我有一台配备Gigabyte GA-Z77X-UP4主板的3770k。
我已经遇到USB问题很长一段时间了(当我插入某些设备或同时插入许多设备时,桌面背面的所有u***设备都停止工作)以及持续的Wi-Fi连接问题。 (低下载速度,随机断开连接,不断启动故障排除程序以尝试修复问题) 我一次又一次搜索网页,寻找解决这个问题的方法。 我不确定这些问题是否与CPU或主板有关,但我很确定这是垃圾驱动程序。 很多人似乎都遇到了这个特定主板和CPU的驱动程序问题。 我的电脑上的问题随着时间的推移变得更糟。 我不再能够使用方向盘和踏板,也不能一次插入两个控制器。 而在此之前,即使我仍然遇到断线问题,我也可以让它工作。 我知道,是时候升级了。 这是计划,但最近英特尔的价格大幅上涨,所以我宁愿等待他们解决他们的供应问题或转向AMD。 作为一名游戏玩家,英特尔有优势,但我无法为这种性能上的微小差异支付那种溢价。 如果它不是坏驱动程序,CPU本身仍然保持正常,我可以骑出来。 任何帮助将非常感激。 我尝试过的事情: 更新/重新安装网络和USB驱动程序/清理Windows安装/ CMOS重置 以上来自于谷歌翻译 以下为原文 I have an old 3770k with a Gigabyte GA-Z77X-UP4 motherboard. I've been experiencing USB problems for quite some time(All the u*** devices on the back of my desktop stop working when I plug in certain devices or many devices at once) as well as constant Wi-fi connection issues. (low download speeds, random disconnects, constantly having to launch the troubleshooter to try and fix things) I've searched the web time and time again in search of a solution to this problem. I'm unsure whether these issues relate to the CPU or the Motherboard but I'm pretty sure it is down to rubbish drivers. A lot of people seem to be experiencing driver problems with this particular motherboard and CPU. The problems on my computer have gotten worse over time. I am no longer able to use my steering wheel and pedals and can't plug two controllers in at once for example. Whereas before, I could get it to work even though I still experienced disconnection problems. I know, it's time to upgrade. That was the plan, but recently Intel prices took a massive hike so I'd rather wait for them to sort out their supply issues or make the switch to AMD. As a gamer, Intel has the edge but there is no way I am going to pay that kind of premium for such little difference in performance. If it wasn't for bad drivers, the CPU itself still holds up just fine and I could ride it out. Any help would be much appreciated. Things I've tried: updating/re-installing network and u*** drivers/ clean windows install / CMOS reset |
2个回答
什么os?
提供版本号和内部版本号。 而且,u***3,还是u***2? 文件 以上来自于谷歌翻译 以下为原文 What os? Provide version and build numbers. And, u***3, or u***2? Doc |
1. Windows 10 build 1803 2. USB 3.0 以上来自于谷歌翻译 以下为原文 1. Windows 10 build 1803 2. USB 3.0 |
只有小组成员才能发言,加入小组>>
237浏览 0评论
GMT+8, 2024-3-28 21:57 , Processed in 1.996792 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
