我们最近将所有程序从Vee5升级到Vee9。
在每个实例中,在V5中执行完美的程序现在会在V9中崩溃,我们有“EXECUTE CLEAR”实例。 我们必须删除每个实例并用“IP”或“* RST”或任何其他独特的仪器预设状态替换这些命令。 因为我不期待通过每行代码来解决这个问题,所以我想看看其他人是否也遇到过这些问题以及他们的解决方法是什么。 顺便说一句 - 我们已经将程序首选项从V5设置为V9并且没有任何效果。 谢谢,迈克 以上来自于谷歌翻译 以下为原文 We recently upgraded all of our programs from Vee5 to Vee9. In every instance, programs that executed flawlessly in V5 now would crash in V9 where we had instances of "EXECUTE CLEAR". We had to remove each instance and replace those commands with "IP" or "*RST" or any other unique instrument preset state. As I am not looking forward to going through each line of code to dump this out, I wanted to see if others have also had these problems and what their workaround was. BTW - we have already set the program preferences from V5 to V9 and that had no effect. Thanks, Mike |
2个回答
迈克,我从来没有经历过这个,但那可能是因为我在发布时总是升级到每个新的VEE版本。
我确实记得在VEE改变了V8.0中I / O的方式时出现了一些问题,但通常通过在Default Preferences> IO下选中“Enable Pre 8.0 Legacy I / O”来解决这些问题。 你试过吗? -Bill P.S. 如果您订阅VEE反射器,您将获得更快的问题答案,如下所述。 这是一个低流量的邮件列表,所以不要担心被电子邮件淹没。 VEE Reflector:要订阅,请发送电子邮件至:“vrf-request@general.lists.agilent.com”,邮件正文中包含“subscribe”字样(仅限长签名和纯文本)。 要取消订阅,请发送一封空白电子邮件至“leave-vrf@general.lists.agilent.com”(仅限长签名和纯文本)。 要将邮件发送到此邮件列表,请发送电子邮件至“vrf@general.lists.agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@general.lists.agilent.com”。 在“http://vee.engineering.agilent.com”上搜索Agilent vrf存档。 以上来自于谷歌翻译 以下为原文 Mike, I have never experienced this, but that could be because I've always upgraded to each new VEE version at the time they were released. I do remember having some issues when VEE changed the way I/O was done in Version 8.0, but those were usually solved by checking "Enable Pre 8.0 Legacy I/O" under Default Preferences > IO. Did you try that? -Bill P.S. You'll get faster answers to your questions if you subscribe to the VEE reflector as described below. It's a low traffic mailing list so don't worry about getting flooded with email. VEE Reflector: To subscribe please send an email to: "vrf-request@general.lists.agilent.com" with the word subscribe in the message body (no long signatures and plain text only). To unsubscribe send a blank email to "leave-vrf@general.lists.agilent.com" (no long signatures and plain text only). To send messages to this mailing list, email "vrf@general.lists.agilent.com". If you need help with the mailing list send a message to "owner-vrf@general.lists.agilent.com". Search the Agilent vrf archive at "http://vee.engineering.agilent.com". |
derek88 发表于 2018-10-11 09:11 实际上我们没有,但你可以放心,这将是我周一早上测试的绝对第一件事。 非常感谢你的帮助。 以上来自于谷歌翻译 以下为原文 Actually we didn't but you can rest assured it will be the absolute first thing I test out Monday morning. Thank you so much for the assist. |
只有小组成员才能发言,加入小组>>
2096 浏览 1 评论
1854 浏览 1 评论
1712 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1410浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 09:14 , Processed in 1.092099 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
