我正在从531xx计数器切换到532xx计数器,我遇到了问题。
基本上,我想通过HPIB设置计数器,但在我准备好接收数据之前让计数器“自由运行”。 对于使用“INIT:CONT 1”和“INIT:CONT 0”命令的53181/53132,这很容易做到。 一旦进入远程模式,53230似乎就会退出自由运行模式,我无法找到一个命令将其恢复为自由运行状态。 我发现的唯一解决方案是通过前面板按钮将计数器置于本地模式。 有没有人知道通过计算机控制使其免费运行的方法? 谢谢 以上来自于谷歌翻译 以下为原文 I'm switching over from 531xx counters to 532xx counters and I've encountered a problem. Basically, I want to set up the counter via HPIB, but then have the counter "free run" until I'm ready to take data. This was very easy to do with a 53181/53132 using "INIT:CONT 1" and "INIT:CONT 0" commands. A 53230 seems to go out of free run mode as soon as it goes into remote mode, and I can't find a command to put it back in free run. The only solution I've found is to put the counter into local mode via the front panel button. Does anyone know a way to make it free run via computer control? Thanks |
3个回答
我有同样的问题。
解决方案是什么? 谢谢! 以上来自于谷歌翻译 以下为原文 I am having the same issue. What was the solution? Thank you! |
有一个“不支持”的命令(“DIAG:LOCAL”)可以工作。 以上来自于谷歌翻译 以下为原文 There is an "unsupported" command ("DIAG:LOCAL") that works. |
谢谢! 我一直试图解决一些不可能的东西,而不能远程回到自由运行模式! 以上来自于谷歌翻译 以下为原文 Thank you! I have been trying to troubleshoot something that is impossible without being able to go back to free run mode remotely! |
只有小组成员才能发言,加入小组>>
2096 浏览 1 评论
1854 浏览 1 评论
1712 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1410浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 11:43 , Processed in 2.310601 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
