您好,我正在使用网络分析仪(PNA-L N5230A 4端口)使用FOM选项80进行一些频率偏移测量。为了验证测量校正,我首先测量混频器的转换损耗,遵循在线帮助
(应用 - >频率偏移 - >转换损耗),版本A.09.90。 混频器是MiniCircuits ZX05-153LH +。 我将R3(port3)设置为混音器的输入,将D(port4)设置为混音器的输出。 结果总是D显示大于R3大约12 dB,这根据混频器规格是不正确的。 我尝试了其他端口作为输入和输出,但仍然得到相同的结果。 然后我使用单独的频谱分析仪读取混频器的输出,仍然使用R3(port3)作为混频器的输入。 在这种情况下,我可以获得正确的转换损失值。 有人能给我一些关于这种测量的建议吗? 下一步,我想使用FOM选项来测量我的频率转换设备的幅度和相位。 有没有一种很好的方法来进行这种测量? 我的网络分析仪上是否有FCA选项83? 谢谢。 夹克 以上来自于谷歌翻译 以下为原文 Hello, I am using the Network Analyzer (PNA-L N5230A 4-port) to do some frequency offset measurement with the FOM option 80. In order to verify the measurement correction, I first measure the conversion loss of mixer, following the online help (Application->Frequency Offset->Conversion Loss) , version A.09.90. The mixer is MiniCircuits ZX05-153LH+. I set R3 (port3) as the input of the mixer and D (port4) as the output of the mixer. The result is always D display larger than R3 about 12 dB, which is not correct based on the mixers specification. I tried the other ports as the input and output, but still get the same results. Then I use a separate spectrum analyzer to read the output of the mixer and still using the R3 (port3) as the input of the mixer. In this case I can get the correct conversion loss value. Can someone give me some suggestions about this measurement? Next step, I want to use the FOM option to measure both magnitude and phase of my frequency conversion device. Is there a good way to do this measurement? Is the FCA option 83 available on my Network Analyzer? Thank you. Jacket |
6个回答
通常,您无法直接使用FOM测量混频器(可能,但难以校准和设置)。
首先,您必须在测量输入和输出信号之间改变接收器的频率。 但是,选项082将直接测量混频器的幅度响应。 PNA-L不支持083(至少我可以看到),所以你不能轻易测量带有PNA-L的混频器的相位响应。 这是PNA或PNA-X中添加的功能之一。 以上来自于谷歌翻译 以下为原文 Generally, you can't measure a mixer directly with FOM (it is possible, but difficult to calibrate and setup). For one thing, you must change frequencies of the receiver between measuring the input and output signals. However, option 082 will measure you mixer directly for amplitude response. PNA-L doesn't support 083 (at least as I can see) and so you can't easily measure the phase response of a mixer with PNA-L. That's one of the features that is added in the PNA or PNA-X. |
脑洞大赛9 发表于 2018-9-25 10:37 Joel博士:+“通常情况下,你无法直接使用FOM测量混频器(这是可能的,但很难校准和设置)。首先,你必须在测量输入和输出信号之间改变接收器的频率。 + +但是,选项082将直接测量混频器的幅度响应.PNA-L不支持083(至少我可以看到),因此您无法轻松测量具有PNA-L的混频器的相位响应。 这是PNA或PNA-X中添加的功能之一。“+亲爱的Joel博士,在我的情况下,我有PNA N5225A,选项080,我已经能够用它测量转换增益。 但我仍在尝试测量相位,以证明相位共轭发生在被测混频器(MUT)中。 我一直在阅读你的书(使用高级VNA技术的微波元件测量手册)第7.4.3.2节(使用参考混频器的并行路径),并说它需要校准来执行这种技术(7.5.3.1倒数校准 - 混频器反射方法 )必须将滤波器添加到参考混频器的输出。 我的第一个问题是:这个过滤器是否完全必要? 因为根据MUT的输出频率,使用不同的滤波器是不值得的。 为了尝试另一种解决方案,我一直在阅读你的论文“一种测量没有参考混频器的混频器的相位和群延迟的新方法”。 在摘要中你写道:“这种方法依赖于VNA系统,该系统利用*扫频相位相干源和接收器*来维持一个共同的相位参考。” 我的第二个问题是:我的PNA是否能够执行本文所做的测量? 我的最后一个问题是:在你的论文“一种不需要校准混合器的混合器延迟测量的新校准方法”中,这种方法是基于选件083 + Power Comb。 U9391? 非常感谢你提前。 一切顺利,Pascual 以上来自于谷歌翻译 以下为原文 Dr. Joel: +"Generally, you can't measure a mixer directly with FOM (it is possible, but difficult to calibrate and setup). For one thing, you must change frequencies of the receiver between measuring the input and output signals.+ +However, option 082 will measure you mixer directly for amplitude response. PNA-L doesn't support 083 (at least as I can see) and so you can't easily measure the phase response of a mixer with PNA-L. That's one of the features that is added in the PNA or PNA-X."+ Dear Dr. Joel, In my case I have PNA N5225A, with option 080 and I have been able to measure Conversion Gain with it. But I am still trying to measure the phase in order to demonstrate that phase conjugation is happening with the Mixer Under Test (MUT). I have been reading your book (Handbook of Microwave Component Measurements With Advanced VNA Techniques) in section 7.4.3.2 (Parallel Path Using a Reference Mixer) and it says that calibration needed to perform this technique (7.5.3.1 Reciprocal Calibration-Mixer Reflection Method) a filter must be added to the output of the reference mixer. My first question is: Is this filter totally necessary? Because it is not worth it to have a different filter depending on the output frequency of your MUT. In order to try another solution, I have been reading your paper "A Novel Method for Measuring Phase and Group Delay of Mixers Without a Reference Mixer". In the abstract you wrote this: "This method relies on a VNA system which utilizes *swept-frequency phase-coherent sources and receivers* to maintain a common phase reference." My second question is: Is my PNA able to perform the measurements made on this paper? My final question would be: In your paper named "A New Calibration Method for Mixer Delay Measurements that Requires No Calibration Mixer", Is this method based on Option 083 + Power Comb. U9391? Thank you so much in advance. All the best, Pascual |
