嗨,我正在使用带有1xGrid K2的Dell R730 Rack Server和带有Blast Extreme的vmware Horizon(所有虚拟机都在Active Directory中)7.3。
鼠标在FPS游戏中无法正常工作,当我启用相对鼠标时,由于延迟,它无法正常工作。 它不适用于具有与Horizon相同配置的Tesla m60卡的Super Micro服务器。 有没有其他程序或其他东西来解决这个问题? 以上来自于谷歌翻译 以下为原文 Hi, I am using Dell R730 Rack Server with 1xGrid K2, and vmware Horizon(all VMs are in Active Directory) 7.3 with Blast Extreme. The mouse are not working properly in FPS games, when i enabled relative mouse, it is not working either because of the latency. Its not working in Super Micro server with Tesla m60 card with the same configuration of Horizon. Is there any other program or something else to solve this problem? |
3个回答
你好
这可能不会是你所追求的,因为你已经特别提到了Horizon,但我已经使用XenDesktop来玩“使命召唤”,“光环”以及其他带有鼠标和游戏的游戏和模拟器。 键盘(相对鼠标)或XBox 360控制器,它是完美的。 如果你有时间,那么下载一个XenDesktop 7.15的演示,在单个服务器上进行整合安装,这样它很好而且快速,只需要一个虚拟机并尝试一下。 抱歉,我不使用Horizon,因此无法提供有关Blast的任何建议。 以上来自于谷歌翻译 以下为原文 Hi This probably won't be what you're after, as you've specifically mentioned Horizon, but I've used XenDesktop to play Call of Duty, Halo and other games and simulators with Mouse & Keyboard (relative mouse) or an XBox 360 Controller and it's perfect. If you have time, then download a demo of XenDesktop 7.15, do a consolidated install all on single server so it's nice and quick and only takes up a single VM and give it a try. Sorry, but I don't use Horizon so am not able to offer any advice about Blast. |
嗨,
谢谢,我将看看Xendesktop。 Nvidia是否提供用于流式传输桌面的任何工具/程序? 据我所知,vmware或xendesktop都使用Nvidia API进行流式传输。 你知道其他选择吗? 以上来自于谷歌翻译 以下为原文 Hi, Thanks, I will take a look at the Xendesktop. Does Nvidia provide any tool/program for streaming the desktop? As far as i know, vmware or xendesktop are both using Nvidia APIs to stream. Do you know any alternatives? |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2831 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3225 浏览 4 评论
GMT+8, 2024-4-24 01:47 , Processed in 0.557889 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
