大家好,
我们在带有Tesla P4的dell R740服务器中使用linux。 我们正在使用GPU对ffmpeg进行一些测试,没有使用GPU,我们得到了相当多的FPS,我们觉得很奇怪。 没有GPU ffmpeg -i Samsung_UHD_Soccer_Barcelona_Atletico_Madrid.ts -threads 0 -map 0:0 -b 500k -c:v libx264 -s 320x240 -y test.h264 frame = 1068 fps = 77 q = -1.0 Lsize = 1282kB time = 00:00:21.32 bitrate = 492.5kbits / s speed = 1.53x 用GPU ffmpeg -hwaccel cuvid -c:v hevc_cuvid -i Samsung_UHD_Soccer_Barcelona_Atletico_Madrid.ts -map 0:0 -b:v 500k -c:v h264_nvenc -pixel_format yuv420p -r 25 -vf scale_npp = 320:240 -y test1.h264 frame = 415 fps = 66 q = 39.0 Lsize = 1044kB time = 00:00:16.60 bitrate = 515.4kbits / s dup = 0 drop = 411 speed = 2.62x 另一个奇怪的事情是,即使我同时运行不同的进程,GPU的使用总是相同的....大约9% utilization.gpu [%] 9% utilization.gpu [%] 10% utilization.gpu [%] 9% utilization.gpu [%] 10% utilization.gpu [%] 有没有人有ffmpeg来解释这个? 最好的问候和提前感谢 以上来自于谷歌翻译 以下为原文 Hi all, We are using linux in a dell R740 server with a Tesla P4. We are doing some test with ffmpeg using the GPU and without, we get quite much FPS without using the GPU, what we find weird. Without GPU ffmpeg -i Samsung_UHD_Soccer_Barcelona_Atletico_Madrid.ts -threads 0 -map 0:0 -b 500k -c:v libx264 -s 320x240 -y test.h264 frame= 1068 fps= 77 q=-1.0 Lsize= 1282kB time=00:00:21.32 bitrate= 492.5kbits/s speed=1.53x with GPU ffmpeg -hwaccel cuvid -c:v hevc_cuvid -i Samsung_UHD_Soccer_Barcelona_Atletico_Madrid.ts -map 0:0 -b:v 500k -c:v h264_nvenc -pixel_format yuv420p -r 25 -vf scale_npp=320:240 -y test1.h264 frame= 415 fps= 66 q=39.0 Lsize= 1044kB time=00:00:16.60 bitrate= 515.4kbits/s dup=0 drop=411 speed=2.62x The other strange thing is that even if i put to run different processes at the same time, the GPU usage is always the same.... around 9% utilization.gpu [%] 9 % utilization.gpu [%] 10 % utilization.gpu [%] 9 % utilization.gpu [%] 10 % utilization.gpu [%] Anybody has experience with ffmpeg to explain this? Best regards and thanks in advance |
1个回答
嗨,我会假设您使用P4进入FRL = 60fps。
您应该删除VM级别的FRL并再次测试。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi, I would assume that you run into the FRL=60fps with the P4. You should remove FRL on the VM level and test again. Regards Simon |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2819 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3214 浏览 4 评论
2239浏览 0评论
GMT+8, 2024-3-29 21:47 , Processed in 0.472006 second(s), Total 45, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
