我在CYW943907AEV1F平台上使用WICED Studio.1。
我不能成功运用olimex_ARM-u***-tiny-h在wiced-studio-6.1下载图像(windows10)。 但是WICED Studio-6可以成功下载。 失败OpenCOD日志如下; ----------------------------------------------------------------------------------------------------------------------------------------------- 打开芯片调试器0.10.0 + dev-00225-ga9a9861c(2018-02-06-09:36) GNU GPL V2授权 对于bug报告,请阅读 HTTP://OpenCord.Org/DoC/doxGeung/Bugs.HTML trst_and_srst单独srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst trst_and_srst单独srst_nogate trst_push_pull srst_open_drain connect_assert_srst 适配器速度:100千赫 AdvultNSRSTSTORD延迟:100 信息:自动选择第一个可用的会话传输“JTAG。重写使用“传输选择& lt;传输& gt;”。 JTAGYNTSTSTRY延迟:100 Posi-InITIPSoS66-设置 错误:LIUBBSUPEN()失败了 错误:libu***_open()失败,libu***_error_access 错误:没有找到设备 错误:无法打开视频15ba,FTDI装置PID 002a,描述的olimex OpenOCD JTAG串行arm-u***-tiny-h ',' * '在公共汽车的位置* ----------------------------------------------------------------------------------------------------------------------------------------------- 以上来自于百度翻译 以下为原文 I am using WICED-Studio-6.1 on CYW943907AEVAL1F platform. I can't succeed to download the image using by using Olimex_ARM-USB-TINY-H on WICED-Studio-6.1 (Windows10). but WICED-Studio-6.0 can download successfully. The failure OpenOCD log is as follows; ----------------------------------------------------------------------------------------------------------------------------------------------- Open On-Chip Debugger 0.10.0+dev-00225-ga9a9861c (2018-02-06-09:36) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst trst_and_srst separate srst_nogate trst_push_pull srst_open_drain connect_assert_srst adapter speed: 100 kHz adapter_nsrst_delay: 100 Info : auto-selecting first available session transport "jtag". To override use 'transport select jtag_ntrst_delay: 100 post_init_psoc6_setup Error: libu***_open() failed with LIBUSB_ERROR_NOT_SUPPORTED Error: libu***_open() failed with LIBUSB_ERROR_ACCESS Error: no device found Error: unable to open ftdi device with vid 15ba, pid 002a, description 'Olimex OpenOCD JTAG ARM-USB-TINY-H', serial '*' at bus location '*' ----------------------------------------------------------------------------------------------------------------------------------------------- |
3个回答
OLIMEXARMA-UB-TiNY-H使用的驱动程序是什么?请使用43xxxWi-Fi/Too/OpenCd/OLimeXeRead .txt中提到的驱动程序,并提供您所看到的错误消息。(下载的DCT错误?)
相关帮助文章:OpenOCD-WICE 以上来自于百度翻译 以下为原文 What is the driver that you are using for Olimex_ARM-USB-TINY-H ? Please use the driver mentioned in 43xxx_Wi-Fi/tools/OpenOCD/Olimex_README.txt and also provide the error message that you are seeing. (download_dct error? ) Relevant help article: OpenOCD -WICED |
chm5 发表于 2018-9-27 14:53 谢谢你的回答。 使用驱动程序是LIUBB-Win32 V1.1.2.6。 错误信息如下; ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 构建应用程序查找表 WICES/平台/MCU/BCM4390X/BCM94390XO目标。MK:340:目标“下载DCT”失败的配方 使.exe〔1〕:*** [下载负荷dCT]错误1 Ex.EXE(1):***等待未完成的工作… MaFixFiel: 349:目标“MeNIApp”失败的配方 使:***[MNIONAPP]错误2 ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 以上来自于百度翻译 以下为原文 Thank you for the answer. Use driver is libu***-win32 Ver1.2.6. Error message is as follows; ----------------------------------------------------------------------------------------------------------------------------------------------- Building apps lookup table WICED/platform/MCU/BCM4390x/BCM94390x_targets.mk:340: recipe for target 'download_dct' failed make.exe[1]: *** [download_dct] Error 1 make.exe[1]: *** Waiting for unfinished jobs.... Makefile:349: recipe for target 'main_app' failed make: *** [main_app] Error 2 ----------------------------------------------------------------------------------------------------------------------------------------------- |
我假设SW4的状态都在进行,那么你也正在接收这个错误吗?我用61.0.85 SDK进行测试,并且能够在没有手动更新驱动程序的情况下成功下载。对于您的情况,您可以尝试更新驱动程序,通过选择在Windows 10 PC上更新的软件自动搜索选项,如果您已经按照OpenOCD-Wrice中所提到的正确地遵循所有步骤,您应该能够下载。 以上来自于百度翻译 以下为原文 I am assuming status of the SW4 is all ON and then also you are receiving this error? I tested with 6.1.0.85 SDK and I was able to download successfully without manually updating the driver. For your case, you can try updating the driver by choosing the option of search automatically for the updated software in your WINDOWS 10 PC and you should be able to download if you have followed all the steps correctly as mentioned in OpenOCD -WICED |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1653 浏览 1 评论
3406 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
188浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
324浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-25 07:19 , Processed in 0.642102 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
