我使用PSOC-5与PSOC创建者4.2的059个套件,并试图通过EMFLASH应用程序与SD卡接口。我已经按照EMFLASH数据表链接了所有的库,并从示例中复制了代码(删除了LCD部分)。然而,我得到以下错误:
生成错误:设备.h:没有这样的文件或目录 生成错误:命令“ARME EABI GCC .exe”退出代码“1”失败。 工作空间和项目包与此帖子连接。 我在论坛上看到,ARMGGC.EXE问题可能是由一个错误的安装引起的,所以我卸载了PSoC创建者——重新启动PC——然后从网站上下载文件并重新安装并重新启动了PC。什么也没变。 请让我知道我做错了什么,以及如何修复它。 注意:工作区是闪烁的LED文件(因为我修改了闪烁的LED示例项目),项目是FATFS文件。 提前感谢, Sujoy。 CE195352O-PSoCl 5LPFATFS.Cyrj.CaseVo.01.Zip 543.1 K CE195352O-PSoCl 5LpBLink 1.2兆字节 以上来自于百度翻译 以下为原文 I am using PSOC-5 with the 059 Kit with PSOC creator 4.2 and trying to interface it with a SD card via the emFile application. I have linked all the libraries as per the emFile datasheet and copied the code from the example (removed the LCD part). However, I get the following errors:- Build error: device.h: No such file or directory Build error: The command 'arm-none-eabi-gcc.exe' failed with exit code '1'. The workspace and project bundle are attached with this post. I read on the forum that the arm_gcc.exe issue can be caused by a faulty installation so I uninstalled PSOC creator - restarted PC - then downloaded the file from the website and installed it again and restarted the PC again. Nothing changed. Please let me know what I am doing wrong and how to fix it. Note:- the workspace is the Blinking LED file (as I modified the Blinking LED example project) and the Project is the FATFS file. Thanks in Advance, Sujoy. |
2个回答
你好,
你能把.lt;设备& h & gt改为项目吗? 谢谢, 希马 以上来自于百度翻译 以下为原文 Hello, Can you change the Thanks, Hima |
对不起,我的坏消息。该系统工作。我做了愚蠢的事,如添加fs_os文件而去no_os建立更加emfile组件错误的项目。我将在这里后束后的人谁想要一个快速和肮脏的SD卡的PSoC 5安装。 以上来自于百度翻译 以下为原文 Sorry My bad. The system works. I had done dumb things like adding FS_OS files while going for No_OS build and even worse adding the emFile component to the wrong project. I will post the bundle here later for anyone who wants a quick and dirty SD card - PSOC 5 installation. |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
188浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
322浏览 2评论
350浏览 1评论
62浏览 1评论
GMT+8, 2024-4-24 17:17 , Processed in 0.758700 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
