我有超过50年的编程经验,40年的微型计算机,主要是汇编语言。我想把IOT WiFi加到一个简单的设备上,把数据和错误信息输出到一个手机上,以节省增加LCD显示的成本,并提供远程访问一个困难的位置。关于WiFi协议和整合似乎很吓人的论坛活动的基础上。这是我可以使用或我是正确的,学习曲线是非常陡峭的?成功地爬上陡峭的曲线,这是可靠的吗?输出数据是基本的ASCII字符串,是否有一个手机AP会显示它们,或者我也必须攀爬学习曲线吗?
以上来自于百度翻译 以下为原文 I have over 50 years programming experience, 40 years in microcomputers, mainly assembly language. I would like to add IoT WIFI to a simple device to output data and error messages to a cell phone to save the cost of adding an LCD display and provide remote access to a difficult location. I know very little about WIFI protocols and the integration appears rather daunting based on forum activity here. IS THIS SOMETHING I COULD USE OR AM I CORRECT THAT THE LEARNING CURVE IS VERY STEEP? HAVING SUCCEEDED IN CLIMBING THE STEEP CURVE IS THIS GOING TO BE RELIABLE? OUTPUT DATA IS ELEMENTARY ASCII STRINGS, IS THERE A CELLPHONE AP THAT WOULD DISPLAY THEM OR DO I HAVE TO CLIMB THAT LEARNING CURVE TOO? |
7个回答
IWHO使用Wi-Fi设备和内置WEB服务器,使用Wi-Fi手机上的浏览器,并将PIC数据发送到Wi-Fi设备可能提供最快/最简单的解决方案。我发现Wi-Fi(任何RF存储单元数据)是不可靠的。
以上来自于百度翻译 以下为原文 IMHO using a wi-fi device with a builtin web server and using a browser on the wi-fi enabled cell phone and sending PIC data to wi-fi device might provide the quickest/ easiest solution. I have found wi-fi (any rf save for cell data) is unreliable. |
你可以考虑蓝牙和这个解决方案HTTP://www. IfcFr.t/Smithosid。
以上来自于百度翻译 以下为原文 You could consider Bluetooth and this solution http://www.imagecraft.com/smartio Sid |
嗨,我的印象是,它是一个有很多选择的大课题。在我看来,对于WiFi连接来说,Microchip目前的推荐是ATWIN 1500或ATWIN 1510,它是Wi-Fi收音机和TCPIP协议栈中的一个模块。HTTPS://www. MigCHIP.COM/WWWORDSTMS/En/ATWC1500支持Atmel Studio 7与ATMEL软件框架和MPLAB协调的代码和示例。迈西尔
以上来自于百度翻译 以下为原文 Hi, It is my impression that it is a large subject with many options. It seem to me, that for WiFi connection, the current recommendation by Microchip is ATWINC1500 or ATWINC1510. It is Wi-Fi radio and TCPIP stack in a module. https://www.microchip.com/wwwproducts/en/ATWINC1500 Supporting code and examples in Atmel studio 7 with Atmel Software Framework, and in MPLAB Harmony. Mysil |
WiFi(IoT是一个嗡嗡的单词)可以像一个简单的串口到Wi-Fi网桥。或者作为TCP/IP栈运行在PIC上的复杂。物联网是什么?直接插座?或者是微芯片或亚马逊网络服务。如果你想呆在ASM,去一个Wi-Fi到串口桥,然后用一个插座。这将是最简单的在PIC方面。你对另一边有什么打算?
以上来自于百度翻译 以下为原文 Wifi (IoT is a Buzz word) can be as simple as a Serial to Wi-Fi Bridge. Or as complicetes as the TCP/IP stack runs on the PIC. The IOT is self is what? a direct socket to something? Or is it Microchips or Amazons web service. If you want to stay in ASM go with a Wi-Fi to serial bridge and go with a socket. It would be the simpliest on the PIC Side. What did you have planned of the other side? |
HI在同一条船上。在观察这个论坛和其他人正在进行的事情之后,我非常倾向于使用MLA解决方案。我一直在研究PIC18+MRF无线电的简单WiFi示例,它似乎是一个很好的简单解决方案,让一个小的设备有两个I/O来控制和抓取数据。一个简单的设备。我倾向于使用简单的套接字连接。它是一个透明的数据链接,易于在两个方面实现。只是我的2美分。编辑添加:上面提到的例子也支持WiC1500,除了MRF24。
以上来自于百度翻译 以下为原文 Hi I'm on the same boat. After observing what is going in this forum and others, I'm quite inclined to go with the MLA solution. I've been studying the simple wifi example for PIC18+MRF radio and it seems a good and simple solution for a small device with a couple of I/Os to control and grab data out of a simple appliance. And I'm inclined to go with a simple socket connection. Its a transparent data link easy to implement on both sides. Just my 2 cents... EDIT ADD: The mentioned example also supports WINC1500, besides the MRF24. Best regards Jorge |
WiC1500 + MLA并不太坏。有很多完整的例子包含了你想做的任何事情。
以上来自于百度翻译 以下为原文 WINC1500 + MLA isn't too bad. There are many complete examples included that cover just about anything you'd want to do. |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-20 01:35 , Processed in 1.067439 second(s), Total 76, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
