大家好,
我正计划推出一款采用i7-8700和H370主板的全新PC机,配备DP,HDMI,DVI和VGA插槽,提供3x显示器,如下所示: - 1)带HDMI的4k电视 2)带HDMI的FHD监视器 3)带HDMI的FHD监视器 我的研究表明,要在4k上获得60Hz,我必须使用DP插座,因为HDMI仅为v1.4。 为了获得主板上的HDMIv2.0,似乎我需要去Z370(甚至可能是Z270)和mini-ITX主板,但我需要你在H370主板上使用的插槽。 有鉴于此,我计划按如下方式喂养显示器: - 1)DP插座+ DP / HDMI适配器+ HDMI电缆,在60HZ时产生3840x2160 2)HDMI插座+ HDMI线缆产生1920x1080 @无所谓 3)DVI插座+ DVI到HDMI线缆产生1920x1080 @无所谓太多 我被研究人员相信,上述内容可以在Windows 10 Pro 5760x2160下生成组合桌面。 任何人都可以确认,否认或提供有关此设置的任何想法。 此设置适用于非常基本的办公室工作,即我对游戏性能(或视频编辑)不是特别感兴趣,我只需要一个巨大的桌面,并希望能够将显示器驱动到最佳状态。 提前感谢任何想法。 关心马尔科姆 以上来自于谷歌翻译 以下为原文 Hi all, I'm planning a new PC build with an i7-8700 and H370 motherboard featuring a DP, HDMI, DVI and VGA sockets serving 3x monitors as follows:- 1) 4k TV with HDMI 2) FHD Monitor with HDMI 3) FHD Monitor with HDMI My research indicates that to get 60Hz on the 4k I have to use the DP socket as the HDMI is only v1.4. To get HDMIv2.0 on the mobo it seems I need to go to Z370 (possibly even Z270) and mini-ITX boards, but I need the slots you get on H370 mobos. In light of this I plan to feed the monitors as follows:- 1) DP socket + DP/HDMI adapter + HDMI cable to yield 3840x2160 @ 60HZ 2) HDMI socket + HDMI cable to yield 1920x1080 @ doesn't matter too much 3) DVI socket + DVI to HDMI cable to yield 1920x1080 @ doesn't matter too much I am led to believe by my research that the above will work to yield a combined desktop under Windows 10 Pro of 5760x2160. Can anyone confirm, deny or offer any thoughts on this setup. This setup is intended for pretty basic office work, ie I'm not particularly interested in the gaming performance (or video editing), I just need a huge desktop and like to to be able to drive the monitors to their best ability. Thanks in advance for any thoughts. Regards Malcolm |
3个回答
HelloMalcolmD感谢您在英特尔®社区发帖。请允许我与您分享英特尔®酷睿™i7-8700处理器根据规格支持以下解决方案:
最大分辨率(HDMI 1.4):4096x2304 @ 24Hz最大分辨率(DP):4096x2304 @ 60Hz最大分辨率(eDP-集成平板):4096x2304 @ 60Hz注意:这些分辨率将在连接到特定输出类型的所有显示器之间共享。 例如,HDMI输出(4096x2304 @ 24Hz),如果您有2个3显示器,将在每个显示器之间分配。 这意味着每个显示器的分辨率会降低,因此所有这些显示器都会使用与规格上的HDMI输出相当的带宽。 我还建议在Z370上验证主板制造商的显示输出设计。 另外,请记住,英特尔不建议使用任何类型的适配器。 这是因为我们无法测试所有这些,所以我们不能保证这些都能正常工作。希望这会有所帮助。 此致Leonardo C.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello MalcolmD Thank you for posting in the Intel® community. Allow me to share with you that the Intel® Core™ i7-8700 Processor according to the specification it supports the following resolutions:
Note: These resolutions would be shared among all the displays connected to the specific kind of output. For example, the HDMI output (4096x2304@24Hz), if you have 2 o 3 displays, would be distributed among each display. This means that resolution would be lower on each display so that all of them would use the bandwidth equivalent as the HDMI output on the specifications. I would recommend also verifying the Motherboard manufacture for the display output design on the Z370. Also, bear in mind that Intel® does not recommend the use of any kind of adapters. This is because we cannot test all of them, so we cannot guarantee that these are going to work. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-12 10:15 莱昂纳多C,谢谢你的回复。 这是我的担忧,即虽然UHD630可以驱动3倍显示器,但4096x2304的分辨率是共享的。 因此,为了获得5760x2160的台式机(即4k + 2x堆叠FHD),我需要使用主板通过HDMI / DVI驱动两个FHD并购买一个附加卡以通过HDMI驱动4k。 我当然可以从主板上驱动4k并获得一张卡来驱动两个FHD,但是我要么必须运行4k @ 24Hz或使用DP / HDMI适配器。 我认为第一轮更好。 BTW我注意到自从发布了新的第9代核心芯片 - i7-9700是否有ETA? 我知道i7-9700K迫在眉睫,但找不到标准芯片的任何细节。 非常感谢前进, 关心马尔科姆 以上来自于谷歌翻译 以下为原文 Leonardo C, thank you for your reply. This was my concern, ie that although the UHD630 can drive 3x displays, the resolution of 4096x2304 is shared. So it seems that in order to get my desktop of 5760x2160 (ie a 4k+2xstacked FHDs), I need to use the mobo to drive the two FHDs via HDMI/DVI and buy an add in card to drive the 4k via HDMI. I could of course drive the 4k from the mobo and get a card to drive the two FHDs, but then I either have to run the 4k@24Hz or use a DP/HDMI adapter. Better the first way round I think. BTW I noticed since posting of the new 9th gen core chips - is there an ETA for the i7-9700? I know the i7-9700K is imminent, but couldn't find any details for the standard chip. Many thanks advance, Regards Malcolm |
cd340823 发表于 2018-10-12 10:27 您好MalcolmD谢谢您的信息。在这种情况下,如果MOBO有一个DP输出和HDMI输出,使用Intel UHD图形设置不需要分立显卡,但您需要验证有效/支持的配置; 在使用分立视频卡的情况下,与MOBO制造商确认它可以处理英特尔®高清显卡+分立卡非常重要。请参阅以下英特尔®酷睿™i7-9700K处理器规格链接:https:// ark .intel.com / products / 186604 / Intel-Core-i7-9700K-Processor-12M-Cache-up-to-4-90-GHz-我建议您联系您所偏好的英特尔经销商以获得产品。 希望这可以帮助。 此致Leonardo C.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello MalcolmD Thank you for the information. In this case, with Intel UHD graphics the discrete video card is not necessary for the setting if the MOBO has one DP output and to HDMI output, but you need to verify the valid/supported configuration; in case of using the discrete video card is important to verify with the MOBO manufacturer that it can handle Intel® HD graphics + discrete card. Refer to the following link for the Intel® Core™ i7-9700K Processor specification: https://ark.intel.com/products/186604/Intel-Core-i7-9700K-Processor-12M-Cache-up-to-4-90-GHz- I would recommend contacting the Intel distributor of your preference for the product availability. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-24 00:13 , Processed in 0.666375 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
