嗨,
我们目前正在设置它,并在VM中的VGPU配置文件遇到一些问题。 安装了XenServer 6.5,我们目前正在Win 7 SP1上构建主映像。 禁用VGA标准适配器并在Windows上安装NVidia 341.08。 Windows确实可以看到NVIDIA控制面板,并且可以看到已提供的VGPU配置文件。 问题是当我们运行Autodesk REVIT时,程序看不到VGPU,因此当我们选择renderingen时,我们似乎看不到VGPU监视器正在工作。 主机上的CPU确实很高。 因此我们误以为VM正在使用CPU而不是VGPU来进行渲染。 我们试图给出VM不同的配置文件并对其进行测试,但问题是相同的。 我们也尝试过使用BLENDER验证是否是Autodesk的问题。 在COMPUTE DEVICE下的Blender选项下,我们只能看到CPU。 因此,我认为我们所做的设置肯定有问题。 从XenCenter和VM中我们可以一直查看VGPU配置文件,设置似乎是正确的,VM也可以执行VGPU控制面板。 有什么想法来解决这个问题? 好多了! 以上来自于谷歌翻译 以下为原文 Hi, We are currently setting this up and met some trouble with the VGPU profiles in VMs. XenServer 6.5 is installed, we are currently building master image on Win 7 SP1. VGA standar adapter is disabled and NVidia 341.08 is installed on the Windows. Windows does see the NVIDIA control panel and the see the VGPU profile that have been provided. The problem is when we are running Autodesk REVIT, the program doesn´t see the VGPU and therefore when we choose renderingen we can´t seem to see the VGPU monitor is working at all. CPU on the host does goes really high up. So we are mistaking that the VM are using the CPU instead of VGPU for renderingen. We have tried to give the VM differents profiles and tested this out but the problem is the same. We did also tried with BLENDER to verify if it is Autodesk is the problem. Under Blender options under COMPUTE DEVICE we can only see CPU. So therefore i think there must something wrong with the setup that we did. From XenCenter and within the VMs we can se the VGPU profile all the way, the settings seems to be correct and the VMs does the the VGPU control panel too. Any idees to solve this? Much appricated! |
6个回答
如果在您的XenServer上运行的nvidia-smi未显示任何活动,则无论您运行什么,都可能在VM上安装驱动程序时出现问题。
您可以在VM上运行NVIDIA配置应用程序并验证您是否可以检查/更改任何设置? 此外,您是否安装了正确的XenServer许可证? 请参阅:https://gridforums.nvidia.com/default/topic/387/xendesktop-with-nvidia-grid/xs-6-5-and-vgpu-not-seeing-vgpu-profiles-in-console/ 以上来自于谷歌翻译 以下为原文 If nvidia-smi run on your XenServer isn't showing any activity, no matter what you run, there is likely an issue with the installation of the driver on the VM. Can you run the NVIDIA configuration application on the VM itself and verify you can check/change any of the settings? Also, do you have the right XenServer license required installed? See: https://gridforums.nvidia.com/default/topic/387/xendesktop-with-nvidia-grid/xs-6-5-and-vgpu-not-seeing-vgpu-profiles-in-console/ |
嗨,
回复晚了非常抱歉。 我在youtube上按照检查配置,看到了一些怪异的东西。 当我运行DXDIAG时,VM可以在directX enable中看到所有3个选项。 但是当我打开Nvidia控制面板时 我在3D设置下错过了PhysX配置,这样我似乎无法在GLOBAL SETTINGS下看到CUDA选项。 以下是我的NVIDIA-SMI的屏幕截图: [root @ a20-p1-xen001~] #nvidia-smi 2015年2月6日星期五11:00:32 + ------------------------------------------------- ----- + | NVIDIA-SMI 340.57驱动程序版本:340.57 | | ------------------------------- + ----------------- ----- + ---------------------- + | GPU名称持久性-M | Bus-Id Disp.A | 挥发性的Uncorr。 ECC | | Fan Temp Perf Pwr:用法/上限| 内存使用| GPU-Util Compute M. | | =============================== + ================= ===== + ====================== | | 0 GRID K2开| 0000:05:00.0关闭| 关| | N / A 34C P8 27W / 117W | 2000MiB / 4095MiB | 0%默认值| + ------------------------------- + ----------------- ----- + ---------------------- + | 1 GRID K2开| 0000:06:00.0关闭| 关| | N / A 33C P8 27W / 117W | 1869MiB / 4095MiB | 0%默认值| + ------------------------------- + ----------------- ----- + ---------------------- + | 2 GRID K2开| 0000:84:00.0关| 关| | N / A 34C P8 28W / 117W | 12MiB / 4095MiB | 0%默认值| + ------------------------------- + ----------------- ----- + ---------------------- + | 3 GRID K2开| 0000:85:00.0关闭| 关| | N / A 31C P8 27W / 117W | 12MiB / 4095MiB | 0%默认值| + ------------------------------- + ----------------- ----- + ---------------------- + + ------------------------------------------------- ---------------------------- + | 计算过程:GPU内存| | GPU PID进程名称用法| | ================================================= ============================ | | 0 10719 / usr / lib64 / xen / bin / vgpu 1856MiB | + ------------------------------------------------- ---------------------------- + 以上来自于谷歌翻译 以下为原文 Hi, Sorry for the late response. I have follow the check configuration on youtube and saw somehitng weird. When i run DXDIAG, the VM can see all 3 options in directX enable. But when I open Nvidia Control panel I was missing the PhysX configuration under 3D settings, with this I can't seem to see the CUDA options either under GLOBAL SETTINGS. Here are screenshot of my NVIDIA-SMI: [root@a20-p1-xen001 ~]# nvidia-smi Fri Feb 6 11:00:32 2015 +------------------------------------------------------+ | NVIDIA-SMI 340.57 Driver Version: 340.57 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | |===============================+======================+======================| | 0 GRID K2 On | 0000:05:00.0 Off | Off | | N/A 34C P8 27W / 117W | 2000MiB / 4095MiB | 0% Default | +-------------------------------+----------------------+----------------------+ | 1 GRID K2 On | 0000:06:00.0 Off | Off | | N/A 33C P8 27W / 117W | 1869MiB / 4095MiB | 0% Default | +-------------------------------+----------------------+----------------------+ | 2 GRID K2 On | 0000:84:00.0 Off | Off | | N/A 34C P8 28W / 117W | 12MiB / 4095MiB | 0% Default | +-------------------------------+----------------------+----------------------+ | 3 GRID K2 On | 0000:85:00.0 Off | Off | | N/A 31C P8 27W / 117W | 12MiB / 4095MiB | 0% Default | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Compute processes: GPU Memory | | GPU PID Process name Usage | |=============================================================================| | 0 10719 /usr/lib64/xen/bin/vgpu 1856MiB | +-----------------------------------------------------------------------------+ |
对于vGPU的正确设置,一切似乎都很好,当我们从NVIDIA UNIGINE Heaven中获得基准时,我们可以看到VGPU卡工作正常。
即使在REVIT中,硬件加入是活动的,Te程序似乎也找不到vgpu-profile。 我还试图给它VGPU传递并安装REVIT需要的驱动器,但是我不能在XenCenter中为vGPU传递卡提供Performance TAB。 感谢你的宝贵时间! 以上来自于谷歌翻译 以下为原文 Everything seems fine with the correct settings for vGPU, When we runed benchmark from NVIDIA UNIGINE Heaven, We can see the VGPU card working properlies. Even though in REVIT, the hardware accelation are active, Te program can't seems to find the vgpu-profile. I also tried to give it VGPU pass through and intalled the drivere that REVIT require, but hen I can't se the Performance TAB for the vGPU pass though card in XenCenter. Thanks again for your time! |
这是预期的,CUDA和PhysX仅适用于GPU直通配置,而不是vGPU。
因此,如果您为vGPU设置,您将无法在Nvidia控制面板中看到它们的选项。 此外,我需要更新该视频,因为与XenServer 6.5一起使用时XenApp行为已更改 以上来自于谷歌翻译 以下为原文 That's expected, CUDA and PhysX are only available with GPU passthrough configurations, not vGPU. So if you're set up for vGPU you won't see options for them in the Nvidia Control panel. Also, I need to update that video as XenApp behaviour has changed when used with XenServer 6.5 |
谢谢杰森!
我们在使用Nvidia驱动程序341.08的Xenserver 6.5上使用Autodesk应用程序进行了一些发现。 显然,就像今天一样,Autodesk不支持Xenserver 6.5上341.08的图形驱动程序。 因此,我们在安装和打开AutoCAD等应用程序时遇到了很多麻烦。 我们等待更新的驱动程序版本真是太遗憾了。 为了使其在XenServer 6.5上运行,我们必须为其提供Pass Through GPU并为Windows 7安装旧版驱动程序(如332.83)并等待Autodeks的修复。 我们已经与他们打开了一个案例,正在等待他们的回复。 以上来自于谷歌翻译 以下为原文 Thanks Jason! We have maid some discovery with the Autodesk applicationon Xenserver 6.5 with Nvidia driver 341.08. Apperently as for today Autodesk doesn't support for the graphic driver for 341.08 on Xenserver 6.5. Therefore we had a lot of trouble with installing and opened the application like AutoCAD. What a shame for us to wait for a updated driver version. In order to make this work on XenServer 6.5 we have to give it Pass Through GPU and installed older driver like 332.83 for Windows 7 and wait for the fix from Autodeks. We have already an open case with them on this, and are waiting for reply from them. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2818 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3212 浏览 4 评论
2238浏览 0评论
GMT+8, 2024-3-29 14:48 , Processed in 0.608058 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
