发 帖
原厂入驻New
申请华秋企业认证 多层板首单免费打样!
30s提交资料,10分钟通过审核(免费赔付+顺丰包邮)>>立即报名
[经验] 基于Dragonboard 410c的燃气烟雾检测器(三)
2018-9-28 11:47:50  23030 Qualcomm DragonBoard 检测器
分享
  燃气烟雾检测模块MQ-2在上篇博客中已经写好了,接下来是温湿度检测模块dht11了,模块信息在前面已经介绍过了,这里就不再赘述了,直接看程序:
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/workqueue.h>
#include <linux/slab.h>
#include <linux/input.h>
#include <linux/init.h>
#include <linux/errno.h>
#include <linux/serio.h>
#include <linux/delay.h>
#include <linux/platform_device.h>
#include <linux/clk.h>
#include <linux/wait.h>
#include <linux/sched.h>
#include <linux/cdev.h>
#include <linux/miscdevice.h>
#include <linux/fs.h>
#include <linux/of_gpio.h>
#include <linux/printk.h>
#include <linux/time.h>
#include <linux/irq.h>
#include <asm-generic/uaccess.h>
#define DEVICE_NAME "dht11"
#define DEVICE_MAJOR 0
struct dht11_sensor_dev{
    int pin;
    unsigned char value[5];
    int signal;
    int time;
    int count;
    dev_t devno;
    struct class *dht11_class;
    struct cdev cdev;
    struct mutex read_data;
    struct timeval lasttv;
    struct timeval tv;
    struct work_struct dht11_work;
static struct dht11_sensor_dev *dht11_dev;
static int read_byte(void){
        unsigned char data;
        int i = 0;
    for(i = 0; i < 8; i++){
        while(!gpio_get_value(dht11_dev->pin));
        udelay(30);
        data <<= 1;
        IF(gpio_get_value(dht11_dev->pin) == 1){
            data |=0x01;
            while(gpio_get_value(dht11_dev->pin));
        }else{
            data |=0x00;
    return data;
static void dht11_read(void){
    int i = 0;
    dht11_dev->signal = gpio_get_value(dht11_dev->pin);
    if(dht11_dev->signal == 0){
        for(i = 0; i < 5; i++){
            dht11_dev->value = read_byte();
static int dht11_start(void)
    gpio_direction_output(dht11_dev->pin, 0);
    msleep(20);
    gpio_set_value(dht11_dev->pin,1);
    udelay(20);
    gpio_direction_input(dht11_dev->pin);
    do_gettimeofday(&dht11_dev->lasttv);
    dht11_dev->count=0;
    return 0;
static int dht11_checksum(struct dht11_sensor_dev *dev)
    int tmp = 0;
    tmp = dev->value[0] + dev->value[1] + dev->value[2] + dev->value[3];
    if((tmp != dev->value[4]) || (dev->value[4] == 0) || (tmp == 0) ){
        printk(KERN_INFO "[%s] %d %d\n", __func__, dev->value[4], tmp);
        return -1;
    return 1;
static int dht11_sensor_open(struct inode *inode, struct file *filp)
    printk("dht11_sensor_open\n");
    return 0;
static ssize_t dht11_sensor_read(struct file *filp,char __user *buf,size_t
size,loff_t *f_pos)
    int result = 0;
    dht11_dev->value[0] = 0;
    dht11_dev->value[1] = 0;
    dht11_dev->value[2] = 0;
    dht11_dev->value[3] = 0;
    dht11_dev->value[4] = 0;
    printk("dht11_sensor_read\n");
    dht11_start();
    dht11_read();
    msleep(10);
    result=dht11_checksum(dht11_dev);
    if(result<0)
            return -EAGAIN;
    printk("---Humidity=%d.%d%%RH\n---Temperature=%d.%dC\n",\
            dht11_dev->value[0], dht11_dev->value[1], \
            dht11_dev->value[2], dht11_dev->value[3]);
    result=copy_to_user(buf,&dht11_dev->value,4);
    if(result<0)
         printk("copy to user err\n");
         return -EAGAIN;
    return  result;
static int dht11_sensor_release(struct inode *inode,struct file *filp)
    module_put(THIS_MODULE);
    return 0;
static struct file_operations dht11_sensor_fops={
    .owner   = THIS_MODULE,
    .open    = dht11_sensor_open,
    .read    = dht11_sensor_read,
    .release = dht11_sensor_release,
//static int dht11_gpio_init(void)
