我正在做一个关于图像处理的项目。
我的同事完成了界面部分,经过船上验证后,效果很好。 我正在做algm部分,在我的工作之前,我想为接口部分构建测试平台以查看其内部信号。 但是,在构建测试平台之后,再次实现此前一个项目。 它有一些MAP问题。 如下: 位置:1333 - 具有输入/输出编程的IOB锁定到不支持此类值的Bank 1标准:名称= LVDS_25,VREF = NR,VCCO = 2.50,TERM = NONE,DIR = BIDIR,DRIVE_STR = NRList of 锁定的IOB:MCB1_DDR3_XDQS MCB1_DDR3_XDQS MCB1_DDR3_DQS MCB1_DDR3_DQS 移动测试台后,问题仍然存在。 我不知道。 似乎测试平台改变了一些东西。 ps:在这个项目中,使用了mig core。 芯片是斯巴达-6 谢谢大家。 以上来自于谷歌翻译 以下为原文 I am doing a project about image processing. My colleague finished the interface part, and after verification on board, it works well. I am doing the algm part, before my work, I want to build the testbench for the interface part to see its internal signal. But, after I building the testbench, implement this former project again. It got some MAP problem. as follows: Place:1333 - Following IOB's that have input/output programming are locked to the bank 1 that does not support such values IO Standard: Name = LVDS_25, VREF = NR, VCCO = 2.50, TERM = NONE, DIR = BIDIR, DRIVE_STR = NR List of locked IOB's: MCB1_DDR3_XDQS<0> MCB1_DDR3_XDQS<1> MCB1_DDR3_DQS<0> MCB1_DDR3_DQS<1> after moving the testbench, the problem still exist. I have no idea about it. It seems the testbench changes something in uut. ps: in this project, mig core is used. and the chip is spartan-6 Thank you everybody. |
2个回答
我将它移动到实施论坛,因为它是一个布局错误。
测试平台不应该导致此类问题。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 I'll move it to implementation forum as it's a placer error. A testbench shouldn't cause such kind of issue. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
添加测试平台不应导致实现更改设计。
你确定uut没有被修改,并且所有实现选项仍然与无错误实现相同吗? 如果是这种情况,也许您应该打开一个支持Xilinx技术支持的Webcase。 以上来自于谷歌翻译 以下为原文 The addition of a testbench should not cause the implementation to change for the design. Are you sure the uut has not been modified and that all implementation options are still the same as the error free implementation? If that is the case perhaps you should open a webcase with Xilinx tech support. |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-20 05:30 , Processed in 1.092424 second(s), Total 70, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