yysdywerw 发表于 2018-9-25 10:43 >在我的情况下,我有PNA N5225A,选项080,我已经能够用它测量转换增益。 但我仍在尝试测量相位,以证明相位共轭发生在被测混频器(MUT)中。 我一直在阅读你的书(使用高级VNA技术的微波元件测量手册)第7.4.3.2节(使用参考混频器的并行路径),并说它需要校准来执行这种技术(7.5.3.1倒数校准 - 混频器反射方法 )必须将滤波器添加到参考混频器的输出。 >>我的第一个问题是:这个过滤器是否完全必要? 因为根据MUT的输出频率,使用不同的滤波器是不值得的。 一般来说,是的,这是必要的。 普通混音器会将+和 - 图像转换为输出,如果不使用滤波器,它们的反射可以重新加入或反相。 过滤器可以防止不需要的产品达到校准标准,因此从整体结果中消除了其影响。 是的,很难使用不同的滤波器,这就是我发明相位参考校准以消除这种需求的原因>>为了尝试另一种解决方案,我一直在阅读你的论文“测量相位和群延迟的新方法”。 没有参考混合器的混合器“。 >在摘要中你写道:“这种方法依赖于VNA系统,该系统利用*扫频相位相干源和接收器*来维持共同的相位参考。” >>我的第二个问题是:我的PNA是否能够执行本文所做的测量? >是的,我相信它能够进行这些测量,但它需要选项083.>我的最后一个问题是:在你的论文中,“一种新的校准方法,用于需要无校准混合器的混合器延迟测量”,这是 基于Option 083 + Power Comb的方法。 U9391? >是的,确实如此,这也消除了使用过滤器的需要。 此外,如果您的转换器具有许多不同的操作频段,您可以在很宽的频率范围内(使用大量的点)进行单次校准,然后将其应用于许多不同的频段,而不需要为每个频段设置新的校准 或每个新的LO频率。 >提前谢谢你。 >>一切顺利,> Pascual 以上来自于谷歌翻译 以下为原文 > In my case I have PNA N5225A, with option 080 and I have been able to measure Conversion Gain with it. But I am still trying to measure the phase in order to demonstrate that phase conjugation is happening with the Mixer Under Test (MUT). I have been reading your book (Handbook of Microwave Component Measurements With Advanced VNA Techniques) in section 7.4.3.2 (Parallel Path Using a Reference Mixer) and it says that calibration needed to perform this technique (7.5.3.1 Reciprocal Calibration-Mixer Reflection Method) a filter must be added to the output of the reference mixer. > > My first question is: Is this filter totally necessary? Because it is not worth it to have a different filter depending on the output frequency of your MUT. In general, yes it is necessary. A normal mixer will convert the + and - image to the output, and if no filter is used, their reflections can add back in or out of phase. The filter removes the undesired product from hitting the cal standards, and so its effect is removed from the overall result. Yes, it is difficult to use different filters, which is why I invented the phase-reference cal to eliminate this need > > In order to try another solution, I have been reading your paper "A Novel Method for Measuring Phase and Group Delay of Mixers Without a Reference Mixer". > In the abstract you wrote this: "This method relies on a VNA system which utilizes *swept-frequency phase-coherent sources and receivers* to maintain a common phase reference." > > My second question is: Is my PNA able to perform the measurements made on this paper? > Yes, I believe that it is able to make these measurements, but it will need option 083. > My final question would be: In your paper named "A New Calibration Method for Mixer Delay Measurements that Requires No Calibration Mixer", Is this method based on Option 083 + Power Comb. U9391? > Yes, exactly so, and that also eliminates the need to use a filter. Further, you can do a single calibration over a wide frequency span (use lots of points) and then apply it over many different sets of bands of frequencies if your converter has lots of different bands of operation, without requiring a new cal for each band or each new LO frequency. > Thank you so much in advance. > > All the best, > Pascual |
脑洞大赛9 发表于 2018-9-25 10:57 好。 因此,在这种情况下,最好的解决方案是获得Opt.083 + Power Comb。 有没有更快的方式获得Power Comb的贷款。 因为我上周发了一封电子邮件给微博客,我还没有收到任何答复。 非常感谢你的支持,Joel博士。 对此,我真的非常感激! 祝福,Pascual 以上来自于谷歌翻译 以下为原文 Ok. So, in this case the best solution would be to get Opt.083+Power Comb. Is there a faster way to have a loan for the Power Comb.? Because I sent an email to microlease guys last week and I haven't receive any reply yet. Thank you very much for your support, Dr. Joel. I really appreciate it! Best wishes, Pascual |
取决于您的位置。 我们的本地AE通常可以从演示套件访问阶段参考。 将您的联系信息发送给我,我会尝试跟进。 以上来自于谷歌翻译 以下为原文 Depends on your location. Our local AE's can usually access a phase-reference from a demo kit. Send me your contact info and I try to get it followed up. |
私人消息发送的联系信息。 非常感谢你的支持。 最诚挚的问候,Pascual 以上来自于谷歌翻译 以下为原文 Contact info sent by private message. Thank you so much for you support. Best Regards, Pascual |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 18:09 , Processed in 1.105609 second(s), Total 77, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
