嗨,我找不到N2815A电缆的任何文件,所以我的问题是订购哪种电缆(U4201A或N2815A)是正确的,以便与U4164A和DDR3探头(电缆E5845A)或DDR2探头(电缆E5384A / E5826A)一起使用?
一个U4164A模块设置。 命令/地址/数据总线解码器。 订购时应考虑哪种电缆数量? 5992-1057EN U4164A文件提到N2815A电缆是“用于将U4164A连接到90针逻辑分析仪探头的MSO /逻辑分析仪电缆。”将E53xx和E54xx系列90针探头的偶数和/或奇数接头连接到U4164A吊舱的奇数盒中 只对。对于双采样状态模式很有用,不适用于全通道模式)。非常感谢! 以上来自于谷歌翻译 以下为原文 Hi, I could not find any documents for N2815A cable, so my question is which of the cables (U4201A or N2815A) is correct to order for use with U4164A and DDR3 probes (cable E5845A) or DDR2 probes (cable E5384A/E5826A) ? One U4164A module set-up. Command/Address/Data bus decoder. Which quantity of cables should be considered for order ? 5992-1057EN U4164A document mention that N2815A cable is "MSO/logic analyzer cable for connecting U4164A to 90-pin logic analyzer probes. (Connects even and/or odd headers of E53xx and E54xx Series 90-pin probes into odd pod of U4164A pod pair only. Useful for dual-sample state mode, not for full-channel mode). Thank you very much! |
2个回答
不同的Keysight数据表提到了N2815A,但我找不到该产品的任何特定的Keysight WEB页面,也没有找到任何特定的N2815A相关数据表...不清楚,是否真的是Keysight产品对带有总线解码器sw的DDR3双采样模式有帮助
使用,已经可用于订单(也没有价格提到任何地方)? 我正在计划我未来的U4164A订单,考虑到使用Keysight总线解码器sw(E5845A,E5384A / E5826A电缆)的DDR3 / DDR2设计调试,我无法确定订单的正确产品和数量(U4201A或N2815A )。 DDR3-1867 x16(16位或32位总线配置),DDR2-800 x16(32位总线配置)。 PS。 现在我已经使用了2x16962A hw设置,考虑升级到更高的内存速度和未来可能支持的DDR4内存......还有一个U4164A用于16/32位总线宽度配置吗? 以上来自于谷歌翻译 以下为原文 Different Keysight datasheets mention N2815A, but still I could not find any specific Keysight WEB page for this product nor any specific N2815A-related datasheet... Not clear, is it real Keysight product helpful for DDR3 dual-sample mode with bus-decoder sw use, already available for the order (also no prices mention anywhere) ? I'm planning my future order of U4164A, having in mind DDR3/DDR2-designs debug with Keysight bus-decoder sw, (E5845A, E5384A/E5826A cables) and I could not identify correct product and quantity for the order (U4201A or N2815A). DDR3-1867 x16 (16bit or 32 bit bus configuration), DDR2-800 x16 (32 bit bus configuration). PS. Now I have used 2x16962A hw set-up, thinking of upgrade to higher memory speeds and possible future support of DDR4 memories... also is it enough just one U4164A for 16/32 bit bus width configs ? |
毛新宇的儿子王大锤 发表于 2018-10-18 06:38 N2815A是一种专用电缆,适用于带有MSO选件的V系列示波器。 该选项仅支持16个通道。 他们选择构建一根基本上是U4201A的一半的电缆,并且该电缆虽然可以工作,但并未正式支持任何逻辑分析仪卡的任何用途。 它支持与U4431A MIPI D-Phy分析仪一起使用。 正确的答案是:U4201A是正确的电缆。 对于您列出的应用程序,U4201A的正确数量为3.此外,您只需使用一个U4164A就可以使用已列出的DDR2和DDR3应用程序。 人 以上来自于谷歌翻译 以下为原文 The N2815A is a special purpose cable intended for use with the V-Series oscilloscopes with the MSO option. That option only supports 16 channels. They chose to build a cable that was essentially one half of a U4201A, and that cable, while it may work, is not officially supported for any uses with any the the Logic Analyzer cards. It is supported for use with the U4431A MIPI D-Phy analyzer. The correct answer is: The U4201A is the correct cable. The correct quantity of U4201A's for the applications that you have listed is 3. Also, you can get by with just one U4164A for the DDR2 and DDR3 applications that you have listed. Al |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 10:04 , Processed in 1.076929 second(s), Total 67, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
