你好,
我无法在vSphere 6.0 U2中安装vGPU gpumodeswitch实用程序 我收到以下错误: esxcli软件振动安装-v /NVIDIA-GpuModeSwitch-1OEM.600.0.0.2494585.x86_64.vib [InstallationError] ('NVIDIA_bootbank_NVIDIA-VMware_ESXi_6.0_GpuModeSwitch_Driver_1.0-1OEM.600.0.0.2494585','VIB NVIDIA_bootbank_NVIDIA-VMware_ESXi_6.0_GpuModeSwitch_Driver_1.0-1OEM.600.0.0.2494585不包含签名。') vibs = NVIDIA_bootbank_NVIDIA-VMware_ESXi_6.0_GpuModeSwitch_Driver_1.0-1OEM.600.0.0.2494585 有关更多详细信息,请参阅日志文件。 我的服务器有双特斯拉M60。 先谢谢你。 以上来自于谷歌翻译 以下为原文 Hello, I am unable to install the vGPU gpumodeswitch utility in vSphere 6.0 U2 I get the following error: esxcli software vib install -v /NVIDIA-GpuModeSwitch-1OEM.600.0.0.2494585.x86_64.vib [InstallationError] ('NVIDIA_bootbank_NVIDIA-VMware_ESXi_6.0_GpuModeSwitch_Driver_1.0-1OEM.600.0.0.2494585', 'The VIB NVIDIA_bootbank_NVIDIA-VMware_ESXi_6.0_GpuModeSwitch_Driver_1.0-1OEM.600.0.0.2494585 does not contain a signature.') vibs = NVIDIA_bootbank_NVIDIA-VMware_ESXi_6.0_GpuModeSwitch_Driver_1.0-1OEM.600.0.0.2494585 Please refer to the log file for more details. My server has dual Tesla M60s. Thank you in advance. |
3个回答
你好
更改GPU模式的最简单方法是使用ChangeMode .ISO并直接从中启动服务器。 您可以通过将ISO复制到USB密钥并从中启动来实现,或者如果您有一个管理系统允许您将ISO安装到物理服务器(iLO,DRAC,UCSM),则可以远程安装ISO并具有 服务器直接从它启动。 除非你有特殊的理由想要使用.vib,否则我建议使用其中一种方法。 问候 本 以上来自于谷歌翻译 以下为原文 Hi The easiest way to change the GPU mode is to use the ChangeMode .ISO and boot your server from it directly. You can do that by copying the ISO to a USB key and booting from that, or if you have a management system that allows you to mount ISOs to the physical servers (iLO, DRAC, UCSM), you can remotely mount the ISO and have the server boot directly from it. Unless you have a specific reason for wanting to use the .vib, I'd suggest one of those methods. Regards Ben |
嗨,
你可能已经在这台主机上安装了vGPU manager .VIB吗? 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi, could it be possible that you have already installed the vGPU manager .VIB on this host? Regards Simon |
我有同样的问题。
我也无法启动到iso,我不知道为什么,我可以启动到任何其他iso尝试,但不是Nvidia。 我已经尝试了文档中的每个建议方法,但无法加载modeswitch。 以上来自于谷歌翻译 以下为原文 I am having the same issue. I can't boot to the iso either, I don't know why, I can boot to any other iso I try, but not the Nvidia one. I've tried every suggested method in the documentation, but can not get the modeswitch loaded. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2832 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3225 浏览 4 评论
GMT+8, 2024-4-24 21:36 , Processed in 0.614100 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
