当我尝试用ICD4将我的程序加载到我的Explorer 16/32板上时,我得到以下错误信息:验证失败。[调试执行]在0x8000,预期0x000 040100,得到0x000 0400 00为什么这个地址范围不能编程?我看了我的配置位和所有的代码保护和写入保护或禁用或关闭。数据表显示在0x8000内存为“保留”。
以上来自于百度翻译 以下为原文 When I try to load a my program onto my Explorer 16/32 board with an ICD4, I get the following error message: Verify failed. [Debug Executive] at 0x800000, expected 0x00040100, got 0x00040000 Why is this address range failing to program? I looked at my config bits and all the code protects and write protects are either disabled or off. Data sheet shows the memory at 0x800000 as "reserved". |
8个回答
船上的皮卡工作正常。我尝试了一个外部拾取3,它没有连接,也没有读取芯片ID。ICD4读取ID,程序内存,然后失败,最后一个验证步骤,我猜调试管理器驻留。
以上来自于百度翻译 以下为原文 The PICKit On Board works fine. I tried an external PICKit 3 and it fails to connect and never reads the chip ID. The ICD4 reads the ID, programs memory, and then fails that last verification step where I'm guessing the debug executive resides. |
如果它是ICD4中的一个bug,我就不会感到惊讶。你在使用最新的MPLAB吗?
以上来自于百度翻译 以下为原文 It wouldn't surprise me if it were a bug in the ICD4. Are you using the latest MPLAB? |
只找到设备支持文件的位置。在ICD4页面上打印好。“不支持这个设备”。把头靠在桌子上。它说ICD3工作,所以我会把我的旧的拉出来。谢谢你的帮助。
以上来自于百度翻译 以下为原文 Just found where the Device Support file is. Fine print on the ICD4 page. "no support for this device". D**n. Pounds head against desk. Well it says the ICD3 works so I'll pull the old one I have out. Thanks for the help. |
我似乎对四月03, 2018号上面提到的问题有相反的看法。具体来说,我可以使用ICD3编程板,但还不能使用机载PICkit。有什么建议吗?我发现了一个不同的帖子来描述我的问题:即成功的ICD3/不成功的车载拾取程序。在这篇文章中,有一个问题被问到跳板是否适合板上的PICkit。反应是他们看不到任何相关的跳板上的PICkit。我同意。
以上来自于百度翻译 以下为原文 I seem to have the inverse problem of what is mentioned above on April 03, 2018. Specifically, I can program the board using an ICD3, but have not yet been able to use the on-board PICkit. Any suggestions? I found a different post describing my problem: i.e., successful ICD3 / unsuccessful on-board PICkit programming. In that post a question is asked if the jumpers are correct for the on-board PICkit. The response was they couldn't see any relevant jumpers for on-board PICkit. I agree. |
MT PikKe:你选择车载PICkit作为调试/编程的工具吗?(在Project属性中)如果是这样的话:错误消息究竟是什么?
以上来自于百度翻译 以下为原文 @ MT SPIKE Did you select the onboard PICkit as your means of debugging/programming? (in the project properties) If so: what exactly is/are the error message(s)? |
DU000 0 000 01,非常感谢您的响应。是的,我确实选择了项目属性中的板上拾取。我相信问题已经解决了。在我提到的“不同的帖子”中,有一个USB电缆可能出现的问题的建议。我尝试了一个不同的USB电缆,它工作了。然而,在回答你的问题,但是,有两个“错误条件”观察,但不是一个错误的消息,以我的回忆。它们是:1)当我点击绿色的“制作和程序设备”向下箭头时,什么都不会发生,也没有错误信息。我刚刚通过拔出USB电缆验证了这一点。2)另一个观察到的“错误条件”是,当我单击“制作和程序设备”箭头时,输出窗口将指示制作和程序序列正在进行,但是没有成功下载。程序实现。屏幕右下角的小窗口连续不断地显示某种程度的进步。无论如何,我现在可以用板上的皮卡来编程。再次感谢。
以上来自于百度翻译 以下为原文 du00000001, Thank you so much for responding. Yes indeed, I did select the on-board PICkit in project properties. I believe the problem is solved. In the "different post" I mentioned, there was suggestion of a possible problem with the USB cable. I tried a different USB cable, and it worked. In answer to your question, however, there were two "Error Conditions" observed, but not an error message to my recollection. They were: 1) When I would click the green "Make and Program Device" down arrow, nothing would happen, and no error message. I just verified that by unplugging the USB cable and indeed that is what happened. 2) The other observed "Error Condition" is that when I clicked the "Make and Program Device" arrow, the Output window would indicate the Make and Program sequence was progressing, however no successful download of the program achieved. The small window at bottom right of screen wold continuously indicate some level of progress, continuously. At any rate, I am now able to program using the on-board PICkit. Thanks again. |
如果在编译和加载成功(HEX文件)之后没有得到通常的消息,或者没有调试器连接,或者-你经历过。从廉价的USB电缆中学习故障,我有一小部分高质量的电缆可靠地完成它们的工作。今天,我的PICkit已经失去了提供目标的设置(也许是因为我使用了一些没有这个选项的PKOB)。…VDD……“花了我3次尝试,直到我意识到什么可能是错的。仍然只有分钟…
以上来自于百度翻译 以下为原文 If you don't get the usual messages after successful compilation and loading (the hex file), either no debugger is connected or - - - you experienced that.Learning from trouble with cheap USB cables, I have a small set of high-quality cables that reliably do their job. If you want something to grin: today, my my PICkit had "lost" the setting to supply the target (maybe because inbetween I had used some PKOB that doesn't have this option). "... VDD ..." Cost me 3 attempts until I realized what really might be wrong. Still only minutes... |
只有小组成员才能发言,加入小组>>
4779 浏览 9 评论
1815 浏览 8 评论
1734 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2941 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2043 浏览 5 评论
423浏览 1评论
1101浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
345浏览 0评论
253浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1751浏览 0评论
GMT+8, 2024-3-29 13:07 , Processed in 1.221293 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
