扫一扫,分享给好友
我很困惑为什么验证校验命令应用到bootloadable闪烁的闪光灯不工作,主要是因为所有的行校验和不正确。经过在造物主的源代码,似乎引导计算为整个应用程序的校验,但通过比较校验值是硬编码的值为Flash计算校验过程设置为一个值。我也试过只设置引导装载程序跳过应用校验和结束程序,但是程序还是通过并运行应用程序校验码,停止运行和停止装置复位并允许采取有限的bootloadable应用控制。附件是我的C表单应用程序供参考。
以太网程序 1兆字节 以上来自于百度翻译 以下为原文 I'm confused on why the verify checksum command for flashing the bootloadable application onto flash isn't working, primarily because all the row checksums are correct. After going through the source code in creator, it seems that the bootloader computes a value for the checksum of the entire application but through the process of comparing the checksum value to what is hard coded value into flash the calculated checksum is set to 0x00. I also tried just setting the bootloader to skip the application checksum and just to end the program, however the program still goes through and runs the application checksum code which halts the operation and stops the device from resetting and allowing the bootloadable application from taking control. Attached is my C# forms app for reference.
2个回答
是否可以将创建者项目附加到引导加载程序和可引导加载程序中
以上来自于百度翻译 以下为原文 Is it possible to attach the Creator project's too for bootloader and bootloadable |
当然,在与PSoC程序员比较校验和之后,计算出的PSoC闪存的校验和为0xC468,相应的HEX文件仅为0xC466。但是我不知道这是怎么回事,因为我的行校验和的每一个都算出了。谢谢你的快速回复。 工作空间05.BultLe01.Zip 227.8兆字节 以上来自于百度翻译 以下为原文 Certainly, also after comparing the checksums with the psoc programmer it turns out the calculated checksum for the psoc flash is 0xC468 and the corresponding hex file is only 0xC466. Im not sure how this can be however because everyone of my row checksums worked out. Thanks for the quick reply.
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-18 14:42 , Processed in 0.616677 second(s), Total 72, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
