你好
因此,我正在尝试启动并运行MQTT客户端,以在intel galileo gen 2板上运行带有mosquitto的TCP / IP,SSL和TLS-PSK。 我一直在关注英特尔管理的本教程(https://www.codeproject.com/Arti ... oT-Sensor-to-the-In)。 我不确定的是如何实现配置指令,如附图所示。 我必须创建一个新的.conf文件或编辑现有文件吗? 或者它与配置文件无关? 只是不确定该做什么或如何实现它们。 任何有关该主题的帮助将不胜感激。 谢谢,马修 directives.PNG 29.6 K. 以上来自于谷歌翻译 以下为原文 Hi There So I am currently trying to get an MQTT client up and running to run TCP/IP, SSL and TLS-PSK with mosquitto on an intel galileo gen 2 board. I have been following this tutorial (https://www.codeproject.com/Arti ... oT-Sensor-to-the-In) administered by Intel. What I am unsure about is how to implement the configuration directives as shown in the attached picture. Must I create a new .conf file or edit an existing one? Or has it got nothing to do with configuration files? Just not sure what to do or how to implement them. Any help on the subject would be appreciated. Thanks,Matthew
1个回答
你好,
感谢您联系英特尔卓越支持。 我们已收到您的请求,很快我们将与您联系并提供更多信息。 最好的祝福, 英特尔客户支持工程师 根据与英特尔的合同 以上来自于谷歌翻译 以下为原文 Hello, Thank you for contacting Intel Premier Support. We have received your request and shortly we will be contacting you with additional information. Best Regards, Intel Customer Support Engineer Under contract to Intel |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-23 19:28 , Processed in 0.411484 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
