使用开发板的晶振 tx和rx pll 无法锁定 配置程序如下
SPIWrite 009,07 // Enable Clocks use crystal WAIT 20 // waits 20 ms //************************************************************ // Setup Rx Frequency-Dependent Syntheisizer Registers //************************************************************ SPIWrite 23A,4A // Set VCO Output level[3:0] SPIWrite 239,C0 // Set Init ALC Value[3:0] and VCO Varactor[3:0] SPIWrite 242,17 // Set VCO Bias Tcf[1:0] and VCO Bias Ref[2:0] SPIWrite 238,40 // Set VCO Cal Offset[3:0] SPIWrite 245,00 // Set VCO Cal Ref Tcf[2:0] SPIWrite 251,00 // Set VCO Varactor Reference[3:0] SPIWrite 250,70 // Set VCO Varactor Ref Tcf[2:0] and VCO Varactor Offset[3:0] SPIWrite 23B,A4 // Set Synth Loop Filter charge pump current (Icp) SPIWrite 23E,D4 // Set Synth Loop Filter C2 and C1 SPIWrite 23F,DF // Set Synth Loop Filter R1 and C3 SPIWrite 240,09 // Set Synth Loop Filter R3 //************************************************************ // Setup Tx Frequency-Dependent Syntheisizer Registers //************************************************************ SPIWrite 27A,4A // Set VCO Output level[3:0] SPIWrite 279,C0 // Set Init ALC Value[3:0] and VCO Varactor[3:0] SPIWrite 282,17 // Set VCO Bias Tcf[1:0] and VCO Bias Ref[2:0] SPIWrite 278,40 // Set VCO Cal Offset[3:0] SPIWrite 285,00 // Set VCO Cal Ref Tcf[2:0] SPIWrite 291,00 // Set VCO Varactor Reference[3:0] SPIWrite 290,70 // Set VCO Varactor Ref Tcf[2:0] and VCO Varactor Offset[3:0] SPIWrite 27B,A4 // Set Synth Loop Filter charge pump current (Icp) SPIWrite 27E,D4 // Set Synth Loop Filter C2 and C1 SPIWrite 27F,DF // Set Synth Loop Filter R1 and C3 SPIWrite 280,09 // Set Synth Loop Filter R3 SPIWrite 233,F8 // Write Rx Synth Fractional Freq Word[7:0] SPIWrite 234,FF // Write Rx Synth Fractional Freq Word[15:8] SPIWrite 235,3F // Write Rx Synth Fractional Freq Word[22:16] SPIWrite 232,00 // Write Rx Synth Integer Freq Word[10:8] SPIWrite 231,52 // Write Rx Synth Integer Freq Word[7:0] SPIWrite 005,00 // Set LO divider setting SPIWrite 273,F8 // Write Tx Synth Fractional Freq Word[7:0] SPIWrite 274,FF // Write Tx Synth Fractional Freq Word[15:8] SPIWrite 275,3F // Write Tx Synth Fractional Freq Word[22:16] SPIWrite 272,00 // Write Tx Synth Integer Freq Word[10:8] SPIWrite 271,52 // Write Tx Synth Integer Freq Word[7:0] (starts VCO cal) SPIWrite 005,00 // Set LO divider setting SPIRead 247 // Check RX RF PLL lock status (0x247[1]==1 is locked) SPIRead 287 // Check TX RF PLL lock status (0x287[1]==1 is locked) |
8个回答
楼主问题解决了吗?我也遇到这样的问题==
你问题解决了吗?我也碰到这个问题。 1.硬件没有问题,fdd 模式,ensm管脚控制,spi读写脚本有用,bbp pll已经锁定,rx tx 校准也已经锁定了,即0x244[7] 和0x284[7]已经置高,但是0x247[1]一直读不到锁定置位,不明白哪里出了问题!有人能告诉我吗? |
收发本振要正常工作,需要检查几个地方:
