您好我正在尝试使用两个或更多不同的X轴创建散点图。
附件是带有示例的Excel电子表格和名为“XYChart.vee”的Hp Vee示例程序。我正在使用Vee 9.3运行Window 7。 谢谢Tony Sellas 以上来自于谷歌翻译 以下为原文 Hello I am trying to create a scatter plot with two or more different X-axis. Attached is an Excel spreadsheet with an example and the Hp Vee example program named "XYChart.vee" I am running Window 7 with Vee 9.3. Thank you, Tony Sellas |
7个回答
我看不到你的附件。
您可能会意识到,通常情况下,有多个X /域/水平轴是不常见的。 AFAIR你可以用VEE做2个垂直/ Y轴,但也许不行。 在没有看到你的例子的情况下,我建议采取一些方法:通过创建辅助轴(假设它必须对主X轴有一些影响,假设),在图形下方使用不同的图形组件...使用 MatLab图(有很多例子) - 我已经将它们用于表面和其他3D视图 - 或者 - VEE支持.NET(和COM),过去我使用过TeeChart(来自steema.com) 我需要弄乱标记等等。 当然还有其他选择,也许是内置的MS .NET图表(ZChart是吗?)在极限情况下,如果Excel是唯一的实用工具,你当然可以自动化图形构造。 HTH,Mike Watts 以上来自于谷歌翻译 以下为原文 I couldn't see your attachments. You probably realise it's unusual to have more than one X/domain/horizontal axis as you normally plot against that. AFAIR you can do 2 vertical/Y axes with VEE but maybe no more. Without seeing your example I'd suggest a few ways to go: 'fake' it by creating supplementary axes ( which must have some bearing to the main X axis, I presume ) beneath the graph use a different graph component... use a MatLab graph ( there are loads of examples ) - I've used these for surface and other 3D-view graphs -or - VEE supports .NET ( and COM ) and in the past I've used TeeChart ( from steema.com ) where I needed to mess with markers and so forth. There are other options of course, maybe the built-in MS .NET chart ( ZChart is it? ) In the limit, if Excel is the only practical tool you can of course automate the graph construction with that. HTH, Mike Watts |
嗨,迈克,谢谢你的帮助。
我正在测试不同电路和偏置的PIPO。 每个电路的输入功率(X轴)不同。 要在Excel中创建最终报告,我必须手动为每个数据集选择X轴和Y轴。 我会尝试再次附加该文件。 以下是具有不同x轴的几个简单数据集的示例。第一数据集_X__y_ 12.2 22.4 32.6 42.8 53 63.2 73.4 83.6 93.8第二数据集_X__y_ 1.52.2 22.4 2.52.6 32.8 3.53 43.2 4.53.4 53.6 5.53.8 3rd 数据集_X__y_ 1.32.2 1.62.4 1.92.6 2.22.8 2.53 2.83.2 3.13.4 3.43.6 3.73.8谢谢, 以上来自于谷歌翻译 以下为原文 Hi Mike, Thanks for you help. I am testing PIPO on different circuits and bias. The input power (X-axis) is not the same for each ciircuit. To create a final report in Excel I have to manually select the X-axis and Y-axis for each data set. I will try to attach the file again. Below are examples of several simple data sets with different x-axis.. 1st Data set _X_ _y_ 1 2.2 2 2.4 3 2.6 4 2.8 5 3 6 3.2 7 3.4 8 3.6 9 3.8 2nd data set _X_ _y_ 1.5 2.2 2 2.4 2.5 2.6 3 2.8 3.5 3 4 3.2 4.5 3.4 5 3.6 5.5 3.8 3rd data set _X_ _y_ 1.3 2.2 1.6 2.4 1.9 2.6 2.2 2.8 2.5 3 2.8 3.2 3.1 3.4 3.4 3.6 3.7 3.8 Thanks, 附件 |
好的,绝对可行,但不是图表最直接的应用。 我附上了一个看起来像你的电子表格的例子。 注意:映射的所有输入都是数据 - >常量 - > Real64,但一般情况下,如果(a)对象标题被短的&更改,则更容易读取程序。 有意义的 (b)然后通过点击图表LHS上的Trace 1来最小化它们改变痕迹颜色(名称等),或者你可以通过进入属性(左下窗口)找到它们,找到Traces并点击 ...打开一个对话框,可以通过单击Y名称将Y比例从自动更改为固定,同样可以如上所述设置具有X名称或两者的X比例,但是对于Scales属性,可以向图形添加额外的跟踪 通过图形对象的菜单添加终端 - >数据输入...同样将映射值引脚添加到数据 - >访问数组 - >设置映射对象,单击对象菜单添加终端 - >数据输入然后选择映射从1 ,再次执行相同操作以获取Map To 1输入引脚。 如果有什么不清楚,那就继续问! 