任何人都可以建议一种方法来查看计算机上的8753存储文件。
手动建议是指不再可用的软件包。 谢谢 以上来自于谷歌翻译 以下为原文 Can anybody suggest a way to view 8753 stored files on the computer. The manual suggestion refer to software packages that are not available anymore. Thanks |
3个回答
对于像这样的旧的,不支持的工具,你最好的选择是在列出的雅虎论坛上发布。
该论坛有很多人习惯于处理旧设备,许多人已经提出了解决各种问题的各种解决方案。 这是链接:https://groups.yahoo.com/neo/groups/hp_agilent_equipment/conversations/topics 以上来自于谷歌翻译 以下为原文 For older, out-of-support instruments like this, your best bet is to post this on the Yahoo forum listed. That forum has lots of people that are used to dealing with older equipment and many people have come up with various solutions to various issues. Here is the link: https://groups.yahoo.com/neo/groups/hp_agilent_equipment/conversations/topics |
> {quote:title = out_of_phase写道:} {quote}>任何人都可以建议一种在计算机上查看8753存储文件的方法。
>手动建议是指不再可用的软件包。 >谢谢什么8753 VNA,什么手册,什么过时的软件? 我已经详细阅读了8720D编程手册,而不是8753ES手册,但从未见过任何GPIB命令来从机器上读取文件。 我也没有找到任何复制USER cal kit内容的命令,我觉得这很烦人。 如果要使用Windows从VNA保存数据,那么来自John Miles的vna.exe值得谷歌搜索。 如果你想在Linux上将数据保存到.s1p或.s2p,那么我可以分享我编写的一些Unix代码。 我只在Solaris下测试过,但我希望它可以在Linux下运行。 它需要NI的GPIB卡。 正如jvall所说,雅虎集团是好的。 如果有软件,那么很可能有人可能有副本。 戴夫 以上来自于谷歌翻译 以下为原文 > {quote:title=out_of_phase wrote:}{quote} > Can anybody suggest a way to view 8753 stored files on the computer. > The manual suggestion refer to software packages that are not available anymore. > Thanks What 8753 VNA, what manual, what obsolete software? I have looked in detail at the 8720D programming manual, and less at the 8753ES manual, but have never seen any GPIB commands to read the files off the machine. Neither have I found any command to copy the contents of a USER cal kit, which I find annoying. If you want to save data from the VNA, using Windows, then vna.exe from John Miles is worth Googling. If you want to save data to a .s1p or .s2p on Linux, then I can share some Unix code I wrote. I have only tested under Solaris, but I would expect it to work under Linux. It need a GPIB card from National Instruments. As jvall said, the Yahoo group is good. If there was software, then there's a good chance someone might have a copy. Dave |
只有小组成员才能发言,加入小组>>
2099 浏览 1 评论
1854 浏览 1 评论
1714 浏览 5 评论
2581 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1560 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2258浏览 0评论
GMT+8, 2024-4-25 16:05 , Processed in 1.154615 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