1. 首先, 需检查晶体是否起振. 晶体和外部晶振不同, 晶体是两个管脚接到9361的XTAL_P和XTAL_N, 需要芯片内部的DCXO协同工作才能起振, 而外部晶振是一个管脚接到9361的XTAL_N端, 不需要芯片内部的DCXO模块参与工作. 下面是两个例子分别是用晶体和外部晶振需要配置的寄存器, 可以看出使用晶体时需要调节0x292-0x294寄存器 关于DCXO的应用文档可参阅下述链接 AD9361晶振的问题 ******************************************************************************* //example1 using DCXO SPIWrite 2A6,0E // Enable Master Bias SPIWrite 2A8,0E // Set Bandgap Trim SPIWrite 292,08 // Set DCXO Coarse Tune[5:0]. Coarse and Fine nominal values used with eval system. Other nominal values may be needed in a customer system SPIWrite 293,80 // Set DCXO Fine Tune [12:5] SPIWrite 294,00 // Set DCXO Fine Tune [4:0] SPIWrite 2AB,07 // Set RF PLL reflclk scale to REFCLK * 2 SPIWrite 2AC,FF // Set RF PLL reflclk scale to REFCLK * 2 SPIWrite 009,07 // Enable Clocks WAIT 20 // waits 20 ms ******************************************************************************* //example2 don't use DCXO SPIWrite 2A6,0E // Enable Master Bias SPIWrite 2A8,0E // Set Bandgap Trim SPIWrite 2AB,07 // Set RF PLL reflclk scale to REFCLK * 2 SPIWrite 2AC,FF // Set RF PLL reflclk scale to REFCLK * 2 SPIWrite 009,17 // Enable Clocks WAIT 20 // waits 20 ms ******************************************************************************* 2.确定参考输入的分频/倍频设置以确定射频本振的鉴相频率 即上述例子中的0x2AB和0x2AC寄存器: SPIWrite 2AB,07 // Set RF PLL reflclk scale to REFCLK * 2 SPIWrite 2AC,FF // Set RF PLL reflclk scale to REFCLK * 2 这个例子是将参考输入进行倍频. 3. 设置VCO LDO, VCO校正等与频率无关的寄存器 (NOTE: 例子中除了SPIWrite命令是寄存器设置外, 其他命令如WAIT... ; WAIT_CALDONE等都是用于等待时间的宏命令, 需根据自己软件平台的指令进行修改) //************************************************************ // Setup RF PLL non-frequency-dependent registers //************************************************************ SPIWrite 261,00 // Set Rx LO Power mode SPIWrite 2A1,00 // Set Tx LO Power mode SPIWrite 248,0B // Enable Rx VCO LDO SPIWrite 288,0B // Enable Tx VCO LDO SPIWrite 246,02 // Set VCO Power down TCF bits SPIWrite 286,02 // Set VCO Power down TCF bits SPIWrite 249,8E // Set VCO cal length SPIWrite 289,8E // Set VCO cal length SPIWrite 23B,80 // Enable Rx VCO cal SPIWrite 27B,80 // Enable Tx VCO cal SPIWrite 243,0D // Set Rx prescaler bias SPIWrite 283,0D // Set Tx prescaler bias SPIWrite 23D,00 // Clear Half VCO cal clock setting SPIWrite 27D,00 // Clear Half VCO cal clock setting SPIWrite 015,0C // Set Dual Synth mode bit SPIWrite 014,15 // Set Force ALERT State bit SPIWrite 013,01 // Set ENSM FDD mode WAIT 1 // waits 1 ms SPIWrite 23D,04 // Start RX CP cal WAIT_CALDONE RXCP,100 // Wait for CP cal to complete, Max RXCP Cal time: 480.000 (us)(Done when 0x244[7]==1) SPIWrite 27D,04 // Start TX CP cal WAIT_CALDONE TXCP,100 // Wait for CP cal to complete, Max TXCP Cal time: 480.000 (us)(Done when 0x284[7]==1) 4. 设置跟射频频率相关的频综寄存器 即你文中的两段VCO和环路滤波器设置: //************************************************************ // Setup Rx Frequency-Dependent Syntheisizer Registers //************************************************************ SPIWrite 23A,4A // Set VCO Output level[3:0] SPIWrite 239,C0 // Set Init ALC Value[3:0] and VCO Varactor[3:0] SPIWrite 242,17 // Set VCO Bias Tcf[1:0] and VCO Bias Ref[2:0] SPIWrite 238,40 // Set VCO Cal Offset[3:0] SPIWrite 245,00 // Set VCO Cal Ref Tcf[2:0] SPIWrite 251,00 // Set VCO Varactor Reference[3:0] SPIWrite 250,70 // Set VCO Varactor Ref Tcf[2:0] and VCO Varactor Offset[3:0] SPIWrite 23B,A4 // Set