您好
在映射和布局布线中,我正在收到警告。 我无法删除它。 我该怎么知道这个问题 警告:参数:288 - 信号lane2 / U0 / xst_fifo_generator / gconvfifo.rf / grf.rf / gntv_or_sync_fifo.mem / gdm.dm / Mram_RAM207_RAMD_O无负载。 PAR不会尝试路由此信号。 感谢您 Subash 以上来自于谷歌翻译 以下为原文 HI In the mapping and Place and Route, I am getting warnning . I unable to remove it. I what to know the problem WARNING:Par:288 - The signal lane2/U0/xst_fifo_generator/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.mem/gdm.dm/Mram_RAM207_RAMD_O has no load. PAR will not attempt to route this signal. Thanking you Subash |
4个回答
嗨感谢您的重播。
当我使用分布式FIFO时我得到的警告,当我使用inbuilt-ram进行FIFO时,它被删除了。 在我的数据循环设计中,我在同一设计中使用了8个FIFO。 最后警告被删除。 由于这个警告,我无法看到设计的时间模拟。 RegardsSubash 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi Thanks for replaying . The warning i got when i am using the distributed FIFO and there are removed when i used inbuilt-ram for FIFO. In my design for some loop back of the data, i have used the 8 FIFO's in the same design. Final the warning is removed. Due to that warning i am unable see the time-simulation of the design. Regards Subash View solution in original post |
你好Subhash,
您可以查看此解决方案以及讨论类似问题的线程下方 http://forums.xilinx.com/t5/General-Technical-Discussion/Warning-PAR-288/td-p/86221 如果您希望获得警告说明或更好地附加测试用例,请详细说明您的设计。 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello Subhash, You can check this answer record as well as below thread where similar issue is discussed http://forums.xilinx.com/t5/General-Technical-Discussion/Warning-PAR-288/td-p/86221 Please elaborate more about your design in case you expect the explanation of warning or better attach testcase. Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,
此警告消息清楚地表明消息中的信号没有负载。 检查您的设计是否存在驱动Mram_RAM207_RAMD_O的信号或是否已将其清除。 谢谢, Manusha。 以上来自于谷歌翻译 以下为原文 Hi, This warning message clearly says that the signal in the message has no load. Check in your design whether the signal that is driving the Mram_RAM207_RAMD_O is present or it was trimmed out. Thanks, Manusha. |
嗨感谢您的重播。
当我使用分布式FIFO时我得到的警告,当我使用inbuilt-ram进行FIFO时,它被删除了。 在我的数据循环设计中,我在同一设计中使用了8个FIFO。 最后警告被删除。 由于这个警告,我无法看到设计的时间模拟。 RegardsSubash 以上来自于谷歌翻译 以下为原文 Hi Thanks for replaying . The warning i got when i am using the distributed FIFO and there are removed when i used inbuilt-ram for FIFO. In my design for some loop back of the data, i have used the 8 FIFO's in the same design. Final the warning is removed. Due to that warning i am unable see the time-simulation of the design. Regards Subash |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2589 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2061 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
399浏览 1评论
1502浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2163浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-28 17:01 , Processed in 1.082525 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
