系统板是带有e5140处理器的s5000pal。
尝试运行selviewer会导致: BMC通讯失败。 该板最近“间歇地”执行,即它不能完成启动过程。 cpu和PS被替换,现在似乎正常执行。 其他方面正常运行,没有操作系统更改。 Selviewer在间歇性表演之前工作。 提前谢谢 - 丹 以上来自于谷歌翻译 以下为原文 The system board is an s5000pal with an e5140 processor. Attempts to run selviewer result in: BMC communication failed. This board has recently performed 'intermittently', i.e. it would not complete the boot process. The cpu and PS were replaced and now appears to be performaing normally. Other aspects are running normally, there has been no OS change. Selviewer worked prior to the intermittent performance. Thanks in advance - Dan |
3个回答
我建议在另一块主板上测试处理器以确保它有缺陷。
如果是这种情况,那么您可能需要联系英特尔当地客户支持中心,以便他们可以为您提供任何保修选项,您可以在以下位置找到本地联系信息: http://www.intel.com/support/9089.htm 以上来自于谷歌翻译 以下为原文 I would suggest testing the processor on another motherboard to make sure it is defective. If that is the case, then you might want to contact Intel local customer support center so they can assist you with any warranty option, you can find the local contact information at: http://www.intel.com/support/9089.htm |
第三代的年均卡上 发表于 2018-10-11 09:36 后续更新:当BIOS OS时间设置为10分钟时,系统将在10分钟的周期内自动重新启动。 这告诉我BMC正在工作,问题是BMC和CPU / OS之间的通信。 这是一个合理的假设吗? 谢谢 - 丹 以上来自于谷歌翻译 以下为原文 A follow on update: When the BIOS OS timere is set to 10 minutes the system auto reboots on a 10 minute cycle. This says to me the BMC is working and the issue is communication between BMC and the CPU / OS. Is this a reasonable assumption? Thanks - Dan |
yhxcftp 发表于 2018-10-11 09:44 你在DOS下运行吗? Linux还是Windows? 尝试DOS。 它是最基本的工具(不依赖于其他OS驱动程序) BMC“处理器”完全独立于主板CPU,您可以通过测试来展示BMC的功能。 另一个是前面板ID按钮。 如果蓝色LED亮起,则BMC正在运行。 对于您的其他问题,我怀疑日志可能已损坏。 尝试从BIOS设置屏幕清除BMC日志,然后再次尝试SELVIEW。 以上来自于谷歌翻译 以下为原文 Are you running in DOS. Linux or Windows? Try DOS. It is the most basic of the tools (No dependance on other OS drivers) The BMC "processors" is totally seperate from the main board CPU and you test is a good on to show BMC is functoning. Another is the front pannel ID button. If the blue LED lights, BMC is running. With your other issues, i would suspect the log may be corrupted. Try clearing the BMC log from the BIOS set-up screen then try the SELVIEW again. |
只有小组成员才能发言,加入小组>>
255浏览 0评论
GMT+8, 2024-4-24 12:16 , Processed in 0.585703 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
