扫一扫,分享给好友
大家好我已经检查了EDA文档网站来查找这个,但这只是部分回答了我的问题。
这可能看起来很愚蠢但是如果由于某种原因我需要停止一个长动量模拟,等待一段时间(或看看结果到那一点)然后从我停止的地方重新运行它...是 有可能吗? 我正在攻读MMIC博士学位,我现在的模拟需要几天才能完成,有很多模拟点,所以我想知道是否有任何方法可以“检查”我已经模拟过的点是否告诉我我的设计是否良好 或者不好,不浪费时间,或者让模拟完成......对于EMPro来说也是如此。 关心伊班 以上来自于谷歌翻译 以下为原文 Hi all I've checked the EDA documentation site to look for this but this only partially answered my question. This may look silly but If for some reason i needed to stop a long momentum simulation, wait for some time (or have a look at the results up to that point) and then re-run it from where I stopped it... is it possible? I'm doing a PhD in MMICs, and my present simulations take days to complete, with many simulation points, so I would like to know if there were any means to "check" whether my already simulated points tell me if my design is good or bad, not to waste time, or to let the simulation complete... And same for EMPro. Regards Iban |
6个回答
***5 发表于 2018-9-29 11:04 嗨aehoward。 感谢您的回答!! 我想我没有机会做我想要的,但你的方法更有意义!! 再次感谢。 伊班 以上来自于谷歌翻译 以下为原文 Hi aehoward. Thanks for your answer!! I guess there's no chance to do what i'm asking for, but your approach makes much more sense!! Thanks again. Iban |
> {quote:title = teleko7写道:} {quote}>我正在攻读MMIC博士学位,我现在的模拟需要几天才能完成,有很多模拟点,所以我想知道是否有任何方法可以“
检查“我已经模拟的点是否告诉我,我的设计是好还是坏,不浪费时间,或让模拟完成......具有离散结果的数据集(没有+ _a +后缀)在每个频率点后更新 。 这意味着您可以在模拟期间随时检查现有结果,而无需等待自适应扫描以最终更新插值+ _a +数据集。 以上来自于谷歌翻译 以下为原文 > {quote:title=teleko7 wrote:}{quote} > I'm doing a PhD in MMICs, and my present simulations take days to complete, with many simulation points, so I would like to know if there were any means to "check" whether my already simulated points tell me if my design is good or bad, not to waste time, or to let the simulation complete... The dataset with the discrete results (without the +_a+ suffix) is updated after each frequency point. This means that you can check existing results anytime during simulation, without waiting for adaptive sweep to finally update the interpolated +_a+ dataset. |
lmksa 发表于 2018-9-29 11:27 嗨Volker,谢谢你的回答!! 你提到的文件的位置是哪个? 我已经看过“/ ADS_projects / My_Workspace / simulation / My_Workspace_lib / simulated_layout_name / emModel_MoM”下的“proj_a”文件,但似乎不是S参数文件......顺便说一句,如果我停止正在运行的模拟, 我可以将计算结果直到停止分配给我为原理图创建的模型吗? 我的意思是,我可以创建一个具有空EM模型的组件,并将之前模拟(停止或完成)的结果分配给它吗? 在此先感谢,问候。 伊班 以上来自于谷歌翻译 以下为原文 Hi Volker, thanks for your answer!! Which is the location of the file you mention? I've had a look at the "proj_a" file under "/ADS_projects/My_Workspace/simulation/My_Workspace_lib/simulated_layout_name/emModel_MoM" but doesn seem to be an S parameter file... By the way, if I stop a running simulation, can I assign the results calculated up to the stopping to a model I create for a schematic? I mean, can I create a component with an empty EM model and assign the results from a previous simulation(stopped or finished) to it? Thanks in advance, regards. Iban |
云汉008 发表于 2018-9-29 11:36 > {quote:title = teleko7写道:} {quote}>嗨Volker,谢谢你的回答!! >>您提到的文件的位置是哪个? 我已经看过>>“/ ADS_projects / My_Workspace / simulation / My_Workspace_lib / simulated_layout_name / emModel_MoM”下的“proj_a”文件,但似乎不是S参数文件......没什么特别的,也许你觉得太复杂了 这里。 我假设您已经从emSetup启动了Momentum仿真(而不是间接使用原理图中的空emModel)。 默认情况下,数据集将转到工作空间数据目录,数据显示将在其中找到它们。 文件后缀始终为* .ds。 如果单元格名称为+ simulated_layout_name +并且您已使用Momentum微波模式,则默认数据集名称为离散结果的+ simulated_layout_name_MomUW +,以及自适应扫描的最终插值结果的+ simulated_layout_name_MomUW_a +。 您希望将+ simulated_layout_name_MomUW +与离散频率一起使用,该频率针对每个求解的频率点进行更新。 您可以使用数据块(S2P,S3P,...)读取数据集,只需浏览到* .ds文件,不要忘记将格式从“Touchstone”切换到“数据集”。 >顺便说一下,如果我停止正在运行的模拟,我可以将计算结果直到停止分配给我为原理图创建的模型吗? >我的意思是,我可以使用空EM模型创建一个组件,并将之前模拟(停止或完成)的结果分配给它吗? 我不知道一个简单的方法。 移动和移动可能是可能的。 重命名文件,但不确定。 更简单(直接)的方法是将数据块元素与* .ds文件一起使用。编辑:volker_muehlhaus于2015年6月11日上午4:13 以上来自于谷歌翻译 以下为原文 > {quote:title=teleko7 wrote:}{quote} > Hi Volker, thanks for your answer!! > > Which is the location of the file you mention? I've had a look at the "proj_a" file under > > "/ADS_projects/My_Workspace/simulation/My_Workspace_lib/simulated_layout_name/emModel_MoM" but doesn seem to be an S parameter file... Nothing special, maybe you are thinking too complicated here. I assume that you have started the Momentum simulation from the emSetup (not indirectly with empty emModel from schematic). By default, datasets go to the workspace data directory where data display will find them. File suffix is *.ds as always. If the cell name is +simulated_layout_name+ and you have used Momentum microwave mode, then the default dataset name is +simulated_layout_name_MomUW+ for the discrete results and +simulated_layout_name_MomUW_a+ for the final interpolated results from adaptive sweep. You want to use +simulated_layout_name_MomUW+ with the discrete frequencies, which is updated for every solved frequency point. You can use the data blocks (S2P, S3P, ...) to read a dataset, just browse to the *.ds file and don't forget to switch the format from "Touchstone" to "Dataset". > By the way, if I stop a running simulation, can I assign the results calculated up to the stopping to a model I create for a schematic? > I mean, can I create a component with an empty EM model and assign the results from a previous simulation(stopped or finished) to it? I don't know an easy way to do that. It might be possible by moving & renaming files, but not sure about that. The easier (direct) way is to use the data block element with the *.ds file. Edited by: volker_muehlhaus on Jun 11, 2015 4:13 AM |
lmksa 发表于 2018-9-29 11:41 嗨沃克,再次感谢!!!! 你是对的,我倾向于认为太复杂......太常见! XD明白!! 问候。 伊班 以上来自于谷歌翻译 以下为原文 Hi volker, thanks again!!!! You're right, i tend to think tooo complicate... too often!! XD Understood!! Regards. Iban |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1846 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1547 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
349浏览 0评论
1386浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
262浏览 0评论
2248浏览 0评论
1103浏览 0评论
GMT+8, 2024-3-29 14:44 , Processed in 0.525197 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
