我使用PSoC4100M。当从休眠中醒来一段时间,配置为输出的GPIO变低,这对于我的系统来说是不可接受的。我试图在冬眠前冷冻它,但这无济于事。当MCU唤醒时,PIN再次进入三态。在复位过程中是否有保持高逻辑的方法?
以上来自于百度翻译 以下为原文 I use PSOC4100M. When wake up from hibernate for a while one GPIO configured as output goes low, which is not acceptable for my system. I tried to freeze it before go in hibernate but this does not help. While the MCU wakes up, the pin goes in tristate for a while again. Is there any way to keep its high logic during reset |
2个回答
我不确定该设备是否支持在休眠期间唤醒PIN状态,但实现您的需求的一种方式是将PIN配置为开漏驱动器低,然后连接外部上拉以保持引脚状态高。
以上来自于百度翻译 以下为原文 I'm not sure if the device supports saving pin state during wake-up from hibernate, but one way of achieving your requirement could be to configure the pin as open-drain drive low, and then connecting external pull-up to keep the pin state high. |
fbele456 发表于 2018-10-16 19:49 低功耗模式的应用笔记对于Hibernate没有任何关于GPIO保存状态的东西,但是,我从我自己的测试中知道,深度睡眠电源模式将节省/使用GPIO状态。AN92588-为Low Power设计和估计BLE应用的电池寿命 不幸的是,默认的引脚状态是复位上的三态;您可以尝试在TopDebug。CysCH中的一些组件连接,看看这是否会迫使引脚在复位期间保持逻辑高(数字输出引脚的默认状态配置为高,这真的是我唯一能想到的)。 以上来自于百度翻译 以下为原文 The application note for low power modes doesn't have anything on GPIO saving state for hibernate, however, I know from my own testing that the deep-sleep power mode will save/use GPIO states. AN92584 - Designing for Low Power and Estimating Battery Life for BLE Applications The default pin state is tristate on reset unfortunately; You could try wiring some components in the topdesign.cysch to see if that will force the pins to stay logic-high during reset (A digital output pin with the default state configured to high is really the only thing I can think of to try). |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-19 16:55 , Processed in 0.810217 second(s), Total 70, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
