我有一个奇怪的问题与UART2在18F65 K40。我在这个芯片上使用所有5个UART,而其他4个则正常运行。但只有UART2 TX闲置低。我处于异步模式,SCKP没有影响。这几乎就像SCKP被困在高硅,我不能改变它。我看不到任何关于这件事的勘误表。以前有人见过这样的东西吗?这是我的最低可行代码。它输出0xAA每500毫秒的发射引脚。我运行了一个16MHz晶体的芯片,并启用PLL。一个有趣的调试尝试,我尝试将所有的寄存器从UART2到UART1(以及适当的PPS的东西)。这样,我可以使用完全相同的代码来观察UART1的TX线。UART1正确地闲置高。
以上来自于百度翻译 以下为原文 I'm having a strange issue with UART2 on an 18F65K40. I'm using all 5 UARTs on this chip and the other 4 are behaving normally. But just UART2 TX idles low. I'm in asynchronous mode and SCKP has no affect. It's almost like SCKP is stuck high in the silicon and I can't change it. I don't see anything in the errata about this. Has anyone seen something like this before? Here's my minimum viable code. It outputs 0xAA every 500ms out the transmit pin. I run the chip off a 16MHz crystal and enable PLL. One interesting debugging attempt I tried was to change all of the registers from UART2 to UART1 (along with the appropriate PPS stuff). In that way, I could observe UART1's TX line using the exact same code. UART1 properly idled high. #pragma config FEXTOSC = HS // External Oscillator mode Selection bits (Oscillator not enabled) #pragma config RSTOSC = HFINTOSC_1MHZ// Power-up default value for COSC bits (HFINTOSC with HFFRQ = 4 MHz and CDIV = 4:1) // CONFIG1H #pragma config CLKOUTEN = OFF // Clock Out Enable bit (CLKOUT function is disabled) #pragma config CSWEN = ON // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed) #pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled) // CONFIG2L #pragma config MCLRE = EXTMCLR // Master Clear Enable bit (If LVP = 0, MCLR pin is MCLR; If LVP = 1, RG5 pin function is MCLR ) #pragma config PWRTE = OFF // Power-up Timer Enable bit (Power up timer disabled) #pragma config LPBOREN = OFF // Low-power BOR enable bit (ULPBOR disabled) #pragma config BOREN = SBORDIS // Brown-out Reset Enable bits (Brown-out Reset enabled , SBOREN bit is ignored) // CONFIG2H #pragma config BORV = VBOR_2P45 // Brown Out Reset Voltage selection bits (Brown-out Reset Voltage (VBOR) set to 2.45V) #pragma config ZCD = OFF // ZCD Disable bit (ZCD disabled. ZCD can be enabled by setting the ZCDSEN bit of ZCDCON) #pragma config PPS1WAY = ON // PPSLOCK bit One-Way Set Enable bit (PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle) #pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset) #pragma config DEBUG = OFF // Debugger Enable bit (Background debugger disabled) #pragma config XINST = OFF // Extended Instruction Set Enable bit (Extended Instruction Set and Indexed Addressing Mode disabled) // CONFIG3L #pragma config WDTCPS = WDTCPS_31// WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS) #pragma config WDTE = OFF // WDT operating mode (WDT Disabled) // CONFIG3H #pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required) #pragma config WDTCCS = SC // WDT input clock selector (Software Control) // CONFIG4L #pragma config WRT0 = OFF // Write Protection Block 0 (Block 0 (000800-001FFFh) not write-protected) #pragma config WRT1 = OFF // Write Protection Block 1 (Block 1 (002000-003FFFh) not write-protected) #pragma config WRT2 = OFF // Write Protection Block 2 (Block 2 (004000-005FFFh) not write-protected) #pragma config WRT3 = OFF // Write Protection Block 3 (Block 3 (006000-007FFFh) not write-protected) // CONFIG4H #pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-30000Bh) not write-protected) #pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected) #pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write-protected) #pragma config SCANE = ON // Scanner Enable bit (Scanner module is available for use, SCANMD bit can control the module) #pragma config LVP = ON // Low Voltage Programming Enable bit (Low voltage programming enabled. MCLR/VPP pin function is MCLR. MCLRE configuration bit is ignored) // CONFIG5L #pragma config CP = OFF // UserNVM Program Memory Code Protection bit (UserNVM code protection disabled) #pragma config CPD = OFF // DataNVM Memory Code Protection bit (DataNVM code protection disabled) // CONFIG5H // CONFIG6L #pragma config EBTR0 = OFF // Table Read Protection Block 0 (Block 0 (000800-001FFFh) not protected from table reads executed in other blocks) #pragma config EBTR1 = OFF // Table Read Protection Block 1 (Block 1 (002000-003FFFh) not protected from table reads executed in other blocks) #pragma config EBTR2 = OFF // Table Read Protection Block 2 (Block 2 (004000-005FFFh) not protected from table reads executed in other blocks) #pragma config EBTR3 = OFF // Table Read Protection Block 3 (Block 3 (006000-007FFFh) not protected from table reads executed in other blocks) // CONFIG6H #pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks) #include #define _XTAL_FREQ 64000000 void main(void) { asm("BSF NVMCON1,7"); OSCCON1bits.NOSC = 0b010; //FEXTOSC with 4x PLL OSCCON1bits.NDIV = 0b0000; //No divider TRISGbits.TRISG0 = 0; TRISGbits.TRISG1 = 1; RX2PPS = 0b110000 | 1; RG0PPS = 0x0F; ANSELG = 0; BAUD2CONbits.SCKP = 0; //<-No affect?? TX2STAbits.SYNC = 0; TX2STAbits.TX9 = 0; RC2STAbits.RX9 = 0; PIE3bits.TX2IE = 0; PIE3bits.RC2IE = 0; TX2STAbits.BRGH = 1; BAUD2CONbits.BRG16 = 1; SP2BRG = 0x14; SP2BRGH = 0x01; TX2STAbits.TXEN = 1; RC2STAbits.CREN = 1; RC2STAbits.SPEN = 1; while(1) { while( !PIR3bits.TX2IF ); TX2REG = 0b10101010; __delay_ms(500); } } |
2个回答
嗨,已经在PIC18F26K22上试用了测试程序。它的代码功能和空闲电平一样高,并且发送了一个正确接收的字符。我认为这应该有一个支持报告单到Microchip。关于,Mysil。
以上来自于百度翻译 以下为原文 Hi, Have tried the test program on PIC18F26K22. There the code function as expected with Idle level High, and transmitting a character that is correctly received. I think this deserve a support report ticket to Microchip. Regards, Mysil |
在记录中,原来我的代码中有一个打印错误。RG0PPS的值应该是0x0e,但是我意外地输入了0x0f。换句话说:移动,这里没有什么可看的。
以上来自于百度翻译 以下为原文 For the record, it turned out I just had a typo in my code. The value of RG0PPS should be 0x0E, but I had typed 0x0F by accident. In other words: Move along, nothing to see here. |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-20 09:04 , Processed in 1.104665 second(s), Total 73, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
