任何安装风格都可以。
我不是100%在球场上,我认为这一端是1毫米,但我在FFC的另一端是.5mm soooo ...是的。 思考? 以上来自于谷歌翻译 以下为原文 Any mounting style would be fine. I’m not 100% on the pitch, I think this end is 1mm but I the other end of the FFC is .5mm soooo… yeah. Thoughts? |
8个回答
是否有任何其他信息或照片可能会有所帮助?
以上来自于谷歌翻译 以下为原文 Is there any additional information or photos that may help? |
连接器上是否有标记?
背面是通孔还是表面贴装? 你有配对连接器吗? 它上面有标记吗? 以上来自于谷歌翻译 以下为原文 Are there any markings on the connector? On the back side is it through hole or surface mount? Do you have the mating connector? Are there any markings on it? |
该连接器标记为F9284A,配对标记为F0540A。
它们似乎是30针通孔连接器焊接到固定在2个玻璃纤维板之间的FFC。 我做了一些谷歌搜索,没有任何结果。 我有点难过。 以上来自于谷歌翻译 以下为原文 This connector is marked F9284A and the mating is marked F0540A. They appear to be 30 pin through hole connectors soldered to a FFC pinned between 2 fiberglass boards. I did some google searches which turned up nothing. I’m a little stumped. |
我没有运气确定确切的连接器。
它是一种类似于TX25-30P-8ST-H1E的夹层连接器。 这将与TX24-30R-LT-H1E相匹配 以上来自于谷歌翻译 以下为原文 I am not having any luck identifying the exact connector. It is a Mezzanine connector of sorts similar to TX25-30P-8ST-H1E. This would mate to something like TX24-30R-LT-H1E |
谢谢你的尝试。
我会订购一些样品,看看是否有任何合适的样品。 =] 以上来自于谷歌翻译 以下为原文 Thank you for trying. I’ll order a few samples and see if anything fits together. =] |
实际上,你非常有帮助。
在查看您的建议时,我发现这可能是完全匹配。 https://www.digikey.com/product-detail/en/3m/P50L-030P-A-DA/P50L-030P-A-DA-ND/2340973 我无法在连接器侧看到图像,但其余数据匹配,包括配合高度。 如果您对结果感到好奇,我会告诉您。 =] 以上来自于谷歌翻译 以下为原文 Actually, you were VERY helpful. While looking into your suggestions I found this that I think may be an exact match. https://www.digikey.com/product-detail/en/3m/P50L-030P-A-DA/P50L-030P-A-DA-ND/2340973 I can’t see an image on the connector side but the rest of the data matched including the mating height. If you’re curious about the result I’ll let you know. =] |
那很棒!
让我们知道会发生什么。 我还将传递我们可以使用交配侧图片的评论。 以上来自于谷歌翻译 以下为原文 Thats great! Let us know what happens. I will also pass on the comment that we could use a mating side picture as well. |
只有小组成员才能发言,加入小组>>
3283 浏览 3 评论
204浏览 1评论
GMT+8, 2024-4-20 11:16 , Processed in 0.645789 second(s), Total 97, Slave 86 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
