您好,我有一个16802逻辑分析仪,我想测量PC和其他设备之间异步通信的时间延迟。
该通信使用波特率为921.6 kbps的HDLC协议。 问题是延迟通常高于300毫秒,因此内部存储器不足以保存所有样本。 我想知道是否有任何方法可以配置逻辑分析器,以便它只保存我们想要的帧,并计算帧之间的时间而不保存信息。 我试图编写一个高级触发器,但似乎只从一个点填充内存。 另一个问题是可能使信号与LA同步。 真的有可能吗? 最大采样分辨率为10 ns,因此无法以该波特率采样,我不知道如何避免误码。 谢谢你的帮助! 此致,Roberto Cuerdo 以上来自于谷歌翻译 以下为原文 Hello, I have a 16802 Logic Analyzer and I want to measure the time delay in an asynchronous communication between a PC and other devices. This communication uses the HDLC protocol at a baudrate of 921.6 kbps. The issue is that the delays are usually higher than 300 ms, therefore the internal memory is not large enough to save all the samples. I wonder if there is any way to configure the logic analyzer so that it saves only the frames we want and it counts the time between frames without saving the information. I have tried to program an advanced trigger, but it seems that only fills the memory from a single point. Another question is the possibility of synchronizing the signal with the LA. Is it really possible? The maximum sampling resolution is 10 ns, so I cannot sample at that baudrate, and I do not know what to do to avoid bit errors. Thanks for your help! Regards, Roberto Cuerdo |
2个回答
您是否尝试使用过渡时序模式?
它只会存储转换,但会跟踪转换的距离。 它可以在相隔几秒,几分钟或几小时的事件上为您提供4 nsec的分辨率。 此外,您可能希望将触发位置设置为1%。 免责声明:为了获得更可靠的响应时间,您应该考虑致电当地的Keysight技术呼叫中心。 Keysight论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 Have you tried using transitional timing mode? It will only store transitions, but keep track of how far apart the transitions are. It can give you 4 nsec resolution on events that are seconds, minutes, or hours apart. Also, you may want to set your trigger position to something like 1%. Al Disclaimer: For more reliable response times, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
nvywyerwer 发表于 2018-10-11 13:22 谢谢。 过渡时序模式正是我所需要的。 关心罗伯托 以上来自于谷歌翻译 以下为原文 Thank you. The transitional timing mode is exactly what I need. Regards Roberto |
只有小组成员才能发言,加入小组>>
2096 浏览 1 评论
1854 浏览 1 评论
1712 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 15:21 , Processed in 1.174717 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