static int parse_dt (struct platform_device *pdev,struct dht11_sensor_dev *data){
    int result;
    struct device_node *node = pdev->dev.of_node;
    data->pin = of_get_named_gpio(node,"thunder,gpio_data",0);
    if(gpio_is_valid(data->pin)){
    result=gpio_request(data->pin, "dht11_gpio");
    if(result)
        printk(KERN_INFO "[%s] gpio_request \n", __func__);
        return -1;
    gpio_direction_output(data->pin,1);
    return 0;
static int dht11_sensor_setup_cdev(void)
    int ret;
    cdev_init(&(dht11_dev->cdev), &dht11_sensor_fops);
    dht11_dev->cdev.owner = THIS_MODULE;
    ret=cdev_add(&(dht11_dev->cdev),dht11_dev->devno, 1);
    if(ret)
        printk(KERN_NOTICE"erro %d adding %s\n",ret,DEVICE_NAME);
    return ret;
static int dht11_probe(struct platform_device *pdev){
    int result;
    dht11_dev=kmalloc(sizeof(struct dht11_sensor_dev),GFP_KERNEL);
    if(!dht11_dev)
        result=-ENOMEM;
        goto allocate_memory_fail;
    if(DEVICE_MAJOR)
        result = register_chrdev_region(dht11_dev->devno, 1, DEVICE_NAME);
    else
        result = alloc_chrdev_region(&dht11_dev->devno, 0, 1, DEVICE_NAME);
    if(result < 0)
        printk("register_chrdev_region err!\n");
        goto chardev_region_fail;
    dht11_dev->dht11_class = class_create(THIS_MODULE, DEVICE_NAME);
    if(IS_ERR(dht11_dev->dht11_class))
             printk("Err: faiLED in creating class.\n");
             goto class_create_fail;
    device_create(dht11_dev->dht11_class, NULL,dht11_dev->devno, NULL,
DEVICE_NAME);
    result = parse_dt(pdev,dht11_dev);
    if(result<0)
        goto gpio_request_fail;
    result=dht11_sensor_setup_cdev();
    if(result<0)
        goto cdev_fail;
    mutex_init(&dht11_dev->read_data);
    printk("dht11 init ok!\n");
    return 0;
gpio_request_fail:
    cdev_del(&dht11_dev->cdev);
cdev_fail:
    device_destroy(dht11_dev->dht11_class,dht11_dev->devno);
    class_destroy(dht11_dev->dht11_class);
class_create_fail:
    unregister_chrdev_region(dht11_dev->devno,1);
chardev_region_fail:
allocate_memory_fail:
    kfree(dht11_dev);
    return result;
static int dht11_remove(struct platform_device *pdev)
    unregister_chrdev_region(dht11_dev->devno, 1);
    kfree(dht11_dev);
    return 0;
static struct of_device_id dht11_match_table[] = {
    { .compatible = "thunder,dht11",},
static struct platform_driver dht11_driver = {
    .probe = dht11_probe,
    .remove = dht11_remove,
    .driver = {
        .name = DEVICE_NAME,
        .of_match_table = dht11_match_table,
module_platform_driver(dht11_driver);
MODULE_AUTHOR("wi");
MODULE_DESCRIPTION("DHT11 Driver");
MODULE_LICENSE("GPL");
这个模块用的是单总线,所以时序要特别注意一下,设备节点:/dev/dht11
为了检测数据的正确性,以及节点是否可用,写了下面一个小程序进行测试
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include <errno.h>
#include <string.h>
int main(){
    int fd;
    int ret;
    int i = 0;
    unsigned char buf[4];
    fd = open("/dev/dht11", O_RDONLY);
    if(fd < 0){
        printf("open the dht11 id failed\n");
        return fd;
    ret = read(fd, buf, 4);
    if(ret < 0){                 //下面三个输出可以了解一下,对于打开,读写节点失败的调试很有帮助的。
        printf("errno= %d\n", errno);
        printf("Mesg----%s\n",strerror(errno));
        perror("read failed");
        return ret;
    printf("---Humidity=%d.%d%%RH\n---Temperature=%d.%dC\n", buf[0], buf[1], buf[2], buf[3]);
    close(fd);
    return 0;
经过测试是没有问题的。到此温湿度检测模块dht11的底层驱动也完成了。
只有小组成员才能发言,加入小组>>
45个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /10 下一条
快速回复 返回顶部 返回列表
