你好ST,
似乎escape_seq参数在IDW01M1中无法正常工作。 用户手册与获得的结果之间存在一些差异。请看一下我的成绩单: 12:16:15.761 [TX] - at + s.scfg = escape_seq,at + miao< CR> 12:16:26.101 [RX] - 好的 + WIND:61:传入套接字客户端:192.168.0.218 + WIND:60:现在处于数据模式 12:25:49.307 [TX] - at + miao 12:25:49.807 [RX] - + WIND:59:返回命令模式 12:26:05.899 [TX] - at + miao 12:26:10.363 [TX] - at + miao< CR> 12:26:13.700 [TX] -AT + S.< CR> 12:26:13.703 [RX] - + WIND:60:现在处于数据模式 所以,似乎: 1)escape_seq仅更改data->命令序列,但不更改command->数据 2)在命令模式下,你需要发送一个来激活序列,尽管手册说明了相反的情况。 更多信息: ♯nv_model= SPWF01SA1 ♯nv_serial= 3915D31697 ♯版本= 160129-c5bf5ce-SPWF01S 朱塞佩 #x-nucleo-idw01m1#spwf01sa1#escape-sequence 以上来自于谷歌翻译 以下为原文 Hello ST, it seems that the escape_seq parameter does not work as expected in the IDW01M1. There are some discrepancies between the user manual and the obtained results. Please have a look at my transcript: 12:16:15.761 [TX] - at+s.scfg=escape_seq,at+miao 12:16:26.101 [RX] - OK +WIND:61:Incoming Socket Client:192.168.0.218 +WIND:60:Now in Data Mode 12:25:49.307 [TX] - at+miao 12:25:49.807 [RX] - +WIND:59:Back to Command Mode 12:26:05.899 [TX] - at+miao 12:26:10.363 [TX] - at+miao 12:26:13.700 [TX] - AT+S. 12:26:13.703 [RX] - +WIND:60:Now in Data Mode So, it seems that: 1) escape_seq only changes the data->command sequence, but not the command->data 2) when in command mode, you need to send a to activate the sequence, despite the fact that the manual states the opposite. Some more information: ♯ nv_model = SPWF01SA1 ♯ nv_serial = 3915D31697 ♯ version = 160129-c5bf5ce-SPWF01S Giuseppe #x-nucleo-idw01m1 #spwf01sa1 #escape-sequence |
5个回答
Ciao Giuseppe,
转义序列用于退出数据模式。进入命令模式后,您需要运行'at + s'。命令再次返回数据模式。这是一个命令,而不是逃避。 Ĵ 以上来自于谷歌翻译 以下为原文 Ciao Giuseppe, escape sequence is used to exit data mode. Once in command mode, you need to run 'at+s.' command to come back into data mode again. It's a command, not An escape. j |
Ciao Gerardo,
阅读完评论后,我仔细检查了手册。事实上,它证实了你说的话。 也许我可以建议更多地强调描述转义序列的'注释'。无论如何,描述是正确的。 谢谢 G。 以上来自于谷歌翻译 以下为原文 Ciao Gerardo, after reading your comment, I checked carefully the manual. In facts it confirms what you say. Perhaps I can suggest to give some more emphasis to the 'note' that describes escape sequence. Anyway, the description is correct. Thanks G. |
请使用“标记正确”按钮关闭该问题
以上来自于谷歌翻译 以下为原文 Please use 'Mark Correct' button to close the issue |
理解。可能是因为你开了一个'讨论',这不是'问题'。我看到一个不同的图标,没有问号。
没问题 Ĵ 以上来自于谷歌翻译 以下为原文 Understand. Probably because you opened a 'Discussion', that is not a 'Question'. I see a different icon, without question mark. No problem j |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1209 浏览 1 评论
1832 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1498 浏览 1 评论
2724 浏览 6 评论
4945 浏览 21 评论
292浏览 4评论
337浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
263浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
331浏览 3评论
344浏览 3评论
GMT+8, 2024-3-28 19:06 , Processed in 0.825420 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
