我最近买了一台配备英特尔Optane Memory(IOM)的预装PC来增强1TB硬盘。
我还订购了三星m.2 PCIe 500GB SSD。 已经连接了IOM'gumstick',我的主板上仍然有两个开放的PCIe m.2插槽。 (我可以使用插槽1而不禁用我的SATA 2.2端口用于HDD。) 正如标题所暗示的那样,我想知道:如果我安装了一个PCIe SSD并将其作为我的启动驱动器,然后将我的硬盘格式化以用于存储,我的硬盘驱动器是否仍会被IOM提升? 这有可能吗? 提前致谢。 以上来自于谷歌翻译 以下为原文 I recently bought a prebuilt PC that came with Intel Optane Memory (IOM) to boost a 1TB HDD. I also ordered a Samsung m.2 PCIe 500GB SSD. With the IOM 'gumstick' already attached, there are still two open PCIe m.2 slots on my mobo. (I am able to use slot 1 without disabling my SATA 2.2 port for the HDD.) As the title suggests, I was wondering: If I install a PCIe SSD and make that my boot drive, then format my HDD to use for storage, will my HDD still be boosted by the IOM? Is this possible at all? Thanks in advance. |
1个回答
嗨Primu,
感谢您在英特尔®社区发帖。 实际上,可以使用最新的英特尔®Optane™内存驱动程序版本来加速辅助驱动器,但是您的系统必须具备一些要求,否则将无法实现辅助驱动器加速。 我建议您查看以下文章,确保您的系统符合要求:采用Intel®Optane™内存的辅助/数据SATA驱动器加速 如果此信息可以解答您的疑虑,请告诉我。 如果您对上述文章中的信息有任何疑问,请随时提出。 祝你今天愉快。 此致,Diego V. 以上来自于谷歌翻译 以下为原文 Hi Primu, Thank you for posting in the Intel® communities. Indeed, it’s possible to accelerate a secondary drive with the latest driver version for the Intel® Optane™ Memory, however there are some requirements that your system must have, otherwise the secondary drive acceleration won’t be possible. I recommend you to check the following article and make sure your system meets the requirements: Secondary/Data SATA Drive Acceleration with Intel® Optane™ Memory Let me know if this information answers your concern. If you have any question about the information in the article above, feel free to ask. Have a nice day. Regards, Diego V. |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-20 04:36 , Processed in 0.606414 second(s), Total 70, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
