发 帖
张飞软硬开源基于STM32 BLDC直流无刷电机驱动器开发视频套件, 👉戳此立抢👈
[传感器] 双传感器测量方法的热量分配表设计包括BOM及原理图
2018-10-10 09:14:48  632 传感器 MCU
分享
The tiDA-00838 reference design implements a heat cost allocator system following the EN834 standard with the “two-sensor measurement method". The solution achieves better than 0.5 degrees Celsius accuracy across a range of +20 to +85°C. Two analog temperature sensors are available as  (...)
主要特色
  • Highly accurate temperature sensing across environment conditions: better than 0.5 degrees from +20 to +85°C.
  • CC1310 SimpleLink(TM) Wireless MCU provides single-chip solution for heat measurement and RF communications
  • Sensor Controller interfaces seamlessly to two matched LMT70A, which eliminate the  (...)
Schematic/Block Diagram.pdf
476.54 KB, 下载次数: 1
物料清单.pdf
98.01 KB, 下载次数: 0
软件.zip
19.2 MB, 下载次数: 0
参考指南.pdf
1.74 MB, 下载次数: 0
TIDA-00838 PCB.pdf
1.63 MB, 下载次数: 0
TIDA-00838 PCB 3D Print.pdf
2.17 MB, 下载次数: 0
分享淘帖 显示全部楼层
最近下载过的用户(1)
只有小组成员才能发言,加入小组>>
123个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /8 下一条
快速回复 返回顶部 返回列表