迈克沃茨 以上来自于谷歌翻译 以下为原文 Ok, definitely doable but not the most straightforward application of the charts. I have attached an example which looks like your spreadsheet. Notes: all of the inputs to the mappings are Data -> Constant -> Real64 but in general it is easier to read the program if (a) object titles are changed with something short & meaningful & (b) they are then minimised change the trace colours ( names and so forth ) by clicking on Trace 1 on the LHS of the graph or you can get to them by going into the properties ( left lower window ), find Traces and click on the ... to open a dialog box the Y scale can be changed from auto to fixed by clicking on Y name, likewise X scale with X name or both can be set as noted above but for the Scales properties Add extra traces to the graph by the graph object's menu Add Terminal -> Data Input... Likewise to add the mapping values pins to the Data -> Access Array -> Set Mappings objects, click on the objects menu Add Terminal -> Data Input then select Map From 1, do the same again to get the Map To 1 input pin. If anything is not clear then keep asking! Mike Watts 附件 |
bgvywerq 发表于 2018-10-12 12:02 我不得不说迈克,我喜欢这个。 在使用vee的所有年份中,我从未使用过'set mapping'函数。 西蒙 以上来自于谷歌翻译 以下为原文 I have to say Mike I love this. Of all the years using vee I have never used the 'set mapping' function. Simon |
Simon,我认为VEE(映射数组)的一个重要特性 - 当然你可能已经使用了分别映射到时间和频率的波形和/或频谱。 麦克风 以上来自于谷歌翻译 以下为原文 Simon, One of the great features of VEE ( mapped arrays ) I think - of course you have probably used waveform and/or spectrum which are mapped to time and frequency respectively. Mike |
嗨,迈克,谢谢你的例子。
在测试和审查测试数据时,这将对我有很大帮助。 我想知道Vee Excel“创建XY图表”功能是否可以创建具有多个X轴的相同图表。 在Excel中创建可编辑的绘图而不是图片时,我会很有帮助。 以上来自于谷歌翻译 以下为原文 Hi Mike, Thanks for the example. That will help me greatly while testing and reviewing the test data. I was wondering if the Vee Excel "Create XY chart" function can create the same chart with multiple X-axis. I would be helpful when creating an editable plot in Excel instead of a pictures. |
yweyerwq 发表于 2018-10-12 12:47 Tony,简短的回答是肯定的,您可以通过VEE以编程方式在Excel中创建图形。 然而,这不是我最近做过的事情,我没有使用过那个VEE菜单项。 通常在我的工作中,应用程序显示每天使用的图形,然后保存到Excel(或XML)以进行进一步的临时分析和数据存储。 我已经看过几个关于Excel图表的主题 - 可能值得搜索论坛。 干杯。 麦克风 以上来自于谷歌翻译 以下为原文 Tony, The short answer is yes, you can create the graph in Excel programmatically from VEE. However it's not something I have done recently and I haven't used that VEE menu item. Typically in the work I do, the application program displays the graphs used everyday and then saves to Excel ( or XML ) for further ad-hoc analysis and data storage. I have seen several threads regarding Excel graphs - might be worth a search of the forum for those. Cheers. Mike |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1846 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1547 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
349浏览 0评论
1386浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
261浏览 0评论
2248浏览 0评论
1102浏览 0评论
GMT+8, 2024-3-29 08:53 , Processed in 1.104192 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
