在谐波平衡模拟中使用EM模型进行模拟时会出现收敛误差。
但是在ADS的电气模型(微带线模型等)的仿真中没有收敛误差。 只有从其布局中提取的EM模型才会出现该错误。 我在ADS手册中阅读了谐波平衡模拟中的收敛误差文档。 我尝试应用文档中建议的技术,例如更改OSR,使用TAHB,自动(首选)收敛模式,高级(稳健)收敛模式,将迭代更改为强大和自定义1000,直接求解器,Krylov求解器,Matrix re - 使用健壮,自定义,Krylove重新启动长度(强大,低内存,自定义)等等...我也尝试更改一些高级延续参数和高级krylov参数。 但收敛仍然没有成功。 我可以尝试什么来达到收敛? 非常感谢你。 以上来自于谷歌翻译 以下为原文 Convergence errors occur in a simulation with an EM model in hARMonic balance simulation. But there is no convergence error in a simulation with electrical models(microstrip line models and so on) of ADS. The error only occurs with its EM model extracted from its layout. I read the document of convergence error in harmonic balance simulation in the manual of ADS. I tried applying the techniques suggested in the document, such as changing the OSR, using TAHB, auto(preferred) convergence mode, advanced (robust) convergence mode, changing iterations to robust and custom with 1000, direct solver, Krylov solver, Matrix re-use robust, custom, Krylove Restart length (robust, low memory, custom), and so on... I also tried changing some of advanced continuation parameters and advanced krylov parameters. But still no success in convergence. What could I try to reach the convergence? Thank you very much. |
1个回答
尝试检查非线性器件的偏置,通常不适当的偏置会导致收敛问题。
此外,您可以在运行s参数模拟时检查小信号的稳定性,因为s参数仍然应该运行,如果它不稳定,那将是收敛问题的原因。 希望有所帮助。 问候 以上来自于谷歌翻译 以下为原文 Try to check the biasing of the non-linear device, quite often not a proper biasing leads to convergence issues. Also you can check the small signal stability when running s-parameter simulation, since s-parameters should still run, and if it is not stable there - that would be the cause for convergence issue. Hope that helps. Regards |
只有小组成员才能发言,加入小组>>
2096 浏览 1 评论
1854 浏览 1 评论
1712 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1410浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 07:25 , Processed in 1.135503 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