Synth Loop Filter charge pump current (Icp) SPIWrite 23E,D4 // Set Synth Loop Filter C2 and C1 SPIWrite 23F,DF // Set Synth Loop Filter R1 and C3 SPIWrite 240,09 // Set Synth Loop Filter R3 //************************************************************ // Setup Tx Frequency-Dependent Syntheisizer Registers //************************************************************ SPIWrite 27A,4A // Set VCO Output level[3:0] SPIWrite 279,C0 // Set Init ALC Value[3:0] and VCO Varactor[3:0] SPIWrite 282,17 // Set VCO Bias Tcf[1:0] and VCO Bias Ref[2:0] SPIWrite 278,40 // Set VCO Cal Offset[3:0] SPIWrite 285,00 // Set VCO Cal Ref Tcf[2:0] SPIWrite 291,00 // Set VCO Varactor Reference[3:0] SPIWrite 290,70 // Set VCO Varactor Ref Tcf[2:0] and VCO Varactor Offset[3:0] SPIWrite 27B,A4 // Set Synth Loop Filter charge pump current (Icp) SPIWrite 27E,D4 // Set Synth Loop Filter C2 and C1 SPIWrite 27F,DF // Set Synth Loop Filter R1 and C3 SPIWrite 280,09 // Set Synth Loop Filter R3 5. 设置跟射频频率相关的频率控制字寄存器和输出分频 即你文中的这段: SPIWrite 233,F8 // Write Rx Synth Fractional Freq Word[7:0] SPIWrite 234,FF // Write Rx Synth Fractional Freq Word[15:8] SPIWrite 235,3F // Write Rx Synth Fractional Freq Word[22:16] SPIWrite 232,00 // Write Rx Synth Integer Freq Word[10:8] SPIWrite 231,52 // Write Rx Synth Integer Freq Word[7:0] SPIWrite 005,00 // Set LO divider setting SPIWrite 273,F8 // Write Tx Synth Fractional Freq Word[7:0] SPIWrite 274,FF // Write Tx Synth Fractional Freq Word[15:8] SPIWrite 275,3F // Write Tx Synth Fractional Freq Word[22:16] SPIWrite 272,00 // Write Tx Synth Integer Freq Word[10:8] SPIWrite 271,52 // Write Tx Synth Integer Freq Word[7:0] (starts VCO cal) SPIWrite 005,00 // Set LO divider setting 6. 检查射频PLL是否锁定 SPIRead 247 // Check RX RF PLL lock status (0x247[1]==1 is locked) SPIRead 287 // Check TX RF PLL lock status (0x287[1]==1 is locked) |
1 条评论
msvsudsdf 发表于 2018-9-26 08:27 您好。我的配置信息是按照您所讲的配置顺序进行的,在调试过程中,我检测到A12脚TX_EXT_LO有稳定的电压输出大概在1.3V左右。这是不是说明我的LO已经锁定了?就是这个管脚的稳定电压与我配置的本振频率的关系是什么样的啊?我在文档中没有找到……然后我在没有给发射管脚写入信号数据的时候,将9361工作模式调至FDD下,可以用频谱分析仪测到本振泄露吗?测不到是正常的吗?谢谢,希望能得到你的答复…… |
zsqzsqzs 发表于 2018-9-26 08:42 A12是TX外部本振输入管脚, 跟内部本振是否锁定无关. 在没有送发射数据情况下, 发射端口接频谱仪应该能看到本振泄露 |
你问题解决了吗?我也碰到这个问题。 1.硬件没有问题,fdd 模式,ensm管脚控制,spi读写脚本有用,bbp pll已经锁定,rx tx 校准也已经锁定了,即0x244[7] 和0x284[7]已经置高,但是0x247[1]一直读不到锁定置位,不明白哪里出了问题!有人能告诉我吗?我是拿软件直接生成的寄存器脚本。 |
msvsudsdf 发表于 2018-9-26 08:27 你问题解决了吗?我也碰到这个问题。 1.硬件没有问题,fdd 模式,ensm管脚控制,spi读写脚本有用,bbp pll已经锁定,rx tx 校准也已经锁定了,即0x244[7] 和0x284[7]已经置高,但是0x247[1]一直读不到锁定置位,不明白哪里出了问题!有人能告诉我吗? |
3 条评论
你好,009设置后,为什么要wait 20ms?我用的晶体,在官网下的源码中没有见到wait,也就没有加,然后bbpll就没有锁定~
只有小组成员才能发言,加入小组>>
ADP5092 SYS端口为2.09V,但是REG_OUT为0是什么原因?
1307 浏览 1 评论
ad7193差分输入ain1与ain2差是正值时,读到电压与实际值误差小,但为负值值,误差就变的很大
3932 浏览 2 评论
8595 浏览 1 评论
2919 浏览 1 评论
6717 浏览 2 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
715浏览 3评论
AD7190状态寄存器一直是0x80,连续转换模式下RDY不拉低
1035浏览 2评论
3932浏览 2评论
963浏览 2评论
746浏览 1评论
GMT+8, 2024-4-24 21:09 , Processed in 0.569064 second(s), Total 57, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
