在带有2个网格K1卡的UCS C240 M4机架安装上运行ESXi 6.0。
Xendestop VM通过运行7.6代理HDX 3d Pro和Nvidia驱动程序(348.27)的PVS进行配置。 VDA计算机配置了grid_k120q配置文件。 当我们从Vcenter ESXi主机利用率中启动多台计算机(10台或更多计算机)的guest虚拟机时,它将达到100%并冻结主机,直到任务完成。 我们在从VM中删除NVidia网卡后进行了测试,一切都很好。 关机任务按预期工作,速度很快,没有消耗CPU周期。 有谁遇到过这个问题? 以上来自于谷歌翻译 以下为原文 Running ESXi 6.0 on UCS C240 M4 Rack mount with 2 Grid K1 Cards. Xendestop VM's are provisioned through PVS running 7.6 agent HDX 3d Pro and Nvidia driver (348.27) . VDA machines are configured with grid_k120q profile. When we Intiate a guestshutdown of multiple machines (10 or more machines) from the Vcenter ESXi host utilization goes to 100% and it freezes the host untill the task is completed . We tested after removing the NVidia grid card from the VM’s and everything was fine . shutdown task worked as expected and it was fast and did not consume cpu cycles. Any one faced this issues ? |
2个回答
早期版本/测试版中存在类似问题,需要在vSphere中进行更新。
您是否可以在ESX主机中确认vGPU管理器版本。 它应该是346.68 谢谢 以上来自于谷歌翻译 以下为原文 There was a similar issue in the early release / beta which required an update in vSphere. Can you confirm the vGPU manager version in the ESX host. It should be 346.68 Thanks |
是的,主机上的驱动程序版本是346.68。
以上来自于谷歌翻译 以下为原文 Yes the driver version is 346.68 on the host . |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2830 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3223 浏览 4 评论
GMT+8, 2024-4-20 03:59 , Processed in 0.437174 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
