回到ISE,
我们可以做的一件事是路由设计,然后为设计生成约束文件, 过去对这些较小的部件有用,看看工具如何连接引脚,给出了一个起点, 我怎么在Vivado做这个? 在vhdl / ip块中输入设计, 模拟和合成,放置/路由,然后如何将生成的引脚转回约束文件? 以上来自于谷歌翻译 以下为原文 Back in ISE, one of the things we could do was route a design, and then generate a constraints file for the design, used to be usefull on these smaller parts to look at how the tools wired up the pins, gave oen a starting point, how do I do this in Vivado ? enter a design in vhdl / ip blocks, simulate and synthesis, place / route, then how do I turn the pin out generated back into a constraints file ? |
3个回答
嗨,
如果要查找“导出端口”功能,请打开已实现的设计,转到文件 - >导出 - >导出IO端口,然后选择.XDC格式将约束写入XDC。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, If you are looking for "export ports" functionality then open Implemented design, go to File --> Export --> Export IO ports and select .XDC format to write constraints in to XDC. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post |
嗨,
如果要查找“导出端口”功能,请打开已实现的设计,转到文件 - >导出 - >导出IO端口,然后选择.XDC格式将约束写入XDC。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, If you are looking for "export ports" functionality then open Implemented design, go to File --> Export --> Export IO ports and select .XDC format to write constraints in to XDC. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2590 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2063 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
400浏览 1评论
1504浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2164浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-29 21:58 , Processed in 0.989096 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
