-rootfs-*.tar -C /media/rootfs/syncsudo chown root:root /media/rootfs/sudo chmod 755 /media/rootfs/During the Debian Stretch development, the chown and chmod call’s became required. But without them, it only broke the default user permissions. Regards, edit: tongue tied… |
只有小组成员才能发言,加入小组>>
3289 浏览 3 评论
207浏览 1评论
GMT+8, 2024-4-24 09:53 , Processed in 0.521505 second(s), Total 52, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
