嘿伙计,
我刚买了一台Intel D510MO,到目前为止对它非常满意。 但现在我遇到了一些问题。 我想使用D510MO设置一个HTPC,因此我买了一个HD2400 PCI附加卡(老实说GMA3150不足以在youtube上观看高清视频等) 所以我将该视频卡连接到D150MO的PCI插槽上并启动了我的电脑。 如果我是对的,则在使用视频附加卡时应自动关闭板载图形,但集成显卡仍处于活动状态。 只要HTPC仍处于启动程序,我的显示器将不会获得任何视频信号,直到Vista或Seven完全加载。 所以这意味着如果我想在BIOS中安装不同的操作系统或更改设置,我需要在这两个源之间切换显示。 BTW:我在BIOS中尝试了几种设置,比如将主视频适配器设置为“auto”,“int graphics”或“ext pci graphics”,但仍然是同样的问题,pci视频适配器只能在windows中使用。 任何人有同样的问题或解决方案吗? 我会感谢任何建议。 问候 眼镜蛇 以上来自于谷歌翻译 以下为原文 Hey folks, I just bought an Intel D510MO and so far very pleased with it. But now I ran into some problems. I want to set up a HTPC using the D510MO, therefore I bought a HD2400 PCI add-in card (honestly GMA3150 is not enough for being able to watch hd videos on youtube or such) So I connected that videocard on the PCI slot of my D150MO and started my computer. If I am right the onboard graphics should be turned off automatically, when using a video add-in card, but the integrated graphics still ramains active. As long the HTPC is still in the booting routine my display won't get any video signal, until Vista or Seven is fully loaded. So this means if I wanted to install a different os or change setting in bios, I need to switch the display between these two sources. BTW: I tried several settings in bios, like setting primary video adapter to "auto" , "int graphics" or "ext pci graphics" but still the same problem the pci video adapter can only be used in windows. Anyone having the same problem or maybe a solution? I would be thankful for any suggestion. regards cobra |
3个回答
是的我对nVidia Geforce 8400GS有同样的问题。
我必须安装带有连接到板载图形适配器的监视器的Linux,之后我可以在Linux的Geforce中使用它。 我正在使用最新的BIOS更新,没有任何成功。 以上来自于谷歌翻译 以下为原文 Yes I have the same problem with a nVidia Geforce 8400GS. I have to install Linux with the monitor attached to the onboard graphics adaptor and later I can use it at the Geforce in Linux. I'm using the latest bios update without any success. |
与Nvidia Geforce 5200相同的问题。尝试过所有BIOS选项并禁用/删除Windows 7上的板载intel图形驱动程序。
以上来自于谷歌翻译 以下为原文 Same problem for me with Nvidia Geforce 5200. Have tried all the bios options and disabling / removing onboard intel graphics drivers from windows 7. |
60user101 发表于 2018-10-11 13:23 我对这两个组件有另一个问题。 当使用插入的ATI HD2400pro启动D510MO时,我可以看到BIOS的所有输出和Windows 7的启动屏幕,但是我没有登录屏幕。 我只看到一个带有可移动鼠标指针的黑色屏幕,有时会有一个忙碌的圆圈。 我首先使用ATI HD4350解决了这个问题。 经过一些测试后我发现系统通常以Diamond Stealth(1995年非常好的VGA卡)开头:在这里我得到一个登录屏幕。 所以我认为这是一个耗电问题。 Perhabs电路板无法为PCI插槽提供足够的电力。 所以我买了HD2400卡导致了同样的问题。 你是如何在Windows下使用D510MO的HD2400的? 谢谢 TheExpert 以上来自于谷歌翻译 以下为原文 I have an other issue with these two components. When starting the D510MO with an inserted ATI HD2400pro I can see all output of the BIOS and the start screen of Windows 7 but I don't get a logon screen. I only see a black screen with a moveable mouse pointer and sometimes there is a busy circle. I had this problem first with an ATI HD4350. And after some tests I found out that the system is normally starting with an Diamond Stealth (a very good VGA card of the year 1995): Here I get a logon screen. So I thought that this is a power consumption problem. Perhabs the board doesn't deliver enough power to the PCI slot. And so I bought the HD2400 card resulting in the same problem. How did you all get the HD2400 with the D510MO working under Windows? Thank you TheExpert |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-19 14:50 , Processed in 0.647568 second(s), Total 70, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
