7个回答
这可能只是一个格式化问题。
检查语法的一种方法是使用包含公式的简单公式框,例如: “curr”+ A并在输出中使用字母数字来查看结果。 另一种方法是启动I / O监视器。 您可能会发现一个简单的缺失空格字符(命令和参数之间至少需要SCPI)。 HTH,Mike Watts 以上来自于谷歌翻译 以下为原文 It's probably just a formatting problem. One way to check your syntax is to use a simple formula box with your formula e.g. "curr " + A and using an alphanumeric on the output to see the result. Another is to start the I/O monitor. What you'll probably find is a simple missing space character ( required between the command and the parameter at least for SCPI ). HTH, Mike Watts |
我怀疑,它可能是一个缺少空间的简单案例 - 请参阅附带的例子。 这不需要任何仪器,并且是检查发送到仪器的语法的快速方法(或者如前所述使用I / O监视器)。 VEE也理解工程乘数,比如0.010n然而,在我发现的例子中我需要强制它成为Enum类型...如果你感兴趣,公式“curr”+ ToReal64(ToString(A)) 输出curr 1.0E-11迈克 以上来自于谷歌翻译 以下为原文 As I suspected, it's probably a simple case of a missing space - please see attached example. This doesn't need any instruments and is a quick way of checking the syntax being sent to an instrument ( or use the I/O monitor as I mentioned before ). VEE understands engineering multipliers too, like 0.010n however, adding that to the example I found I needed to force it from being an Enum type... if you're interested, the formula "curr "+ToReal64(ToString(A)) outputs curr 1.0E-11 Mike 附件
bgvywerq 发表于 2018-10-18 14:17 感谢您的快速回复。 所以我更改为代码行以读取“写文本”curr“+在吉时利6221上它显示输出为纳米放大器,但它显示错误-111标题分隔符错误?任何想法? 以上来自于谷歌翻译 以下为原文 Thanks for the prompt reply. So I changed to line to of code to read "write text "curr"+A on the keithley 6221 it displays output as nano amps as it should but it displays error -111 Header Seperator Error? Any Ideas? |
60user147 发表于 2018-10-18 14:35 空间。 空间。 最后的边疆? 在第二个'r'之后你需要一个空格字符我不知道我怎么解释它。 你正在发送curr1,你需要发送curr 1 Cheers,Mike 以上来自于谷歌翻译 以下为原文 Space. Space. The final frontier? You need a space character after the second 'r' I don't know how else I can explain that. You're sending curr1 and you need to send curr 1 Cheers, Mike |
嘿非常感谢,我没有在你的代码中看到空格。 现在它就像一个魅力。 现在开始获取数据。 以上来自于谷歌翻译 以下为原文 Hey thanks alot, I didn't see the space in your code. Now it works like a charm. Now to start acquiring data. |
感谢您让我们知道。 这是我们不时错过的东西(空间角色)。 干杯,迈克 以上来自于谷歌翻译 以下为原文 Thanks for letting us know. It's something ( a space character ) we all miss out from time to time. Cheers, Mike |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2574 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1557 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-18 07:44 , Processed in 1.065110 second(s), Total 80, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
