虽然该部件可能仍可用于更换8753D固态开关,但部件#5086-7539相当昂贵,价格为4531美元。可以使用是德科技开关型号U9397A,尽管低频仅限于
300 kHz。 8753D的低端为30 kHz。 史蒂夫 以上来自于谷歌翻译 以下为原文 While the part may be still available for replacement of the 8753D Solid-State switch, part # 5086-7539 is is rather pricey at $ 4531. Can the Keysight switch model U9397A be used, although the low frequency is spec'd only down to 300 kHz. The low end of the 8753D is 30 kHz. Steve |
2个回答
有没有人尝试过在8753系列中使用Keysight U9397A固态开关?
如果是这样,低频响应怎么样? 价格怎么样? 以上来自于谷歌翻译 以下为原文 Has anyone tried using the Keysight U9397A Solid-State Switch in the 8753-series ? If so, how was the low frequency response? How about price? |
嗨史蒂夫,
是的,4500美元就是你今天为整套仪器支付的价格。 我很幸运,在ebay买了我的“新”开关,价格为300美元(当我拿到仪器时,老开关已经死了)。 通常价格是大约两倍或更多,没有保修。 如果您真的需要在10-30 kHz的全功率下进行测量,您可以尝试使用早期VNA型号中的同轴继电器。 在8753D中有一个设置可以关闭连续切换,如果您尝试继电器则应该使用该设置,否则它将很快自行消失。 我当时并不知道U9397A,但它似乎是一个不错的选择。 HP /安捷伦曾经有过非常慷慨的规格,所以如果他们说最低300 kHz,它很可能会低于这个。 损失将是更低的功率和更低的动态范围/精度(更多的插入损耗和更差的回波损耗),但在校准包括开关在内的设置时,仍然可以测量至少低至100 kHz。 http://cp.literature.agilent.com/litweb/pdf/5989-7618EN.pdf 最便宜的替代方案(以及验证损坏的开关)是连接同轴电缆以绕过损坏的开关并终止另一条路径,但是您只能通过传统的DUT反转来测量S21和S11或S12和S22。 祝你好运, 博 以上来自于谷歌翻译 以下为原文 Hi Steve, Yes, at $4500 it is about the price you pay today for the full instrument. I was lucky and got my "new" switch at ebay for $300 (old switch dead when I got the instrument). Typically the price is about double or more and no warranty. If you really need to measure with full power at 10-30 kHz you could try with a coaxial relay like in the earlier VNA models. There is a setting in 8753D to turn off continuous switching that you should use if you try the relay or it will quickly destroy itself. I was not aware of the U9397A at the time but it seems to be a good alternative. HP/Agilent used to have quite generous specs so if they say min 300 kHz it will most likely work well below that. The penalty will be lower power and lower dynamic range / accuracy (more insertion loss and worse return loss) but still possible to measure at least down to 100 kHz as you calibrate your setup including the switch. http://cp.literature.agilent.com/litweb/pdf/5989-7618EN.pdf The cheapest alternative (and to verify the broken switch) is to connect a coax to bypass the broken switch and terminate the other path, but then you can only measure S21 and S11 or S12 and S22 by traditional DUT reversal. Good luck, Bo |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 20:03 , Processed in 1.106898 second(s), Total 74, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
