嗨,我必须连续发送一个21字节的帧从PIC18F47 K42到PIC16F1575。现在,我希望接收器能够区分从旧帧到新帧的字节。我可以在发送器的数据线上产生一个中断条件,但是我不认为接收器有硬件能力来检测中断。有人有什么建议吗?谢谢。
以上来自于百度翻译 以下为原文 hi, I have to continuously transmit a frame of 21 bytes from PIC 18F47K42 to PIC16F1575. Now, i want the receiver to be able to distinguish between bytes from an old frame, and new frame. I could generate a break condition on the data line from the transmitter, but i don't think that receiver has hardware capabilities to detect breaks. Does anyone has any suggestions? Thanks. |
4个回答
“框架”到底是什么?它是否有定义的起始标记或结束标记,或附加的校验和?PIC16F1575可以检测中断字符。数据表在第22.4节中详细描述了这一点。
以上来自于百度翻译 以下为原文 What exactly is a "frame"? Does it have any defined start or end markers, or a checksum attached? The PIC16F1575 can detect a break character. The datasheet describes this in detail in section 22.4 |
我认为我对框架的定义过于自由了。它仅仅是21字节的数据,我将从主控制器连续发送。断线检测只在唤醒,还是可以在正常操作中完成?
以上来自于百度翻译 以下为原文 i think i went too liberal with my definition of a frame. Its just 21 bytes of data, which i will transmit continuously from master controller. Break detection is only on wake up or can it be done in normal operation too? |
当RCIF位被设置时,已接收到中断字符。FRR位设置为RCREG=00 h。
以上来自于百度翻译 以下为原文 A Break character has been received when; • RCIF bit is set • FERR bit is set • RCREG = 00h |
正如麦克朗宁所说,这直接来自我告诉你要阅读的数据表的一部分。
以上来自于百度翻译 以下为原文 As mbrowning said, which comes straight from the part of the datasheet I told you to read. |
只有小组成员才能发言,加入小组>>
4824 浏览 9 评论
1829 浏览 8 评论
1747 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2954 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2059 浏览 5 评论
460浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
362浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1797浏览 0评论
GMT+8, 2024-4-24 08:05 , Processed in 1.010533 second(s), Total 48, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
