您好,我有一个FPGA评估板,并为一个访问32个I / O引脚或16个差分对的应用程序制作了扩展板。
目前我将每个引脚的位置硬编码到我的.UCF中,但我意识到我选择它们的方式可能并不理想。 通过约束指南,我找不到一个命令,我可以为其指定一个引脚子集,然后让工具只考虑它们。例如说我有四个可能的I / O引脚,AB1,AB2,AB3和AB4和 内部有四个数据引脚D1,D2,D3,D4。 如何让工具为这些数据引脚选择最佳路由,但只考虑上面的四个AB引脚? 以上来自于谷歌翻译 以下为原文 Hello, I have an FPGA evaluation board and have made an expansion board for an application that accesses 32 I/O pins, or 16 differential pairs. Currently I hardcode the locations into my .UCF for each pin, but I am realizing that the way in which I have chosen them may not be ideal. Looking through the constraints guide I cannot find a command for which I can specify a subset of pins, and then have the tools only consider them. For example say I have four possible I/O pins, AB1, AB2, AB3, and AB4 and internally have four data pins D1, D2, D3, D4. How can I have the tools choose the best possible routing for these data pins, but only consider the four AB pins above? |
7个回答
首先,我会说至少有一种方法可以做你所要求的,但不清楚你会从中获得任何好处。
您的假设是工具比为您的设计选择IO站点更好,而我很少发现情况就是如此。 但是如果你想尝试一下: 方法1) LOC或PROHIBIT芯片的所有其他引脚。 固定在电路板设计中的LOC引脚。 禁止任何其他引脚,以防止它们被选择用于尚未定位的顶级信号。 您已经知道LOC语法。 检查约束指南以了解PROHIBIT语法。 方法2) 使用LOCATE而不是LOC将模块映射到站点组。 这在约束指南中描述了通常的“示例”风格,除非你已经掌握了这个概念,否则没什么意义。 即“示例”更像是语法的BNF定义,如果将它们粘贴到设计中,则会产生错误。 如果你能弄清楚如何使用这种方法,你将获得在这里发布你的UCF的荣誉。 - Gabor 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 First, I'll say that there is at least one way to do what you're asking, but it's not clear that you'll get any benefit from it. Your assumption is that the tools are better than you are at selecting IO sites for your design, while I've rarely found that to be the case. But if you want to try it: Method 1) LOC or PROHIBIT all the other pins of the chip. LOC pins that are fixed in your board design. PROHIBIT any other pins to prevent them from being chosen for top level signals that haven't already been LOCed. You already know the LOC syntax. Check the Constraints Guide for the PROHIBIT syntax. Method 2) Use LOCATE rather than LOC to map a module to a site group. This is described in the constraints guide with the usual style of "example" that makes little sense unless you already grasp the concept. i.e. the "examples" are more like a BNF definition of the syntax and would create errors if you pasted them into a design. If you can figure out how to use this method, you'll get kudos for posting your UCF here. -- GaborView solution in original post |
您应该始终锁定引脚分配。
您的PCB不会改变,因此您的引脚分配也不会改变。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 You should ALWAYS lock down the pin assignments. Your PCB doesn't change, therefore neither can your pin assignments. ----------------------------Yes, I do this for a living. |
啊,让我澄清一下。
我的PCB还有16个输入,来自外部板,因此我可以根据需要更改输入的分配。 更具体地说,我有一个带有32-SMA输出的16通道10 GHz多路分解器评估板。 这些都是我制作的PCB,它采用这些32-SMA输出并将它们路由到我的FPGA评估板所具有的Samtec接口。 因此,我可以自由地改变DMUX中的SMA电缆以满足我的需求。 以上来自于谷歌翻译 以下为原文 Ah let me clarify. My PCB also has 16 inputs, which come from an external board, so I am able to change the assignment of the inputs as I need to. More specifically, I have a 16-channel 10 GHz demultiplexer evaluation board with 32-SMA outputs. These go to a PCB that I have made, which takes these 32-SMA outputs and routes them into the Samtec interface my FPGA evaluation board has. So, I have the freedom to change around the SMA cables out of the DMUX to suit my needs. |
kwiatlab写道:
啊,让我澄清一下。 我的PCB还有16个输入,来自外部板,因此我可以根据需要更改输入的分配。 更具体地说,我有一个带有32-SMA输出的16通道10 GHz多路分解器评估板。 这些都是我制作的PCB,它采用这些32-SMA输出并将它们路由到我的FPGA评估板所具有的Samtec接口。 因此,我可以自由地改变DMUX中的SMA电缆以满足我的需求。 那么,您需要知道使用了哪个输入,对吧? 并且您无法在配置后更改分配; 事实上,你不能在地方和路线后改变它! 所以再次,总是锁定您的引脚分配。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 kwiatlab wrote:Well, you need to know which input is used, right? And you can't change the assignment after configuration; indeed, you can't change it after place and route! So again, ALWAYS lock down your pin assignments. ----------------------------Yes, I do this for a living. |
您的假设是工具比为您的设计选择IO站点更好,而我很少发现情况就是如此。 但是如果你想尝试一下: 方法1) LOC或PROHIBIT芯片的所有其他引脚。 固定在电路板设计中的LOC引脚。 禁止任何其他引脚,以防止它们被选择用于尚未定位的顶级信号。 您已经知道LOC语法。 检查约束指南以了解PROHIBIT语法。 方法2) 使用LOCATE而不是LOC将模块映射到站点组。 这在约束指南中描述了通常的“示例”风格,除非你已经掌握了这个概念,否则没什么意义。 即“示例”更像是语法的BNF定义,如果将它们粘贴到设计中,则会产生错误。 如果你能弄清楚如何使用这种方法,你将获得在这里发布你的UCF的荣誉。 - Gabor 以上来自于谷歌翻译 以下为原文 First, I'll say that there is at least one way to do what you're asking, but it's not clear that you'll get any benefit from it. Your assumption is that the tools are better than you are at selecting IO sites for your design, while I've rarely found that to be the case. But if you want to try it: Method 1) LOC or PROHIBIT all the other pins of the chip. LOC pins that are fixed in your board design. PROHIBIT any other pins to prevent them from being chosen for top level signals that haven't already been LOCed. You already know the LOC syntax. Check the Constraints Guide for the PROHIBIT syntax. Method 2) Use LOCATE rather than LOC to map a module to a site group. This is described in the constraints guide with the usual style of "example" that makes little sense unless you already grasp the concept. i.e. the "examples" are more like a BNF definition of the syntax and would create errors if you pasted them into a design. If you can figure out how to use this method, you'll get kudos for posting your UCF here. -- Gabor |
UCF约束语法支持LOC约束,并带有逗号分隔的值列表。
我不确定它是否适用于I / O引脚,但很可能。 以上来自于谷歌翻译 以下为原文 The UCF constraint syntax supports LOC constraints with a comma seperated list of values. I'm not certain it works with I/O pins but it very well might. |
LOCATE是一个PCF约束,通常不用作映射的输入源。
它可以完成,但它使流程复杂化。 确保用户约束位于原理图开始/原理图结束定义区域之外,否则将被地图覆盖。 以上来自于谷歌翻译 以下为原文 LOCATE is a PCF constraint that's not normally used as an input source to map. It can be done but it complicates the flow. Make sure that the user constraint is outside the Schematic Start/Schematic End defined area or it will be overritten by map. |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-20 22:56 , Processed in 0.960290 second(s), Total 74, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
